Piv Klit Posted December 15, 2017 Share Posted December 15, 2017 Looking in the forums for a few days and reading up on a lot of stuff, I got the zero to boot from spi and USB, fairly easy once you got the right commands, and replacing "linux-u-boot-next-orangepipc2_5.34_arm64" with the version on the image for the board. Quote The procedure didn't really change, you need to activate the spi-jedec-nor overlay in /boot/armbianEnv.txt : overlays=spi-jedec-nor param_spinor_spi_bus=0 Then, after reboot, you should get from "cat /proc/mtd", something like that : dev: size erasesize name mtd0: 00200000 00001000 "spi0.0" Then cat /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/sunxi-spl.bin /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot.itb > /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin and flash with flashcp /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin /dev/mtd0 The I tried NFS shares and that worked fine to, but now I want to boot directly from another server, providing different folders for each board that I have and use spi for the boot. The reading the forum again to find out more about NFS booting, and mostly found this "hurray I got it to work" then kind of leaving the rest of us hanging there thinking HOW??? I was then reading about uboot and found out that it have ethernet enabled, so guess it´s prepared for this kind of booting. So I need to change something in uboot so it will know what ip and folder to look after, since I'm looking into booting different boards? Oh and heres a picture of my crazy project. Link to comment Share on other sites More sharing options...
Piv Klit Posted October 28, 2018 Author Share Posted October 28, 2018 Nearly a year later, and other people asking me in my inbox if I got it to work. No I didn't, I'm still on SPI + USB, but if anybody got it to work, please post it here so me and others can get this to work Link to comment Share on other sites More sharing options...
zux Posted January 6, 2019 Share Posted January 6, 2019 ## set this to NFS root path (ip:path) ## or else provide dhcp option 17 (root-path) #setenv nfs_root # for DHCP setenv net_setup "ip=dhcp" # for static configuration see documentation # https://github.com/torvalds/linux/blob/master/Documentation/filesystems/nfs/nfsroot.txt # setenv net_setup "ip=<client-ip>:<server-ip>:<gw-ip>:<netmask>:<hostname>:<device>:<autoconf>:<dns0-ip>:<dns1-ip>" # you may need to add extra kernel arguments specific to your device setenv bootargs "console=tty1 console=ttyS0,115200 root=/dev/nfs ${net_setup} rw rootflags=noatime,nodiratime disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 logle if test -n ${nfs_root}; then setenv bootargs "${bootargs} nfsroot=${nfs_root}" fi tftp ${kernel_addr_r} ${serverip}:vmlinuz-4.14.91-sunxi tftp ${ramdisk_addr_r} ${serverip}:uInitrd-4.14.91-sunxi tftp ${fdt_addr_r} ${serverip}:sun8i-h2-plus-orangepi-zero.dtb bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} save and do mkimage -C none -A arm -T script -d boot.cmd boot.scr.uimg copy boot.scr.uimg, vmlinuz,uInitrd, *.dtb to tftp folder and boot. Working for me Link to comment Share on other sites More sharing options...
zux Posted January 6, 2019 Share Posted January 6, 2019 For building nfs image and vmlinuz,uInitrd, *.dtb On ubuntu 18.04 apt -y install git git clone https://github.com/armbian/build cd build ./compile.sh ROOTFS_TYPE=nfs wait.....................................................................DONE cd output/images ls .....nfsboot-rootfs.tgz .....nfsboot.img .....nfsboot-rootfs.tgz tar -xzf to nfs export dir fdisk -l .....nfsboot.img ........Orangepizero_Ubuntu_bionic_next_......._nfsboot.img1 8192 131071 122880 60M 83 Linux 8192 * 512 = 4194304 mount -o loop,offset=4194304 .....nfsboot.img /mnt copy vmlinuz,uInitrd, and dtb for you platform to tftp dir Link to comment Share on other sites More sharing options...
Dmahony Posted January 29, 2019 Share Posted January 29, 2019 Hi @zux Thanks for the extra instructions. I get stuck at 'Uncompressing Linux... done, booting the kernel.' This is what I've done: => setenv serverip 192.168.1.209 => setenv ipaddr 192.168.1.170 => setenv fdtfile sun8i-h2-plus-orangepi-zero.dtb => setenv tftpblocksize 1024 => usb start => tftp ${kernel_addr_r} vmlinuz-4.19.17-sunxi ethernet@1c30000 Waiting for PHY auto negotiation to complete. done Using ethernet@1c30000 device TFTP from server 192.168.1.209; our IP address is 192.168.1.170 Filename 'vmlinuz-4.19.17-sunxi'. Load address: 0x42000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################ 4.4 MiB/s done Bytes transferred = 7313648 (6f98f0 hex) => tftp ${fdt_addr_r} ${fdtfile} Using ethernet@1c30000 device TFTP from server 192.168.1.209; our IP address is 192.168.1.170 Filename 'sun8i-h2-plus-orangepi-zero.dtb'. Load address: 0x43000000 Loading: ###### 3.4 MiB/s done Bytes transferred = 28787 (7073 hex) => setenv nfs_ip 192.168.1.209 => setenv rootpath /nfsboot/ubuntu/ => setenv bootargs earlyprintk console=ttyAMA0 console=tty1 ip=dhcp root=/dev/nfs rootwait => bootz ${kernel_addr_r} - ${fdt_addr_r} ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Device Tree to 49ff5000, end 49fff072 ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. If anyone can help it would be much appreciated. Link to comment Share on other sites More sharing options...
