SzLA Posted December 22, 2015 Share Posted December 22, 2015 Hi, I try to run Armbian 4.5 (Bananapi Ubuntu trusty 3.4.109 desktop) on my Banana Pi M1+, but after the "Starting kernel..." prompt the monitor show only the "No signal" warning. (I connect the Banana Pi to my monitor with HDMI - DVI converter, I will be able to try it with single HDMI cable a few days later.) However, it boots. I have a lot of tries to change the boot.cmd and the banana.bin, but I didn't achieve satisfying result. The result of dmesg: [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.110-sun7i (root@production) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #2 SMP PREEMPT Sat Nov 28 19:53:25 CET 2015 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun7i [ 0.000000] Memory Reserved: [ 0.000000] SYS : 0x43000000 - 0x4300ffff ( 64 kB) [ 0.000000] VE : 0x44000000 - 0x48ffffff ( 80 MB) [ 0.000000] G2D : 0x49000000 - 0x49ffffff ( 16 MB) [ 0.000000] LCD : 0x4a000000 - 0x4bffffff ( 32 MB) [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] sunxi: Allwinner A20 (AW1651/sun7i) detected. [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat c0a7b780, node_mem_map d0000000 [ 0.000000] DMA zone: 512 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 65024 pages, LIFO batch:15 [ 0.000000] Normal zone: 1008 pages used for memmap [ 0.000000] Normal zone: 128016 pages, LIFO batch:31 [ 0.000000] HighMem zone: 528 pages used for memmap [ 0.000000] HighMem zone: 67056 pages, LIFO batch:15 [ 0.000000] PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768 [ 0.000000] pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096 [ 0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 hdmi.audio=0 disp.screen0_output_mode=1280x1024p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 893656k/893656k available, 154920k reserved, 270336K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc09d2b30 (10027 kB) [ 0.000000] .init : 0xc09d3000 - 0xc0a0b040 ( 225 kB) [ 0.000000] .data : 0xc0a0c000 - 0xc0a83f28 ( 480 kB) [ 0.000000] .bss : 0xc0a83f4c - 0xc0c592f8 (1877 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:192 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] start_kernel(): bug: interrupts were enabled early [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.013307] Calibrating delay loop... 1816.98 BogoMIPS (lpj=9084928) [ 0.076003] pid_max: default: 32768 minimum: 301 [ 0.079682] Mount-cache hash table entries: 512 [ 0.083946] Initializing cgroup subsys cpuacct [ 0.087266] Initializing cgroup subsys memory [ 0.090691] Initializing cgroup subsys devices [ 0.094129] Initializing cgroup subsys freezer [ 0.097354] Initializing cgroup subsys blkio [ 0.101030] Initializing cgroup subsys perf_event [ 0.104610] CPU: Testing write buffer coherency: ok [ 0.109808] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.116912] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available [ 0.122453] Setting up static identity map for 0x40713450 - 0x407134a8 [ 0.238386] CPU1: Booted secondary processor [ 0.297364] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.299376] Brought up 2 CPUs [ 0.304687] SMP: Total of 2 processors activated (3640.52 BogoMIPS). [ 0.307961] devtmpfs: initialized [ 0.313460] dummy: [ 0.317139] NET: Registered protocol family 16 [ 0.323411] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.331119] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.335987] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.339142] [ccu-inf] aw clock manager init [ 0.341414] [ccu-inf] aw_ccu_init [ 0.345388] [ccu-inf] script config pll3 to 297MHz [ 0.349140] [ccu-inf] script config pll4 to 300MHz [ 0.352888] [ccu-inf] script config pll6 to 600MHz [ 0.356653] [ccu-inf] script config pll7 to 297MHz [ 0.360400] [ccu-inf] script config pll8 to 336MHz [ 0.363165] Init eGon pin module V2.0 [ 0.372394] bio: create slab <bio-0> at 0 [ 0.375992] sunxi_gpio driver init ver 1.3 [ 0.382278] gpiochip_add: registered GPIOs 1 to 88 on device: A1X_GPIO [ 0.385504] SCSI subsystem initialized [ 0.388348] libata version 3.00 loaded. [ 0.392996] usbcore: registered new interface driver usbfs [ 0.397349] usbcore: registered new interface driver hub [ 0.401521] usbcore: registered new device driver usb [ 0.404640] Linux media interface: v0.10 [ 0.408280] Linux video capture interface: v2.00 [ 0.413876] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.419188] Switching to clocksource arch_sys_counter [ 0.421306] FS-Cache: Loaded [ 0.423499] CacheFiles: Loaded [ 0.434590] cfg80211: Calling CRDA to update world regulatory domain [ 0.439946] [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG [ 0.443765] [sw_hcd0]: usb host driver initialize........ [ 0.447936] [sw_hcd0]: open_usb_clock [ 0.472205] [sw_hcd0]: host_init_state = 0 [ 0.473176] [sw_hcd0]: platform is usb host [ 0.476083] [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn) [ 0.487269] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70 [ 0.499808] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver [ 0.506521] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 [ 0.509936] hub 1-0:1.0: USB hub found [ 0.512868] hub 1-0:1.0: 1 port detected [ 0.516724] wrn: hcd is not enable, need not start hcd [ 0.518061] [sw_hcd0]: sw_usb_host0_disable start [ 0.524103] -------sw_hcd0_soft_disconnect--------- [ 0.527085] is_on = 0, hcd0_set_vbus_cnt = 0 [ 0.530136] [sw_hcd_host0]: Set USB Power Off [ 0.533880] wrn: hcd is not enable, need not stop hcd [ 0.534934] [sw_hcd0]: close_usb_clock [ 0.537398] [sw_hcd0]: sw_usb_host0_disable end [ 0.540605] [sw_udc]: udc_init: version 20080411 [ 0.546953] NET: Registered protocol family 2 [ 0.563851] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.570793] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.578322] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.584990] TCP: Hash tables configured (established 131072 bind 65536) [ 0.587177] TCP: reno registered [ 0.592054] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.597404] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.601021] NET: Registered protocol family 1 [ 0.606278] RPC: Registered named UNIX socket transport module. [ 0.609941] RPC: Registered udp transport module. [ 0.613725] RPC: Registered tcp transport module. [ 0.619117] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.624694] audit: initializing netlink socket (disabled) [ 0.628395] type=2000 audit(0.610:1): initialized [ 0.632685] highmem bounce pool size: 64 pages [ 0.644483] VFS: Disk quotas dquot_6.5.2 [ 0.649989] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.657225] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.662620] NFS: Registering the id_resolver key type [ 0.667185] NTFS driver 2.1.30 [Flags: R/W]. [ 0.670497] fuse init (API version 7.18) [ 0.675179] JFS: nTxBlock = 6981, nTxLock = 55853 [ 0.692126] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled [ 0.696395] Btrfs loaded [ 0.699216] msgmni has been set to 1217 [ 0.706859] alg: No test for stdrng (krng) [ 0.713548] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 0.716548] io scheduler noop registered [ 0.719775] io scheduler deadline registered [ 0.723529] io scheduler cfq registered (default) [ 0.728420] sunxi disp driver loaded (/dev/disp api 1.0) [ 0.733977] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.738742] [uart]: used uart info.: 0x81 [ 0.743431] [uart]: serial probe 0 irq 33 mapbase 0x01c28000 [ 0.769729] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A [ 0.774624] [uart]: serial probe 7 irq 52 mapbase 0x01c29c00 [ 0.800829] sunxi-uart.7: ttyS1 at MMIO 0x1c29c00 (irq = 52) is a U6_16550A [ 0.803448] G2D: drv_g2d_init [ 0.808151] G2D: g2dmem: g2d_start=49000000, g2d_size=1000000 [ 0.811376] G2D: head:c9000000,tail:ca000000 [ 0.814748] G2D: Module initialized.major:250 [ 0.824218] brd: module loaded [ 0.830308] loop: module loaded [ 0.832642] nand driver is disabled [ 0.836424] gpio count < =0 ,gpio_count is: 0 [ 0.842347] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP [ 0.846847] ahci: SSS flag set, parallel bus scan disabled [ 0.854258] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 0.861149] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc [ 0.864559] scsi0 : sw_ahci_platform [ 0.871777] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88 [ 0.876322] [spi-inf] Found 