korrupto Posted November 3, 2017 Share Posted November 3, 2017 (edited) Hello, I've flashed several times last image from cubox-i but I have this: Wrong image format for "source" command file not found /boot.scr file not fougn /uEnv.txt file not found /zImage file not found /uImage ..... ERROR: Did not find a cndline Flattened Device Tree Could not find a valid device tree ..... And more ¿Whats wrong? Thanks Edited November 3, 2017 by korrupto Link to comment Share on other sites More sharing options...
0 Tido Posted November 3, 2017 Share Posted November 3, 2017 7z and zip archives can be uncompressed with 7-Zip on Windows, Keka on OS X and 7z on Linux. Images shall only be written with Etcher on all platforms since unlike other tools Etcher validates burning results saving you from corrupted SD card contents. Link to comment Share on other sites More sharing options...
0 korrupto Posted November 3, 2017 Author Share Posted November 3, 2017 Yes, every time with Etcher.... Link to comment Share on other sites More sharing options...
0 Igor Posted November 4, 2017 Share Posted November 4, 2017 Did not find a cndline Flattened Device Tree This is the problem - u-boot does not recognize your board properly. I assume you are trying to run a modern kernel? Try this. Add: setenv fdt_file imx6dl-cubox-i.dtb to /boot/boot.cmd and recompile boot script with mkimage -C none -A arm -T script -d boot.cmd boot.scr (you will need some Debian based Linux to mount your SD card there and install u-boot-tools) You can try first with adding fdt_file=imx6dl-cubox-i.dtb to /boot/armbianEnv.txt but I am not sure this works properly at Cubox since u-boot is very old. One (quick and dirty) way is also to copy /boot/dtb/imx6dl-cubox-i.dtb to /boot/dtb/imx6-cubox-i-som-v45.dtb (or whatever you have under file not found) Link to comment Share on other sites More sharing options...
0 korrupto Posted November 4, 2017 Author Share Posted November 4, 2017 Thanks, Thanks, but it is very difficult for me to compile. I'll have to look for something else, otherwise I'll go crazy Link to comment Share on other sites More sharing options...
0 Igor Posted November 4, 2017 Share Posted November 4, 2017 Than try 3rd option. Copy file from one to another. You only need some linux to access sd card. Something else will most likely have same problem since we all use the same uboot from Solidrun.Wrote on mobile Link to comment Share on other sites More sharing options...
0 korrupto Posted November 4, 2017 Author Share Posted November 4, 2017 Ok, I'll tried. Thanks Link to comment Share on other sites More sharing options...
Question
korrupto
And more
¿Whats wrong?
Thanks
Edited by korruptoLink to comment
6 answers to this question
