thanh_tan Posted March 11, 2018 Share Posted March 11, 2018 since opi one plus use 26 pins gpio, anyone know the map of gpio i need to use i2s sound card on it Link to comment Share on other sites More sharing options...
chwe Posted March 11, 2018 Share Posted March 11, 2018 35 minutes ago, thanh_tan said: anyone know the map of gpio i need to use i2s sound card on it there're schematics released on their website. http://www.orangepi.org/downloadresources/orangepioneplus/2018-01-02/orangepioneplus25bbae76ae50e20b46b70.html links to a baidu/mega page where you find schematics too.... Link to comment Share on other sites More sharing options...
tkaiser Posted March 12, 2018 Share Posted March 12, 2018 17 hours ago, chwe said: on their website If it's an Allwinner device better look into linux-sunxi wiki first (and if someone finds stuff somewhere else please upload the documents where they belong to): http://linux-sunxi.org/Orange_Pi_One_Plus#See_also Link to comment Share on other sites More sharing options...
sagt3k Posted March 24, 2018 Share Posted March 24, 2018 Hi, I need help to configure PINs of Orange PI One Plus with H6. I'm using official distribution Ubuntu 16.04. I view in /sys/class/gpio_sw only: PD6 PL4 PL7 normal_led standby_led but I need PC9 and others pins. Can You help me ? Thanks Antonio Link to comment Share on other sites More sharing options...
Werner Posted May 4, 2018 Share Posted May 4, 2018 On 2/1/2018 at 1:03 AM, chwe said: Hoped to find something like voltage monitoring (on input) but as far as I understand the manual of the AXP805, there is no such possibility. Would it make a goods beginners board (as soon as kernel is 'in a good shape') cause it would avoid 'powering gone wrong'... - anyway, every barrel plug powered board is a bit more beginners friendly.. I don't follow sunxi mailing list fully (mostly cause I wouldn't understand most of the things discussed there.. ), but as I saw for the A64s PMIC was a bit problematic (handled by AR100, whereas complier for it is not GPL). As I understand, this issue was solved with those commits. Is the H6 also affected by such problems? (Allwinner had PMIC since a long time on the AR100 but it was possible to avoid using it). More experienced users have to decide if it's worth to use this kernel... But nice to see that allwinner publishes this stuff faster than in the past. btw. for those interested in it: https://github.com/Allwinner-Homlet?tab=repositories there you go. I tried to compile a kernel from these 4.9 sources for the One Plus but it runs into kernel panic after boot so obviously I messed up. Someone here that was smart enough to compile a working kernel image and would not mind to share the success? Cheers Werner Link to comment Share on other sites More sharing options...
dolphs Posted March 12, 2019 Share Posted March 12, 2019 moved to this section Link to comment Share on other sites More sharing options...
gounthar Posted January 12, 2020 Share Posted January 12, 2020 @jeromescuggs: do you think it could be possible to write dotfiles so that anyone can install your configuration? Link to comment Share on other sites More sharing options...
Abdullah Posted February 16, 2020 Share Posted February 16, 2020 Is the board beginner friendly yet? For running web server / ad blocking dns service. Link to comment Share on other sites More sharing options...
Werner Posted February 16, 2020 Share Posted February 16, 2020 5 hours ago, Abdullah said: Is the board beginner friendly yet? For running web server / ad blocking dns service. Headless it is perfectly fine in my opinion. No idea about HDMI output though. Keep in mind that the CPU is capped to 1,5GHz for stability reasons. Older images offering the full 1.8 GHz did not work properly for some people. Link to comment Share on other sites More sharing options...
