comrade_bear Posted November 19, 2017 Share Posted November 19, 2017 Thank your for the good works to make these board run much better. I have ARMBIAN 5.34.171116 install on opi pc2, what I try to archive is rather simple. I can mount usb stick, but not usb hard disk, after plugin, the disk (NS1068x controller) will turn on LED, but seems nothing happen in /dev/. My knowledge can not help me beyond this point, Any help will be appreciated Link to comment Share on other sites More sharing options...
chwe Posted November 19, 2017 Share Posted November 19, 2017 How do you power your HDD when connecting to the OPi PC2? If you power it through the SBC ist most probably a power issue... Link to comment Share on other sites More sharing options...
comrade_bear Posted November 19, 2017 Author Share Posted November 19, 2017 8 minutes ago, chwe said: How do you power your HDD when connecting to the OPi PC2? If you power it through the SBC ist most probably a power issue... Yes, HD drain power from SBC, I'm using a 2.5" 1T disk, It was working flawlessly on raspberry pi2's USB ports. Any way to test it? Thx. Link to comment Share on other sites More sharing options...
chwe Posted November 19, 2017 Share Posted November 19, 2017 Does it spin-up? How do you power your OPi PC2 (type of PSU)? Link to comment Share on other sites More sharing options...
comrade_bear Posted November 19, 2017 Author Share Posted November 19, 2017 17 minutes ago, chwe said: Does it spin-up? How do you power your OPi PC2 (type of PSU)? I heard a click sound from the hard disk, so I think the mist for me is clear now, thank you very much, I'm not quite sure why Raspberry pi can power up the HD, yet the orange pi pc 2 doesn't, it's connected to a 2.4A rating PSU. Link to comment Share on other sites More sharing options...
tkaiser Posted November 19, 2017 Share Posted November 19, 2017 1 hour ago, comrade_bear said: it's connected to a 2.4A rating PSU How? With one of those 'PSP charger cables' which often have too tiny wires? Anyway, this thread should be moved to https://forum.armbian.com/forum/31-sd-card-and-power-supply/ Link to comment Share on other sites More sharing options...
comrade_bear Posted November 19, 2017 Author Share Posted November 19, 2017 6 minutes ago, tkaiser said: How? With one of those 'PSP charger cables' which often have too tiny wires? Anyway, this thread should be moved to https://forum.armbian.com/forum/31-sd-card-and-power-supply/ I was too ignorance, thank you for the hint. Link to comment Share on other sites More sharing options...
TonyMac32 Posted November 19, 2017 Share Posted November 19, 2017 8 hours ago, comrade_bear said: thank you for the hint. It is common with anything designed for developers/marketed to hobbyists. I feel like this would have been common at old radio club meetings, where someone forgot to wire in an antenna... In reality the board makers needs to include some of this education in the package if they are working this way, human nature does not include reading the FAQ when joining a forum. Link to comment Share on other sites More sharing options...
comrade_bear Posted November 19, 2017 Author Share Posted November 19, 2017 3 minutes ago, TonyMac32 said: It is common with anything designed for developers/marketed to hobbyists. I feel like this would have been common at old radio club meetings, where someone forgot to wire in an antenna... In reality the board makers needs to include some of this education in the package if they are working this way, human nature does not include reading the FAQ when joining a forum. You are absolutely right, I think these kind of mistake is too common and counter productive. And I feel stupid to make one more. Link to comment Share on other sites More sharing options...
