selfbg Posted November 2, 2017 Share Posted November 2, 2017 Hello, I want to use touchscreen on my lcd. To do this I do the following: Compile my own dtbo and load it: /dts-v1/; /plugin/; / { compatible = "allwinner,sun7i-a20"; fragment@0 { target = <&rtp>; __overlay__ { allwinner,ts-attached; }; }; }; Blacklist gpadc modules: blacklist sun4i_gpadc_iio blacklist sun4i_gpadc After reboot the touchscreen is working. However I cannot see what is loading these two modules? Also is there any other way getting working touchscreen? I'm using armbian 5.34 with kernel version 4.13.11. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted November 2, 2017 Share Posted November 2, 2017 sun4i-gpadc is loaded by DT "compatible" string rtp: rtp@01c25000 { compatible = "allwinner,sun5i-a13-ts"; reg = <0x01c25000 0x100>; interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; #thermal-sensor-cells = <0>; }; ➜ ~ % modinfo sun4i-gpadc | grep ^alias alias: of:N*T*Callwinner,sun6i-a31-tsC* alias: of:N*T*Callwinner,sun6i-a31-ts alias: of:N*T*Callwinner,sun5i-a13-tsC* alias: of:N*T*Callwinner,sun5i-a13-ts alias: of:N*T*Callwinner,sun4i-a10-tsC* alias: of:N*T*Callwinner,sun4i-a10-ts ➜ ~ % And sun4i-gpadc is an MFD driver and it will try to probe the sun4i-gpadc-iio config MFD_SUN4I_GPADC tristate "Allwinner sunxi platforms' GPADC MFD driver" select MFD_CORE select REGMAP_MMIO select REGMAP_IRQ depends on ARCH_SUNXI || COMPILE_TEST depends on !TOUCHSCREEN_SUN4I help Select this to get support for Allwinner SoCs (A10, A13 and A31) ADC. This driver will only map the hardware interrupt and registers, you have to select individual drivers based on this MFD to be able to use the ADC or the thermal sensor. This will try to probe the ADC driver sun4i-gpadc-iio and the hwmon driver iio_hwmon. To compile this driver as a module, choose M here: the module will be called sun4i-gpadc. Link to comment Share on other sites More sharing options...
selfbg Posted November 3, 2017 Author Share Posted November 3, 2017 So, this is the correct way of enabling the touchscreen? Link to comment Share on other sites More sharing options...
