tty1337 Posted December 23, 2017 Share Posted December 23, 2017 (edited) Hello, I want to use for my domotic a USB Everspring sa413 (Z-Wave modem based on ZM5304), but this device is not detected on Armbian with my Orange Pi Zero h2+. https://fccid.io/D87-ZM5304-U/User-Manual/User-Manual-pdf-2052478 Normally, I think this dongle is use like CDC/ACM device but I don't understand what wrong because ACM module is loaded. I use actually Debian Jessie next 4.13016. root@orangepizero:~# lsusb -t /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M No ttyAMA0 on my dev root@orangepizero:~# lsmod Module Size Used by sun8i_codec_analog 24576 0 xradio_wlan 94208 1 snd_soc_core 118784 1 sun8i_codec_analog snd_pcm_dmaengine 16384 1 snd_soc_core mac80211 450560 1 xradio_wlan snd_pcm 69632 2 snd_pcm_dmaengine,snd_soc_core snd_timer 24576 1 snd_pcm snd 45056 3 snd_timer,snd_soc_core,snd_pcm cfg80211 376832 2 mac80211,xradio_wlan soundcore 16384 1 snd sun4i_gpadc_iio 16384 0 rfkill 20480 2 cfg80211 uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm g_serial 16384 0 libcomposite 40960 2 g_serial,usb_f_acm fuse 73728 1 pwrseq_simple 16384 1 dmseg : https://ufile.io/0u7n8 (Nothing happen) When I plug a usb storage, all work, so no problem from hardware. root@orangepizero:~# lsusb -t ..... /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M ..... Test from other Linux (no ARMBIAN ), this USB device is detected : Spoiler ================================================================= Bus 005 Device 002: ID 0658:0200 Sigma Designs, Inc. Couldn't open device, some information will be missing Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 2 Communications bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x0658 Sigma Designs, Inc. idProduct 0x0200 bcdDevice 0.00 iManufacturer 0 iProduct 0 iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 67 bNumInterfaces 2 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 2 Abstract (modem) bInterfaceProtocol 1 AT-commands (v.25ter) iInterface 0 CDC Header: bcdCDC 1.10 CDC Call Management: bmCapabilities 0x00 bDataInterface 1 CDC ACM: bmCapabilities 0x00 CDC Union: bMasterInterface 0 bSlaveInterface 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0008 1x 8 bytes bInterval 32 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 Unused bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 ================================================================= [69703.532786] usb 8-4: USB disconnect, device number 3 [69716.392096] usb 5-2: new full-speed USB device number 2 using uhci_hcd [69716.570111] usb 5-2: New USB device found, idVendor=0658, idProduct=0200 [69716.570118] usb 5-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [69716.598156] cdc_acm 5-2:1.0: ttyACM0: USB ACM device [69716.600234] usbcore: registered new interface driver cdc_acm [69716.600236] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters ================================================================= Thank a lot for your help. OPI_Deb_next_dmesg Edited February 16, 2018 by tty1337 Solved Link to comment Share on other sites More sharing options...
martinayotte Posted December 23, 2017 Share Posted December 23, 2017 5 hours ago, tty1337 said: [69716.598156] cdc_acm 5-2:1.0: ttyACM0: USB ACM device This means the device appears as /dev/ttyACM0 ... Link to comment Share on other sites More sharing options...
tty1337 Posted December 24, 2017 Author Share Posted December 24, 2017 It's extract form another Linux. On my armbian nothing appen. Link to comment Share on other sites More sharing options...
martinayotte Posted December 24, 2017 Share Posted December 24, 2017 Ah ! Ok ! In my case, I have a Z-Wave USB on OPiPC and it is showing properly on /dev/ttyACM0. Bus 007 Device 002: ID 0658:0200 Sigma Designs, Inc. Link to comment Share on other sites More sharing options...
tty1337 Posted December 24, 2017 Author Share Posted December 24, 2017 What version of armbian and active module have you ? Link to comment Share on other sites More sharing options...
tty1337 Posted February 1, 2018 Author Share Posted February 1, 2018 Person has an idea ? I've try with one Orange PI PC2, same problem Link to comment Share on other sites More sharing options...
tty1337 Posted February 1, 2018 Author Share Posted February 1, 2018 I've find topic with exacly the same problem but not really explication (maybe kernel update is the cause) The guy use ARMBIAN 5.25 the dongle work and after upgrade to ARMBIAN 5.36 the dongle is not detect. I'll try with the oldest version for Orange Pi Zero (Armbian 5.30). Link to comment Share on other sites More sharing options...
tty1337 Posted February 16, 2018 Author Share Posted February 16, 2018 This issue is solved, finally the dongle doesnt work on small device (OrangePi &Raspberry) but work on my laptop, so after changed with new key, that work perfectly now on all devices. Thank you Link to comment Share on other sites More sharing options...
