Armbian 4.5 Debian Jessie legacy boot failure on Cubieboard 2
Toast
So continuing from this thread since i dont wanna threadjack im facing a simular issue using this image used rufus instead of suse imagewriter since its defunkt on windows 10, have tested the sdcard with 0 errors took about 3 hours to do so since im using a 32gb card for my server.
Warning: Only 30418 of 30419 MByte tested.
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 5.57 MByte/s
Reading speed: 8.19 MByte/s
H2testw v1.4
So same scenario as the ubuntu distro
[ bytes read info ]
## Executing script at 43100000
** File not found /boot/.next **
** Unrecognized filesystem type **
[ bytes read info ]
** ext4fs_devread read error - block
** Can't read partition table on 0:0 **
** Invalid partition 1 **
Kernel image @ 0x48000000 [ 0x000000 - 0x558a0 ]
Staring kernel ...
as the first boot always takes some time while swap etc is being built and i left it alone came back an hour later still stuck on starting kernel.
any advice at this point ?
@Toast
@Igor would know better
** File not found /boot/.next ** .next is used for mainline kernel
The only piece of advise as "newbie", can you try to write the image from a linux machine with dd or better dc3dd tool ? so we can make sure there is no "options" making the sdcard badly written
dcfldd has also a nice "on the fly" hashing mechanism (so to avoid complex md5 or sha*)
=> dc3dd & dcfldd are improved forks of dd
Also, after writing the sdcard, "sudo fsck /dev/sdX1" would be nice as "** Unrecognized filesystem type **"
my guess is that that it just check if there is a mainline kernel if not it boots the legacy kernel.
as for writing the image sure i got a linux machine i could write the image to sd on but rufus should be able to handle it since it knows that the raw file is a dd image hasnt failed me on other distros
This looks like a fault SD but since you tested the media ... Try latest Cubietruck image which I am 100% sure that it works. I don't test images on CB2 since I don't own it.
It can't be "normal" microSD since their size is limited to 4GB
Maximum capacity
  • SD - 4GB
  • SDHC - 32GB
  • SDXC - 2TB
Look at markings on the card itself, it should be either HC or XC. And as far as I remember some XC cards have problems when they are formatted not in exFAT FS.
I have cubietruck (which essentially has same SoC, same u-boot and kernel configs, and these images should work. I suggest trying different card before blaming Armbian image.
Err not blaming trying to find the root cause of it all
and yeah its a HC, i can boot older version of debian ie cubeez on that card
OK, then I'll double check this image for any obvious problems.
Did you try booting one with kernel 4.2.3? Does it show same filesystem/partition error in u-boot?
Edit: image boots on cubietruck up to network startup, can't check any further due to network driver incompatibility.
k another sd card this time a microsd 4gb
Writing speed: 3.50 MByte/s
Reading speed: 13.9 MByte/s
H2testw v1.
Same as before trying the 4.2.3 vanilla kernel and it booted but still dont see why a HC card could make or break the boot process since i can use the old debian images from cubieboard page
still a big thx for the support and a big tnx to @igor for bringing a modern kernel to the crappy cubieboard :D
