  • 0
SolidRun MicroSoM rev. 1.5 does not boot
sescsen
Question
I am unable to boot the latest armbian version on my hummingboard using a MicroSoM i1 rev. 1.5.
It seems to be an DTB problem. The boot error is "no valid device tree binary"
Does anybody have the same problem or a solution?
7 answers to this question
  • 0
This is my output, nothing happens after that:
U-Boot 2017.11-armbian (Dec 15 2017 - 13:29:26 +0100)
CPU:   Freescale i.MX6SOLO rev1.3 996 MHz (running at 792 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 32C
Reset cause: POR
Board: MX6 Hummingboard
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
*** Warning - bad CRC, using default environment
No panel detected: default to HDMI
Display: HDMI (1024x768)
In:    serial
Out:   serial
Err:   serial
Net:   FEC
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
1816 bytes read in 121 ms (14.6 KiB/s)
## Executing script at 12000000
0 bytes read in 78 ms (0 Bytes/s)
78 bytes read in 96 ms (0 Bytes/s)
37846 bytes read in 278 ms (132.8 KiB/s)
4333097 bytes read in 363 ms (11.4 MiB/s)
5236152 bytes read in 415 ms (12 MiB/s)
## Loading init Ramdisk from Legacy Image at 14800000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4333033 Bytes = 4.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800c3d5
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
  • 0
Mount SD card on some Linux and add:
fdt_file=imx6dl-hummingboard-som-v15.dtb
or if you have HB2
fdt_file=imx6dl-hummingboard2-som-v15.dtb
to the /boot/armbianEnv.txt
If you have eMMC version then imx6dl-hummingboard-emmc-som-v15.dtb and imx6dl-hummingboard2-emmc-som-v15.dtb
  • 0
Thank you for your quick response, unfortunately this does not solve the problem.
I am not using a HB2, so i added the line
the resulting armbianEnv.txt is attached
armbianEnv.txt
Update:
I am able to login using HDMI and a Keyboard. Serial Terminal still does not work.
  • 0
Nice!
Known (upstream) bug, AFAIK unresolved.