1 spi devices in config files [ 0.883164] [spi-inf] boards num modalias max_spd_hz bus_num cs mode [ 0.886953] [spi-inf] spi_board0 irq gpio not used [ 0.893908] [spi-inf] 0 spidev 12000000 0 0 0x3 [ 0.898005] [spi-inf] sun7i_spi_probe: sun7i spi probe [ 0.902625] [spi-inf] sun7i_spi_probe: spi0 dma type: normal [ 0.906227] [spi-inf] bus num = 0, spi used = 3 [ 0.910666] [spi-inf] sun7i_spi_probe: spi0 cs bitmap: 0x3 [ 0.919231] [spi-inf] sun7i_spi_set_mclk: spi0 source = sdram_pll_p, src_clk = 432000000, mclk 86400000 [ 0.925156] sun7i-spi sun7i-spi.0: master is unqueued, this is deprecated [ 0.931259] [spi-inf] sun7i_spi_setup: enter, bpw: 8, mshz: 12000000, mode: 3 [ 0.940071] [spi-inf] sun7i_spi_probe: reuuimlla's SoC SPI Driver loaded for Bus SPI0 with 2 Slaves at most [ 0.949474] [spi-inf] sun7i_spi_probe: spi0 driver probe succeed, base f0518000, irq 42, dma_id_rx 24, dma_id_tx 24 [ 0.955608] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 0.960358] Fixed MDIO Bus: probed [ 0.964951] emac_init fetch emac using configuration failed [ 0.967398] emac driver is disabled [ 0.970934] gmac: use mac address from chipid [ 0.975058] gmac: device MAC address 02:19:06:03:54:f8 [ 0.980747] [gmac]: sun6i_gmac platform driver registration completed [ 0.984057] PPP generic driver version 2.4.2 [ 0.987993] PPP BSD Compression module registered [ 0.992000] PPP Deflate Compression module registered [ 0.996905] PPP MPPE Compression module registered [ 1.000311] NET: Registered protocol family 24 [ 1.006371] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.011568] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.014040] [sw-ehci1]: open clock [ 1.036721] [sw-ehci1]: Set USB Power ON [ 1.043159] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.049399] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 [ 1.053809] sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000 [ 1.073623] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 [ 1.076989] hub 2-0:1.0: USB hub found [ 1.079885] hub 2-0:1.0: 1 port detected [ 1.082550] [sw-ohci1]: open clock [ 1.108698] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 1.114918] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 [ 1.119257] sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400 [ 1.186673] hub 3-0:1.0: USB hub found [ 1.189568] hub 3-0:1.0: 1 port detected [ 1.192226] [sw-ehci2]: open clock [ 1.214916] [sw-ehci2]: Set USB Power ON [ 1.221352] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.225708] ata1: SATA link down (SStatus 0 SControl 300) [ 1.231990] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 [ 1.236403] sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000 [ 1.253619] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 [ 1.256960] hub 4-0:1.0: USB hub found [ 1.259854] hub 4-0:1.0: 1 port detected [ 1.262515] [sw-ohci2]: open clock [ 1.288666] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 1.294912] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 [ 1.299301] sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400 [ 1.366652] hub 5-0:1.0: USB hub found [ 1.369545] hub 5-0:1.0: 1 port detected [ 1.373825] Initializing USB Mass Storage driver... [ 1.378946] usbcore: registered new interface driver usb-storage [ 1.382520] USB Mass Storage support registered. [ 1.387475] usbcore: registered new interface driver ums-alauda [ 1.392475] usbcore: registered new interface driver ums-cypress [ 1.397495] usbcore: registered new interface driver ums-datafab [ 1.402667] usbcore: registered new interface driver ums_eneub6250 [ 1.407693] usbcore: registered new interface driver ums-freecom [ 1.412604] usbcore: registered new interface driver ums-isd200 [ 1.417708] usbcore: registered new interface driver ums-jumpshot [ 1.422533] usbcore: registered new interface driver ums-karma [ 1.427635] usbcore: registered new interface driver ums-onetouch [ 1.432652] usbcore: registered new interface driver ums-realtek [ 1.437581] usbcore: registered new interface driver ums-sddr09 [ 1.442492] usbcore: registered new interface driver ums-sddr55 [ 1.447333] usbcore: registered new interface driver ums-usbat [ 1.452104] mousedev: