fandres Posted November 18, 2017 Share Posted November 18, 2017 I bought an orange plate zero pi that I requested for a project. The issue is that I can not start the AP mode. I am making use of the hostapd and isc-dhcp-server packages, apparently everything is well configured, I am thinking that the problem is the chip driver of the wireless network. I put some relevant data, from now on thanks. root@orangepizero:~# /usr/sbin/hostapd /etc/hostapd/hostapd.conf Configuration file: /etc/hostapd/hostapd.conf nl80211: Could not configure driver mode nl80211: deinit ifname=wlan0 disabled_11b_rates=0 nl80211 driver initialization failed. wlan0: interface state UNINITIALIZED->DISABLED wlan0: AP-DISABLED hostapd_free_hapd_data: Interface wlan0 wasn't started root@orangepizero:~# uname -r 4.13.8-sunxi OS: Ubuntu 16.04.3 LTS 4.13.8-sunxi cat /etc/hostapd/hostapd.conf interface=wlan0 #driver= ssid=Onion Pi country_code=ES hw_mode=g channel=6 macaddr_acl=0 auth_algs=1 ignore_broadcast_ssid=0 wpa=2 wpa_passphrase=pa22w0rd_extra_d1f1c1l wpa_key_mgmt=WPA-PSK wpa_pairwise=CCMP wpa_group_rekey=86400 ieee80211n=1 wme_enabled=1 Someone ah successfully configured AP mode on the orange zero with Armbian pi? What problem do I have? with what driver do I try? Any suggestions? PD. sorry for my English Link to comment Share on other sites More sharing options...
Piv Klit Posted November 18, 2017 Share Posted November 18, 2017 I did it, and never got it stable, It can run for 14 days, it can run for a few hours, BUT IT WILL CRASH. You need to configure your /etc/network/interfaces. to get it to work. Delete everything in it and set it up as you normally would and it should work. Right now you have probably just set up the wifi in there, but you need to add the eth to with either a dhcp or static setup. I guess you used the adafruit guide Link to comment Share on other sites More sharing options...
Igor Posted November 18, 2017 Share Posted November 18, 2017 1 hour ago, fandres said: Someone ah successfully configured AP mode on the orange zero with Armbian pi? What problem do I have? with what driver do I try? Any suggestions? Download the latest image, use/switch to beta and do apt-get update & upgrade. Than run armbian-config ... Link to comment Share on other sites More sharing options...
fandres Posted November 18, 2017 Author Share Posted November 18, 2017 Hello Thanks Friend, it worked Link to comment Share on other sites More sharing options...
fandres Posted November 18, 2017 Author Share Posted November 18, 2017 I have used these two guides in conjunction with changing to the beta branch, which the friend Igor recommended. http://orangepiweb.es/wifi-access-point.php https://frillip.com/using-your-raspberry-pi-3-as-a-wifi-access-point-with-hostapd/ Link to comment Share on other sites More sharing options...
