Hikmet TEKIN Posted December 14, 2017 Share Posted December 14, 2017 Hi everybody, My question is about stop a running program with C. I have written a c code to start program with system() function in orange pi zero. I am starting RTKLIB software, which is STR2STR and when my code starts the software with command str2str -in serial://ttyS1:115200 -out serial:ttyS2:115200, I can stop it with CTRL^C but I want to stop it from my software. When I got a TCP pocket containing a exit status word. It should stop the STR2STR software. I am not very good at linux. How can I do that? Thanks Link to comment Share on other sites More sharing options...
FredrikA Posted January 27, 2018 Share Posted January 27, 2018 If you can start it you can stop it. when you start it keep a reference to the PID, then follow this guide https://www.thegeekstuff.com/2011/02/send-signal-to-process/ Link to comment Share on other sites More sharing options...