PS/2 mouse device common for all mice [ 1.457786] ===========================hv_keypad_init===================== [ 1.461185] ========HV Inital =================== [ 1.465129] tkey_fetch_sysconfig_para: tkey_unused. [ 1.472342] hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 [ 1.478146] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 [ 1.480643] i2c /dev entries driver [ 1.484581] config i2c gpio with gpio_config api [ 1.490203] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected [ 1.496050] axp_mfd 0-0034: AXP internal temperature monitoring enabled [ 1.501286] [AXP]axp driver uning configuration failed(342) [ 1.503253] [AXP]power_start = 0 [ 1.506928] i2c i2c-0: Invalid probe address 0x00 [ 1.509982] I2C: i2c-0: AW16XX I2C adapter [ 1.513379] config i2c gpio with gpio_config api [ 1.517355] i2c i2c-1: Invalid probe address 0x00 [ 1.520409] I2C: i2c-1: AW16XX I2C adapter [ 1.523810] config i2c gpio with gpio_config api [ 1.527777] i2c i2c-2: Invalid probe address 0x00 [ 1.530832] I2C: i2c-2: AW16XX I2C adapter [ 1.534224] config i2c gpio with gpio_config api [ 1.538153] i2c i2c-3: Invalid probe address 0x00 [ 1.541207] I2C: i2c-3: AW16XX I2C adapter [ 1.543973] [cedar dev]: install start!!! [ 1.546942] [cedar dev]: install end!!! [ 1.550342] [tt]----- avs_dev driver load... ---- [ 1.553939] [tt]----- register iomem ---- [ 1.556733] Cannot reserve region for ccmu [ 1.560369] [tt]--- avs_dev driver load ok!! ----- [ 1.562141] [ace_drv] start!!! [ 1.564507] [ace_drv] init end!!! [ 1.566172] [pa_drv] start!!! [ 1.568414] [pa_drv] init end!!! [ 1.570794] axp20_ldo1: 1300 mV [ 1.576054] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV [ 1.581160] axp20_ldo3: 700 <--> 3500 mV at 2800 mV [ 1.586355] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV [ 1.591716] axp20_buck2: 700 <--> 2275 mV at 1450 mV [ 1.598236] somebody is trying to set dcdc3 range to (1300000, 1300000) uV [ 1.603263] but we keep dcdc3 = 1250000 uV from the bootloader [ 1.607532] axp20_buck3: 700 <--> 3500 mV at 1250 mV [ 1.612397] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV [ 1.621976] input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0 [ 1.640496] axp20_ldo2: Failed to create debugfs directory [ 1.643758] incomplete xfer (0x20) [ 1.646023] incomplete xfer (0x20) [ 1.648276] incomplete xfer (0x20) [ 1.650526] incomplete xfer (0x20) [ 1.652809] incomplete xfer (0x20) [ 1.655062] incomplete xfer (0x20) [ 1.657313] incomplete xfer (0x20) [ 1.659563] incomplete xfer (0x20) [ 1.661831] incomplete xfer (0x20) [ 1.664170] incomplete xfer (0x20) [ 1.666504] incomplete xfer (0x20) [ 1.668838] incomplete xfer (0x20) [ 1.671172] incomplete xfer (0x20) [ 1.673523] incomplete xfer (0x20) [ 1.675857] incomplete xfer (0x20) [ 1.678191] incomplete xfer (0x20) [ 1.680525] incomplete xfer (0x20) [ 1.682872] incomplete xfer (0x20) [ 1.685210] incomplete xfer (0x20) [ 1.687544] incomplete xfer (0x20) [ 1.689878] incomplete xfer (0x20) [ 1.692226] incomplete xfer (0x20) [ 1.694561] incomplete xfer (0x20) [ 1.696895] incomplete xfer (0x20) [ 1.699230] incomplete xfer (0x20) [ 1.701595] incomplete xfer (0x20) [ 1.703930] incomplete xfer (0x20) [ 1.706268] incomplete xfer (0x20) [ 1.708604] incomplete xfer (0x20) [ 1.710938] incomplete xfer (0x20) [ 1.713287] incomplete xfer (0x20) [ 1.715621] incomplete xfer (0x20) [ 1.717956] incomplete xfer (0x20) [ 1.720290] incomplete xfer (0x20) [ 1.722638] incomplete xfer (0x20) [ 1.724973] incomplete xfer (0x20) [ 1.728964] device-mapper: uevent: version 1.0.3 [ 1.736810] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 1.741660] device-mapper: multipath: version 1.3.2 loaded [ 1.747176] device-mapper: multipath round-robin: version 1.0.0 loaded [ 1.752743] device-mapper: multipath queue-length: version 0.1.0 loaded [ 1.758323] device-mapper: multipath service-time: version 0.2.0 loaded [ 1.761763] cpuidle: using governor ladder [ 1.764674] cpuidle: using governor menu [ 1.766994] [mmc-msg] sw_mci_init [ 1.772714] [mmc-msg] MMC host used card: 0x1, boot card: 0x0, io_card 0 [ 1.777978] [mmc-msg] sdc0 set round clock 400000, src 24000000 [ 1.786238] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.794458] [mmc-msg] sdc0 