Nick A Posted November 8 Posted November 8 (edited) For those with a Radxa Cubie A7A/A7Z, I made a custom Armbian Build using the BSP kernel. https://github.com/NickAlilovic/build/tree/Radxa-A7A Now supports automatic first boot configuration by default. No need for a usb serial device to boot into a desktop image. First boot takes awhile to load. If you are using a server image you need a usb serial device/ssh to interact with the console. There is no Framebuffer console support in the BSP kernel. If you want to edit the automatic first boot configuration read the documentation. https://docs.armbian.com/User-Guide_Autoconfig/ Username: radxa password: radxa Edited November 28 by Nick A Add a7z support 0 Quote
Nick A Posted November 8 Author Posted November 8 @eli It's compiled in the kernel https://github.com/NickAlilovic/build/blob/Radxa-A7A/config/kernel/linux-sun60i-legacy.config#L1659-L1672 0 Quote
Nick A Posted November 12 Author Posted November 12 (edited) Fixed the automatic first boot configuration on Bookwarm. Now you can boot the desktop image without a usb serial device. Edited November 12 by Nick A 0 Quote
Shubham Singh Posted November 19 Posted November 19 Hey @Nick A, first of all, thanks for providing us with the build, I flashed and tried the image, But I could not see kvm enabled in the system. Is this expected? some example outputs: ~$ ls -l /dev/kvm ls: cannot access '/dev/kvm': No such file or directory ~$ sudo dmesg | grep -i kvm [ 0.184039] kvm [1]: HYP mode not available also no output on lscpu | grep Virtualization 0 Quote
Nick A Posted November 19 Author Posted November 19 (edited) @Shubham Singh To check if KVM is compiled into the kernel, use the following command: grep CONFIG_KVM /boot/config-$(uname -r) CONFIG_KVM=y CONFIG_KVM_MMIO=y CONFIG_KVM_VFIO=y CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y CONFIG_KVM_XFER_TO_GUEST_WORK=y A7A: Harware Virtualization https://forum.radxa.com/t/a7a-harware-virtualization/29745 Edited November 25 by Nick A 1 Quote
zmxyz Posted November 28 Posted November 28 I saw a commit for the A7Z (not the A7A, the one that looks like the Raspberry Pi Zero). Is it available now? 0 Quote
Nick A Posted November 28 Author Posted November 28 (edited) @zmxyz I added support for A7Z. But I haven't tested it yet. I don't own a A7Z. Compile an image and let me know if it works. Edited November 28 by Nick A 0 Quote
zmxyz Posted November 28 Posted November 28 Looks like it's working fine! Thanks for your work. 0 Quote
Gavin Munday Posted November 29 Posted November 29 when i do ./compile.sh i cant see the board in the list??? 0 Quote
Gavin Munday Posted November 29 Posted November 29 i have, board not there unless it using some other name? 0 Quote
Nick A Posted November 29 Author Posted November 29 (edited) @Gavin Mundayhttps://github.com/NickAlilovic/build/blob/Radxa-A7A/config/boards/radxa-cubie-a7z.csc Edited November 29 by Nick A 0 Quote
Gavin Munday Posted November 29 Posted November 29 sadly my a7a doesnt doesnt boot with the image that outputs from the build 0 Quote
Nick A Posted November 29 Author Posted November 29 (edited) @Gavin Munday Did you compile a desktop or server image? Did you write the image onto a reliable sdcard? Remember there’s no framebuffer support. Server images need a usb to serial device attached to the UART. Having a usb serial device attached to the UART helps with these types of problems. https://docs.radxa.com/en/cubie/a7a/system-config/uart_debug Also, first boot might take awhile to boot. For desktop images wait at least 5 minutes for a display manager login screen. Edited November 29 by Nick A 0 Quote
Gavin Munday Posted December 2 Posted December 2 server image, there was no activity led tried 2 decent sd cards, nothing board and activity led works with radxa bullseye os on same sd cards 0 Quote
Nick A Posted December 2 Author Posted December 2 @Gavin Munday Try these images. Extract them first before you write to the SD card. https://github.com/NickAlilovic/build/releases/tag/Radxa-a7a-v0.3 0 Quote
伍翠波 Posted December 6 Posted December 6 It is expected that the server image supports Framebuffer. 0 Quote
Nick A Posted December 6 Author Posted December 6 You’re more than welcome to clone my repository and fix the frame buffer console. All the sources are there except u-boot. 0 Quote
laibsch Posted December 8 Posted December 8 thank you for your work, @Nick A Is this being pushed back to Armbian itself eventually? 0 Quote
Werner Posted Tuesday at 03:52 AM Posted Tuesday at 03:52 AM First step is to cleanup and bump the sunxi patchset to 6.18. This is a major blocker. Once that is done. Patches for more recent Allwinner SoCs can be added. I started doing that but it is extremely exhausting. I have no clue how the-going managed to maintain that for that long... must be sort of masochistic or something lol. https://github.com/EvilOlaf/build/tree/sunxi-6.18 0 Quote
Dalibor Pospíšil Posted Thursday at 09:58 AM Posted Thursday at 09:58 AM Great job, man! Would it be possible to build the kernel SATA support in the next release? I have the PentaHAT attached to it. It works well with the sunxi kernel eng build but their systems is way too old so I prefer Armbian. 0 Quote
Werner Posted Thursday at 11:43 AM Posted Thursday at 11:43 AM Once this is merged, more recent SoC code can be rebased on top:https://github.com/armbian/build/pull/9049 0 Quote
