orange pi zero plus2 H5 - HDMI - audio
zeljko
install to Orange pi zero plus2 H5
Armbian_5.32.170706_Orangepizeroplus2-h5_Ubuntu_xenial_dev_4.11.8.img
install  tasksel and lubuntu and LXDE
#:  speaker-test
NOT WORK AUDIO HDMI
work to audo board
#: applay -l
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
please my help!
On 18/09/2017 at 9:14 PM, Igor said:
We can't help. Not developed or implemented yet.
Is the analog Audio on the Orange pi zero plus2 H5 not the same as on the Orange Pi Zero Plus(without2) H5?
On my Orange Pi Zero Plus(without2) H5 I got also:
root@opi-zeroplus:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
  Subdevices: 1/1
My /etc/asound.conf is:
pcm.!default {
    type hw
    card 0
    device 0
ctl.!default {
    type hw
    card 0
I activated the analog audio (named analog-codec) in armbian-config --> system --> hardware and save/reboot to activate.
(has to be done, because normally there is no audio port...only after adding the additionall USB/Audio/Video-Dock)
After installing espeak (apt install espeak) I could let the H5 talk via:
espeak -w /tmp/espeak.wav -s150 "Hello how are you today?"; aplay -D plughw:0,0 /tmp/espeak.wav 2>/dev/null
So analog sound should work with the H3 Audio Codec on a H5 device
HDMI couldnt be checked by me, because my  Orange Pi Zero Plus(without2) H5 hasnt HDMI-Audio/Video
