OPiWin - stretch testing
t-bob
i've built and started testing stretch ... it mostly looks pretty good with these issues found so far
lircd - goes wild. systemd goes to 100% cpu
   it need to be blacklisted or the like. stopping/disabling it didnt work. i need to remove it to stop the cpu usage problem
   https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=860551
install python-wheel as default package as pip breaks without it
eth0 has gone but seems to be a known issue
   https://irclog.whitequark.org/linux-sunxi/2017-09-19
and I see that hdmi has made progress (by smaeul)
   https://irclog.whitequark.org/linux-sunxi/2017-09-26
the hdmi part of linux doesnt work yet so you'll see the part of the booting up process and then nothing. we dont have an eta on hdmi working yet :(
buy a usb-ttl device and hook that to the serial connection
the ethernet port may not work either as they have pulled support for that for the moment. wifi only :(
Seems like it answers the question:
"The second is dwmac-sun8i, this a glue to the stmmac driver. You can find the latest version at https://github.com/montjoie/linux/tree/dwmac-sun8i-current
This driver is mainline, but DT was reverted in 4.13-rc7. DT should be back soon."
http://linux-sunxi.org/Sun8i_emac
What exactly need to be done? Can java back-end developer with minimum c and kernel skills help in any way? :)
I had a play with reverting the DTS files but with no luck. I expect there may be some u-boot changes that need to be added given that it doesnt find it on boot either. It complained about pinctrl I think.
        cp /boot/dtb/allwinner/sun50i-a64-orangepi-win.dtb /boot/dtb/allwinner/sun50i-a64-orangepi-win.dtb.orig
        dtc -I dtb -O dts -o /boot/dtb/allwinner/sun50i-a64-orangepi-win.dts /boot/dtb/allwinner/sun50i-a64-orangepi-win.dtb
        vi +/ethernet /boot/dtb/allwinner/sun50i-a64-orangepi-win.dts
        dtc -I dts -O dtb -o /boot/dtb/allwinner/sun50i-a64-orangepi-win.dtb /boot/dtb/allwinner/sun50i-a64-orangepi-win.dts