Probe: base:0xf0570000 irq:64 sg_cpu:f0572000(4fc00000) ret 0. [ 1.799056] [mmc_pm]: failed to fetch sdio card configuration! [ 1.801493] sunxi_leds driver init [ 1.805608] Registered led device: green:ph24:led1 [ 1.810614] ledtrig-cpu: registered to indicate activity on CPUs [ 1.815824] usbcore: registered new interface driver usbhid [ 1.818615] usbhid: USB HID core driver [ 1.821308] ashmem: initialized [ 1.824981] logger: created 256K log 'log_main' [ 1.828784] logger: created 256K log 'log_events' [ 1.832480] logger: created 256K log 'log_radio' [ 1.836300] logger: created 256K log 'log_system' [ 1.843119] [sPDIF] [spdif_para] isn't defined or spdif_used=0 [ 1.845977] [i2S-0] Entered sunxi_i2s_init [ 1.853711] [i2S-0] sunxi-i2s cannot find any using configuration for controllers, return directly! [ 1.861434] [i2S-0] sndi2s cannot find any using configuration for controllers, return directly! [ 1.864510] [i2S-0] Entered sunxi_sndi2s_init [ 1.867947] IPv4 over IPv4 tunneling driver [ 1.870771] TCP: bic registered [ 1.873111] TCP: cubic registered [ 1.875643] TCP: westwood registered [ 1.878259] TCP: highspeed registered [ 1.880528] TCP: hybla registered [ 1.882728] TCP: htcp registered [ 1.884998] TCP: vegas registered [ 1.887181] TCP: veno registered [ 1.889710] TCP: scalable registered [ 1.891733] TCP: lp registered [ 1.893916] TCP: yeah registered [ 1.896445] TCP: illinois registered [ 1.899667] Initializing XFRM netlink socket [ 1.903792] NET: Registered protocol family 10 [ 1.908453] NET: Registered protocol family 17 [ 1.911889] NET: Registered protocol family 15 [ 1.916606] [mmc_pm]: No sdio card, please check your config !! [ 1.920278] Registering the dns_resolver key type [ 1.922377] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 [ 1.930930] Registering SWP/SWPB emulation handler [ 1.935580] axp20_buck2: Failed to create debugfs directory [ 1.941749] [cpu_freq] INF:-------------------V-F Table------------------- [ 1.946828] [cpu_freq] INF: voltage = 1450mv frequency = 1008MHz [ 1.951873] [cpu_freq] INF: voltage = 1425mv frequency = 912MHz [ 1.956931] [cpu_freq] INF: voltage = 1350mv frequency = 864MHz [ 1.961976] [cpu_freq] INF: voltage = 1250mv frequency = 720MHz [ 1.967032] [cpu_freq] INF: voltage = 1150mv frequency = 528MHz [ 1.972077] [cpu_freq] INF: voltage = 1100mv frequency = 312MHz [ 1.977132] [cpu_freq] INF: voltage = 1050mv frequency = 144MHz [ 1.982177] [cpu_freq] INF: voltage = 1000mv frequency = 0MHz [ 1.988011] [cpu_freq] INF:----------------------------------------------- [ 1.997747] [cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz [ 2.001809] registered taskstats version 1 [ 2.006426] I2C: i2c-4: HDMI I2C adapter [ 2.035927] disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0 [ 2.778155] [mmc-msg] mmc 0 detect change, present 1 [ 3.277226] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.279688] [mmc-msg] sdc0 power on [ 3.307615] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.312538] [mmc-msg] sdc0 set round clock 400000, src 24000000 [ 3.314463] Console: switching to colour frame buffer device 240x67 [ 3.365744] axp20_buck3: incomplete constraints, leaving on [ 3.370551] axp20_buck2: incomplete constraints, leaving on [ 3.375305] axp20_ldo4: incomplete constraints, leaving on [ 3.380023] axp20_ldo3: incomplete constraints, leaving on [ 3.384762] axp20_ldo2: incomplete constraints, leaving on [ 3.389479] axp20_ldo1: incomplete constraints, leaving on [ 3.392528] console [netcon0] enabled [ 3.396036] netconsole: network logging started [ 3.399353] [mmc-err] smc 0 err, cmd 52, RTO [ 3.403568] otg_wakelock_init: No USB transceiver found [ 3.406883] [mmc-err] smc 0 err, cmd 52, RTO [ 3.415265] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.422747] sunxi-rtc sunxi-rtc: setting system clock to 2015-12-22 14:19:35 UTC (1450793975) [ 3.424825] ALSA device list: [ 3.427879] #0: sunxi-CODEC Audio Codec [ 3.436223] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.440826] Waiting for root device /dev/mmcblk0p1... [ 3.444059] [mmc-err] smc 0 err, cmd 5, RTO [ 3.448118] [mmc-err] smc 0 err, cmd 5, RTO [ 3.452176] [mmc-err] smc 