Need help for Banana Pro I2S DAC PCM 5102
choss38
Hi,
I'm not able to make my DAC to work on my Banana Pro.
It's PCM 5102 DAC and it worked on my previous Armbian Wheezy
My config:
uname -a
Linux bananapipro 4.11.6-sunxi #6 SMP Fri Jun 23 19:56:18 CEST 2017 armv7l GNU/Linux
The DAC doesn't appear:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sun4icodec [sun4i-codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
I looked in armbian-config tool but there is nothing to activate overlays
I looked in folder /boot/dtb/overlays but saw nothing about I2S
I would like to do as I did before, I edited the fex file but I can't find it.
I can't mount the first partition to access /boot because I can see only one partition on my SD card !
fdisk -l
Disk /dev/mmcblk0: 7,4 GiB, 7969177600 bytes, 15564800 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x01841151
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       2048 15253503 15251456  7,3G 83 Linux
Maybe there are some new tricks last years I didn't read but I don't find anything about in the forum or on the web.
Someone can help me ?
Thank you for answer !
But how to made and activate manually an overlay ?
I found this on A10/A20 here: https://docs.armbian.com/Hardware_Allwinner-A20/
Quote
Legacy
System images with legacy kernel
Kernel 3.4.x with large hardware support, headers and some firmware included
Enabled audio devices: analog, 8 channel HDMI, spdif and I2S (if wired and enabled in HW configuration)
What does it mean ?  Is it an other way ?
How to enabled I2S in HW configuration ?
Ok, thank you.
I maybe too a newbie for this work !
I'm going to try with this:
/dts-v1/;
#include "sun7i-a20.dtsi"
#include "sunxi-common-regulators.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/interrupt-controller/irq.h>
        compatible = "allwinner,sun7i-a20";
        pcm5102: pcm510x {
                compatible = "ti,pcm5102a";
                pcm510x,format = "i2s";
                #sound-dai-cells = <0>;
        sound_i2s {
                compatible = "simple-audio-card";
                simple-audio-card,format = "i2s";
                simple-audio-card,mclk-fs = <256>;
                simple-audio-card,cpu {
                        sound-dai = <&i2s0>;
                simple-audio-card,codec {
                        sound-dai = <&pcm5102>;
&i2s0 {
        pinctrl-names = "default";
        pinctrl-0 = <&i2s0_bclk>, <&i2s0_lrclk>, <&i2s0_sdo0>;
        status = "okay";
Do I need all the fifth first lines ?
And I don't see how I can configure the good GPIO's pin ? for example, pin 35 = LRCK, pin 36 = BCLK, pin 40 = DATA (sdo0 ?)
It's a big problem for me: I don't really understand all the code I wrote, I'm afraid to burn my GPIO or other component on my board.
Fisrt, I tried this:
/dts-v1/;
/plugin/;
        fragment@0 {
                target = <&i2s0>;
                __overlay__ {
                        pcm5102a: pcm510x {
        fragment@1 {
                target-path= "/";
                __overlay__ {
                        sound_i2s {
                                        sound-dai = <&pcm5102a>;
but no trace in the system after reboot:
 sudo aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
default:CARD=sun4icodec
    sun4i-codec,
    Default Audio Device
sysdefault:CARD=sun4icodec
    sun4i-codec,
dmix:CARD=sun4icodec,DEV=0
    sun4i-codec,
    Direct sample mixing device
dsnoop:CARD=sun4icodec,DEV=0
    sun4i-codec,
    Direct sample snooping device
hw:CARD=sun4icodec,DEV=0
    sun4i-codec,
    Direct hardware device without any conversions
plughw:CARD=sun4icodec,DEV=0
    sun4i-codec,
    Hardware device with all software conversions
 cat /proc/asound/cards
 0 [sun4icodec     ]: sun4i-codec - sun4i-codec
                      sun4i-codec
and of course no sound
sudo speaker-test -c 2 -f 440 -t sine
speaker-test 1.0.28
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
Sine wave rate is 440,0000Hz
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 128 to 131072
Period size range from 64 to 16384
Using max buffer size 131072
Periods = 4
was set period_size = 16384
was set buffer_size = 131072
 0 - Front Left
 1 - Front Right
Time per period = 2,837370
 0 - Front Left
I Tried to adapt also an HifiBerry DAC for Raspberry pi dts:
// Definitions for HiFiBerry DAC
/dts-v1/;
/plugin/;
        fragment@0 {
                target = <&sound>;
                __overlay__ {
                        compatible = "hifiberry,hifiberry-dac";
                        i2s-controller = <&i2s>;
                        status = "okay";
        fragment@1 {
                target = <&i2s>;
                __overlay__ {
                        status = "okay";
        fragment@2 {
                target-path = "/";
                __overlay__ {
                        pcm5102a-codec {
                                status = "okay";
sudo armbian-add-overlay hifiberry-dac.dts
Compiling the overlay
Copying the compiled overlay file to /boot/overlay-user/
Nothing more. Nada.
sudo aplay -L
[sudo] password for pi:
null
    sun4i-codec,
    sun4i-codec,
    sun4i-codec,
    sun4i-codec,
    sun4i-codec,
    sun4i-codec,
                      sun4i-codec
It's too complicated for me ! :wacko:
Am I in a wrong way ?
Please ! I need help !!
