NanoPi Neo Air - Unable to load i2c-sunxi
moonki123
uname -a : Linux nanopiair 3.4.113-sun8i #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017 armv7l armv7l armv7l GNU/Linux
i installed i2c-tools, libi2c-dev, python-smbus
but if i try like this
i2cdetect -y 0
   0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
i2cdetect -y 1
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
i can't use i2c
gpio load i2c
->  gpio: Unable to load i2c-sunxi
so i tried like this
so i add overlays = i2c0 i2c1
/boot/armbianEnv.txt  and /etc/modprobe.d/blacklist.conf(checking i2c-bcm2708 and i2c-dev)
add from /etc/modules -> i2c-bcm2708, i2c-dev
Eventually I could not find a possible i2c number
so what should i do?
please tell me detail ~
Legacy doesn't use DT and its overlays.
To enable I2C on Legacy, you need to decompile the /boot/script.bin into FEX, edit the FEX and recompile the BIN.
(Of course, you should do a backup of /boot/script.bin in case of trouble...)
thanks your reply
you mean change this part
[twi0_para]
twi0_used = 1 // (enable)
twi0_scl = port:PB00<2><default><default><default> // i think Hardware pin number
twi0_sda = port:PB01<2><default><default><default> // also pin number
but i want to use another i2c address
now 0x48 address be used so i want to use another one
so your method is not match to this question so what should i do?
I do not know if the peripherals I think are right, but let me tell you.
my peripherals is mpu-6050(accleration + gyro-sensor)
Now i using H3 chip and i don't know manufacturer
my processor is  ARMv7 Processor rev 5 (v7l)
hardware is sun8i
i used this Wiring - git clone git://github.com/wertyzp/WiringNP
and my gpio -v is
Copyright (c) 2012-2014 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Banana Pro Details:
  Type: Model A, Revision: 1.2, Memory: 1024MB, Maker: LeMaker
That's all I know.
As I said :
18 hours ago, martinayotte said:
If you don't see your at 0x68, it is probably a wiring problem.
The MPU6050 is effectively at 0x68 (or 0x69 if AD0 is pulled high).
Since it doesn't appear in your test, the wiring is incorrect.
Did you have PullUps on your bus ?
Is the VLOGIC pin is at VCC ?
Are you using pre-fab module ?
Be careful when attaching 5V devices on 3.3V buses ... You need mosfet level-shifter.
Some board provide PullUps, some other don't.
If "i2cdetect" is slow showing the devices, it proves that no pullup present.
Then add somes, usually 4K7 should be Ok !
Um "i2cdetect" is not showing the devices
so it's same result ...
also A few months ago an orange pi zero succeeded in connecting i2c but now Orangepi Zero showed same result as the nanoPi neo air
Is there no other way to use another address?
On 2017/09/28 at 3:15 AM, moonki123 said:
[twi0_para]
This is probably the cause : looking at Neo Air schematic, I2C0-SCL is on PA11 and I2C0-SDA is on PA12 ...
Do you mean arm board?
I checked the mpu-6050 at Aduino_mega
But the mpu-6050 did not matter
I have raspberry pi, orangepi zero and orangepi zero plus
but also same symptom in orangepi zero(not working I2C)
before It worked in orangepi zero using I2C device
It seems to be caused by an update issue