Dmahony Posted January 29, 2019 Share Posted January 29, 2019 I got it working with: setenv fdtfile sun8i-h2-plus-orangepi-zero.dtb usb start setenv serverip 192.168.1.209 setenv ipaddr 192.168.1.170 tftp ${kernel_addr_r} vmlinuz-4.19.17-sunxi tftp ${fdt_addr_r} ${fdtfile} setenv bootargs earlyprintk console=ttyS0,115200 ip=dhcp rootwait nolock rw nfsroot=192.168.1.209:/nfsboot/ubuntu/,v3 root=/dev/nfs rootdelay=7 bootz ${kernel_addr_r} - ${fdt_addr_r} Is there a way to 'saveenv' directly to the SPI flash or do I need to modify u-boot with my settings before compiling? Link to comment Share on other sites More sharing options...
Dmahony Posted February 2, 2019 Share Posted February 2, 2019 For anyone else who is stuck, I had lots of issues because my TFTP server was on a different server to where DHCP is served from, I think U-boot expects the TFTP to come from the same source as DHCP server with the default settings. here is my boot.scr.uimg: setenv fdtfile sun8i-h2-plus-orangepi-zero.dtb setenv serverip 192.168.1.209 setenv ipaddr 192.168.1.170 tftp ${kernel_addr_r} vmlinuz-4.19.17-sunxi tftp ${fdt_addr_r} ${fdtfile} tftp ${ramdisk_addr_r} uInitrd usb start setenv bootargs earlyprintk console=ttyS0,115200 ip=dhcp rootwait nolock rw nfsroot=192.168.1.209:/nfsboot/ubuntu/,v3 root=/dev/nfs rootdelay=7 bootz ${kernel_addr_r} - ${fdt_addr_r} ${ramdisk_addr_r} and my /etc/export (NFS shares) # /etc/exports: the access control list for filesystems which may be exported # to NFS clients. See exports(5). # # Example for NFSv2 and NFSv3: # /srv/homes hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check) # # Example for NFSv4: # /srv/nfs4 gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check) # /srv/nfs4/homes gss/krb5i(rw,sync,no_subtree_check) # /nfsboot 192.168.*(rw,sync,no_root_squash,no_subtree_check) /nfsboot/ubuntu 192.168.*(rw,sync,no_root_squash,no_subtree_check) # Link to comment Share on other sites More sharing options...
zux Posted February 3, 2019 Share Posted February 3, 2019 Quote I had lots of issues because my TFTP server was on a different server to where DHCP is served from, I think U-boot expects the TFTP to come from the same source as DHCP server with the default settings. Dude option tftp-server-name "a.b.c.d"; // option 66 from RFC life hack option host-name = concat("node", concat ( suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,1,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,2,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,3,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,4,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,5,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,6,1))),2) )); will do hostname like node+MAC option root-path = concat("192.168.11.130:/mnt/main/arms_hdd/", concat ( suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,1,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,2,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,3,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,4,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,5,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,6,1))),2) )); mount dir is "MAC" but need use ${nfs_root} int boot.cmd Link to comment Share on other sites More sharing options...
zux Posted February 3, 2019 Share Posted February 3, 2019 ahh sorry, sure thats params just for dhcpd.conf example subnet 10.100.100.0 netmask 255.255.255.0 { range 10.100.100.10 10.100.100.200; option routers 10.100.100.1; option broadcast-address 10.100.100.255; option domain-name-servers 192.168.11.1; option domain-name "cluster"; option host-name = concat("node", concat ( suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,1,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,2,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,3,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,4,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,5,1))),2), "", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,6,1))),2) )); option subnet-mask 255.255.255.0; option root-path = concat("192.168.11.5:/mnt/main/arms_hdd/", concat ( suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,1,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,2,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,3,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,4,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,5,1))),2), ":", suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,6,1))),2) )); default-lease-time 604800; max-lease-time 604800; } Link to comment Share on other sites More sharing options...
zux Posted February 3, 2019 Share Posted February 3, 2019 1 Link to comment Share on other sites More sharing options...
