Marthinius Posted November 6, 2017 Share Posted November 6, 2017 Hello, board: Orange pi One OS: Armbian 16.04 I installed the opi monitor using the command: sudo armbianmonitor -r error: Memory usage is not displayed, show only: Used: NaNkB (NaN%) Available: NaNkB Total: NaNkB The free memory is displayed in the statistics, but not in the Status. I try: edit file /etc/rpimonitor/template/memory.conf Locate line reading dynamic.15.source=/usr/bin/free -mk Replace this line and the following (in my version: lines 21 and 22) with dynamic.15.source=/proc/meminfo dynamic.15.regexp=MemAvailable:\s+(\d+) Save file and restart rpi-monitor . But still memory usage not show any value in the status Link to comment Share on other sites More sharing options...
tkaiser Posted November 6, 2017 Share Posted November 6, 2017 1 hour ago, Marthinius said: /etc/rpimonitor/template/memory.conf This file is original contents from RPi-Monitor. I never touched it since displaying 'free memory' is misleading anyway. The issue came up multiple times (use the google search box on the upper right please) and you might find some 'fixes', eg. https://forum.armbian.com/topic/4418-how-to-select-a-good-board-processor/?do=findComment&comment=34439 Link to comment Share on other sites More sharing options...
Marthinius Posted November 6, 2017 Author Share Posted November 6, 2017 I searched on the internet, tried to reinstall the opi monitor. Your link solved memory problem. Thank you so much Really awesome... Link to comment Share on other sites More sharing options...
