pastito Posted October 22, 2017 Share Posted October 22, 2017 Hi, I am having doubts on how to use I2C ADS1115 unit on Orange Pi Lite. I already have I2C module and tools installed (see below). Thing is, where do I get the Phyton library to make use of it? Are there any examples? The other question is about wiring. When I connect to twi0 I cannot see the I2C device: root@orangepilite:~# i2cdetect -y twi0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- But when I connect to twi1 a 48 appears (I believe that is the device address) root@orangepilite:~# i2cdetect -y twi1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- How do you read that? As i2cget returns 0x00 root@orangepilite:~# i2cget -y twi1 0x48 0x00 Thanks and Regards Link to comment Share on other sites More sharing options...
martinayotte Posted October 22, 2017 Share Posted October 22, 2017 You won't be able to communicate using i2cget, this chip has several register that need to be initialized in order to get analog conversion done. Googling reveal to me that maybe this library could help you : https://learn.adafruit.com/raspberry-pi-analog-to-digital-converters/ads1015-slash-ads1115 This tutorial could help too : http://www.piettes.com/solar-panel-datalogging-with-raspberry-pi-and-ads1115/ Link to comment Share on other sites More sharing options...
pastito Posted October 23, 2017 Author Share Posted October 23, 2017 It works nicely, thank you! Here is a hygrometer connected to port 2 root@orangepilite:~/Adafruit_Python_ADS1x15/examples# ./test.py Reading ADS1x15 values, press Ctrl-C to quit... | 0 | 1 | 2 | 3 | ------------------------------------- | 5460 | 4780 | 25822 | 25822 | | 5716 | 4770 | 25823 | 6356 | Now I wonder why I can only use I2C bus 1 (twi1 --GPIO pins PA19 and PA18--) and not 0 (twi0 --PA11 and PA12--) I also tested this on Raspberry Pi 3 rev B and works nicely too. Thanks and regards Link to comment Share on other sites More sharing options...
martinayotte Posted October 23, 2017 Share Posted October 23, 2017 The fact that you get a "UU" when attached on TWI0 mean that it is detected by a kernel driver, most probably ads1015.ko. You can check that while been connected on TWI0 if this driver is loaded by looking at "lsmod". If Yes, then you can't talk directly to the chip, you need to talk to the driver, most probably from /sys/class/hwmon/hwmon0/device. This is a bit explained here : http://www.jumpnowtek.com/rpi/Using-ads1115-ADCs-with-Raspberry-Pis.html Link to comment Share on other sites More sharing options...
pastito Posted October 23, 2017 Author Share Posted October 23, 2017 Thank you for the information. Now I was trying to set that up, but I cannot seem to find /boot/config.txt in Armbian there is only /boot/armbianEnv.txt I added the following lines: dtparam=i2c_arm=on dtoverlay=ads1115 dtparam=cha_enable dtparam=chb_enable dtparam=chc_enable dtparam=chd_enable dtparam=cha_enable,cha_cfg=0A Then I compiled with mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr And rebooted, but still no luck. It does not work. I see the following error in dmesg [ 82.263791] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x76) [ 82.264134] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77) Any ideas? Thanks! Link to comment Share on other sites More sharing options...
martinayotte Posted October 24, 2017 Share Posted October 24, 2017 Of course, the link I've provided was just for generic reference, because it is specific to RaspberryPi, not for Armbian. You will need first to create an overlay from scratch and place it in /boot/dtb/overlay, then add its name into armbianEnv.txt. Here some hints, but still not cooked solution, about this overlay : https://www.kernel.org/doc/Documentation/devicetree/bindings/hwmon/ads1015.txt https://github.com/modmaker/BeBoPr/wiki/Better-Analog-Inputs https://dev.seemoo.tu-darmstadt.de/bcm/bcm-rpi3/blob/041eec392e9a2e63d94d5b53059718425703f8f7/kernel/arch/arm/boot/dts/overlays/ads1015-overlay.dts Link to comment Share on other sites More sharing options...
zador.blood.stained Posted October 24, 2017 Share Posted October 24, 2017 1 hour ago, martinayotte said: You will need first to create an overlay from scratch and place it in /boot/dtb/overlay, then add its name into armbianEnv.txt. ...but this will work only with the mainline kernel Link to comment Share on other sites More sharing options...
martinayotte Posted October 24, 2017 Share Posted October 24, 2017 1 hour ago, zador.blood.stained said: ...but this will work only with the mainline kernel Of course ... Link to comment Share on other sites More sharing options...
pastito Posted October 26, 2017 Author Share Posted October 26, 2017 Thank you guys for your answers! I am a very seasoned linux sysadmin (been working on it since 1995). It does not seem to be worth the effort to create an overlay to make the bus work since twi1 is working. I will investigate overlays though... when I have a few spare cycles. So far I was able to port everything that I had running on the raspberry pi into the orange pi with Armbian. That is a DS18B0 digital thermometer, a 4 channel optically coupled relay board, an LDR with a 1uF to check light levels and the ADS1115 with 4 hygrometers. Everything is working great. Plus I was able to install apache / PHP / rrdtool and it is generating beautiful graphics on a ramdisk and sync'in the data once a day (in order not to burn the flash quickly). My experience has been very pleasant thanks to you. I was afraid of buying the orange pi as everybody on the internet is talking that it has poor support and that it is hard to do some things on it. Well in my experience y only took a few hours to make it work and it is a great value. I will probably buy a few more powerful ones to create other projects... my gardening setup is almost ready for deployment! I am waiting for the solenoid water valves and need to write some watering code based on humidity statistics! Thanks and regards Link to comment Share on other sites More sharing options...