0 err, cmd 5, RTO [ 3.456237] [mmc-err] smc 0 err, cmd 5, RTO [ 3.465265] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.473632] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.484929] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.520331] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 3.528792] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 3.533961] [mmc-msg] sdc0 set round clock 42857143, src 600000000 [ 3.597495] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B [ 3.601981] mmc0: new high speed SDHC card at address 59b4 [ 3.606060] mmcblk0: mmc0:59b4 00000 7.35 GiB [ 3.609036] mmcblk0: p1 [ 3.703083] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 3.708169] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 3.714526] devtmpfs: mounted [ 3.717518] Freeing init memory: 224K [ 6.072977] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS [ 6.995548] systemd-udevd[191]: starting version 204 [ 7.327344] Bluetooth: Core ver 2.16 [ 7.331238] NET: Registered protocol family 31 [ 7.338741] Bluetooth: HCI device and connection manager initialized [ 7.344663] Bluetooth: HCI socket layer initialized [ 7.348706] Bluetooth: L2CAP socket layer initialized [ 7.352633] Bluetooth: SCO socket layer initialized [ 7.390067] Bluetooth: HCI UART driver ver 2.2 [ 7.393886] Bluetooth: HCI H4 protocol initialized [ 7.398480] Bluetooth: HCI BCSP protocol initialized [ 7.402163] Bluetooth: HCILL protocol initialized [ 7.424626] Bluetooth: HCIATH3K protocol initialized [ 7.636997] Bluetooth: RFCOMM TTY layer initialized [ 7.641657] Bluetooth: RFCOMM socket layer initialized [ 7.664712] Bluetooth: RFCOMM ver 1.11 [ 7.738435] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 7.747152] Bluetooth: BNEP filters: protocol multicast [ 7.799345] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 8.026025] input: sunxi-ir as /devices/virtual/input/input1 [ 8.032606] IR Initial OK [ 8.393926] 8021q: 802.1Q VLAN Support v1.8 [ 8.466964] a20-tp-hwmon a20-tp-hwmon: TP initialization success [ 9.907672] sunxi_gmac: probed [ 9.913096] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active [ 9.926405] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01) [ 11.932465] PHY: sunxi_gmac-0:00 - Link is Up - 100/Full [ 15.182314] init: failsafe main process (514) killed by TERM signal [ 20.782273] eth0: no IPv6 routers present [ 21.453958] Warning: this sunxi disp driver will see significant redesign. [ 21.459310] Applications using /dev/disp directly will break. [ 21.466034] For more information visit: http://linux-sunxi.org/Sunxi_disp_driver [ 21.469124] [DISP] layer allocated: 0,101 What can I try to solve it? Thank you very much for the help! Andrew Link to comment Share on other sites More sharing options...
Igor Posted December 23, 2015 Share Posted December 23, 2015 Mode 1280x1024p60 is not supported. Link to comment Share on other sites More sharing options...
SzLA Posted December 23, 2015 Author Share Posted December 23, 2015 Thank you Igor your quick answer! I apologize for my inattention, I didn't suspect, that "Documentation" button have another function, than open the drop-down menu. So I changed the display settings in boot.cmd and banana.bin too and tried some supported resolutions (720p 60Hz, 720p 50Hz, 480p), but these didn't work for me. I guess, my monitor hates fruits... Andrew 1 Link to comment Share on other sites More sharing options...
matteobp Posted December 31, 2015 Share Posted December 31, 2015 I have the Banana Pi M1+ too. I was able to change the boot.cmd using a ssh session (with putty). I changed the boot.cmd as follow disp.screen0_output_mode=1280x1024p60 and then I recreate the boot.scr mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr After a reboot I can see the output on my monitor using a hdmi-dvi cable (my monitor doesn't have a hdmi port) at 1280x1024. Link to comment Share on other sites More sharing options...
Skygod Posted December 31, 2015 Share Posted December 31, 2015 Cheers for that matteopb, I'll give that a go tomorrow, as I'd almost given up on ever seeing output from the HDMI port. Link to comment Share on other sites More sharing options...
