SPI+USB boot (Orange PI PC2 )
kope
Hi,
https://www.armbian.com/orange-pi-pc2/ states: "Following features should work:" ... "SPI+USB boot" .
I was trying to load u-boot from the SPI (but without success).
I followed the instructions in  u-boot/board/sunxi/README.sunxi64 :
$ ./sunxi-fel spiflash-write 0 spl/sunxi-spl.bin
$ ./sunxi-fel spiflash-write 32768 u-boot.itb
Booting from SPI ends with an exception:
U-Boot SPL 2017.09-armbian (Sep 13 2017 - 12:23:18)
DRAM: 1024 MiB
Trying to boot from sunxi SPI
"Synchronous Abort" handler, esr 0x02000000
ELR:     4a000000
LR:      125cc
x 0: 000000004a000000 x 1: 0000000000000000
x 2: 0000000000007000 x 3: 0000000077777777
As if SPL could find/execute u-boot or SPI at all.
Does anybody have any success with booting from SPI on OPI PC2?
It been a while since I've checked/tested SPI-NOR ...
Effectively, it seems broken now, probably since several u-boot versions.
Fortunately, I still had a old u-boot working build in last March, and I've put back this one into SPI_NOR.
EDIT : since I'm keeping a lost of previous images, I found out that another image build back in May was also working, we were still using Apriztel u-boot tree at that time. So the issue come most probably when we switched to Mainline u-boot recently ...
I've built a fresh OPiPC2 today, and yes I've got one "Synchronous Abort", but it rebooted and boot fine ...
Looking back to OPiPrime, it wasn't flood of "Synchronous Abort", but simply kernel oops, but replacing u-boot with older, the same kernel boot fine.
3 hours ago, martinayotte said:
What do you mean by "new procedure" ?
Previously this year I asked about boot from USB without SD card. Solution was flashing u boot to spi flash. With this new image doesn't work. So I would like to know how to update u boot on SPI so it will boot from USB without SD card.
Thanks
The procedure didn't really change, you need to activate the spi-jedec-nor overlay in /boot/armbianEnv.txt :
overlays=spi-jedec-nor
param_spinor_spi_bus=0
Then, after reboot, you should get from "cat /proc/mtd", something like that :
dev:    size   erasesize  name
mtd0: 00200000 00001000 "spi0.0"
This mean you can use "flashcp" to place the u-boot image into the flash.
Hello, I tried your solution, but I am doing something wrong, flashcp doesn't output nothing. Is that right? When I connect HDD and try to boot, I get error
No matching DT out of these options:
   Configuration to load ATF before U-Boot
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
What am I doing wrong?
Maybe I don't understand the steps you achieve successfully and the one that maybe failed ...
Using the overlay, did you successfully got "cat /proc/mtd ".
If Yes, then you did the flashcp and got no errors.
Next , you've halted the board, remove the SDCard, and repower the board, and U-Boot from Flash actually executed display the output you've mentioned above. Right ?
This means the USB storage you used isn't discovered. I've got such issue with some USB thumb dongles. Did you tried a real USB-HDD drive ?
You should see something like "USB 1 Storage detected" or similar message ...
If you have placed a copy of /boot into that USB drive,  you should see u-boot loading the DT/uInitrd/Image followed by "Starting kernel"
Finaly I understood why this procedure with flashcp doesn't work as it did with previous images. U-boot is split between spl.bin and u-boot file. Previously it was one file with all-in-one. So I don't know how to flash to SPI-NOR with two files. Anybody with ideas are welcome.
Ah ! Ok ! Now I understand ...
Simply concatenate both files into one :
cat /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/sunxi-spl.bin /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot.itb > /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin
Then, you can use normal "flashcp" cmdline :
flashcp /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin /dev/mtd0
