Paul Damian Posted May 14 Posted May 14 Fresh install on the latest image (Armbian_25.2.2_Bigtreetech-cb1_bookworm_current_6.6.75_minimal.img.xz). First thing I wanted to do was an armbian-upgrade, but: Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Hit:6 https://netcup-02.armbian.com/beta bookworm InRelease Reading package lists... Done W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/debian.sources:1 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/debian.sources:1 W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/debian.sources:1 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/debian.sources:1 Any ideas? I'm a Linux noob, by the way 🙂 armbianmonitor -u file: https://paste.armbian.com/axolituped 0 Quote
Werner Posted May 14 Posted May 14 Hi, its just a warning. Check the files mentioned and remove duplicate lines. 0 Quote
Paul Damian Posted May 14 Author Posted May 14 Thank you for your quick answer. Does it count from where I remove the duplicates? 0 Quote
Solution laibsch Posted May 14 Solution Posted May 14 /etc/apt/sources.list:1 and /etc/apt/sources.list.d/debian.sources:1 Those are the files and lines that are duplicate that apt tells you about 0 Quote
