OrangePi PC no boot
hanni76
Hello,
all images for OrangePI PC (next) produced  since yesterday give the following output:
U-Boot SPL 2017.11-armbian (Dec 03 2017 - 17:13:28)
DRAM: 1024 MiB
Trying to boot from MMC1
Uncompressing Linux... done, booting the kernel.
Loading, please wait...
starting version 232
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
An old image is booting fine.
Any ideas?
Thanks
I found that UUID specified in armbianEnv.txt is wrong (???). I have no idea why this happened... One reason to come to my mind is that I mounted a Samba share to "armbian/build/output/images". I am going to try a new build without it.
It seems like the problem didn't exist couple of days ago.
ALERT!  UUID=4dc850bc-ea4c-436a-8a3f-57793795e7a4 does not exist.  Dropping to a shell!
The image was created in Virtualbox. I never seen this before when I was making builds on the "hardware" host.
I have attached serial port log.
minicom.log
Here is the build log when image was created:
[ o.k. ] Preparing image file for rootfs [ orangepipc stretch ]
[ o.k. ] Current rootfs size [ 942 MiB ]
[ o.k. ] Creating blank image for rootfs [ 1456 MiB ]
1.42GiB [70.7MiB/s] [================================================================================================================>] 100%
[ o.k. ] Creating partitions [ root: ext4 ]
[ .... ] Creating rootfs [ ext4 ]
[ .... ] Copying files to root directory
        885.87M  99%   37.06MB/s    0:00:22 (xfr#30842, to-chk=0/38646)
sent 888.22M bytes  received 620.71K bytes  37.82M bytes/sec
total size is 890.87M  speedup is 1.00
[ .... ] Copying files to /boot directory
         24.57M  99%  133.73MB/s    0:00:00 (xfr#154, to-chk=0/161)
sent 24.59M bytes  received 2.97K bytes  49.18M bytes/sec
total size is 24.57M  speedup is 1.00
[ o.k. ] Free space: [ SD card ]
Filesystem                     Size  Used Avail Use% Mounted on
udev                           2.0G     0  2.0G   0% /dev
tmpfs                          396M  5.9M  390M   2% /run
/dev/sda1                       57G   17G   38G  32% /
tmpfs                          2.0G     0  2.0G   0% /dev/shm
tmpfs                          5.0M     0  5.0M   0% /run/lock
tmpfs                          2.0G     0  2.0G   0% /sys/fs/cgroup
//192.168.3.50/smb-toolchains  170G   92G   69G  58% /home/sergey/Projects/armbian/build/cache/toolchains
//192.168.3.50/smb-qt5-build   170G   92G   69G  58% /home/sergey/Projects/qt5-build
//192.168.3.50/smb-boards      170G   92G   69G  58% /home/sergey/Projects/boards
tmpfs                          396M     0  396M   0% /run/user/1000
tmpfs                          2.6G  942M  1.7G  36% /home/sergey/Projects/armbian/build/.tmp/rootfs-next-orangepipc-stretch-no
/dev/loop0p1                   1.4G  957M  396M  71% /home/sergey/Projects/armbian/build/.tmp/mount-next-orangepipc-stretch-no
[ o.k. ] Writing U-boot bootloader [ /dev/loop0 ]
[ o.k. ] Done building [ /home/sergey/Projects/armbian/build/output/images/Armbian_5.36_Orangepipc_Debian_stretch_next_4.14.3.img ]
[ o.k. ] Runtime [ 26 min ]
One interesting detail:  /dev/loop0 is not unmounted in the end and is still visible in blkid.
I can't confirm or deny if we have some problems since we changed few things and I haven't really made an image in the last 24h.
Any idea why that UUID didn't match or didn't exist at all? When I check SD card on host Ubuntu it looks ok.
Here is log file from "hardware" host:
udev            5,9G     0  5,9G   0% /dev
tmpfs           1,2G   27M  1,2G   3% /run
/dev/sda4       156G   22G  126G  15% /
tmpfs           5,9G  171M  5,7G   3% /dev/shm
tmpfs           5,0M  8,0K  5,0M   1% /run/lock
tmpfs           5,9G     0  5,9G   0% /sys/fs/cgroup
/dev/sda5       170G   97G   64G  61% /home/sergey/Projects
/dev/sda6        92G   68M   87G   1% /home/sergey/Public
/dev/sda7       105G   60M  100G   1% /home/sergey/Projects2
tmpfs           1,2G  100K  1,2G   1% /run/user/1000
tmpfs           7,8G  314M  7,5G   4% /home/sergey/Projects/armbian/build/.tmp/rootfs-next-orangepipc-stretch-no
/dev/loop0p1    547M  320M  205M  61% /home/sergey/Projects/armbian/build/.tmp/mount-next-orangepipc-stretch-no
Hardware host, Ubuntu 16.04, produces working images. So the problem exists only in Virtualbox.
IMAGES (without any customization) CREATED IN VIRTUALBOX DO NOT BOOT.
i.e. Virtualbox can't be considered as a reliable platform for building Armbian images. At least until I find a reason why this happens.
