Next not installing on orange pi plus 2e
HungryHippo
I'm pretty new to Linux, so it could just be me doing something wrong, but I downloaded Armbian_5.34.171121_Orangepiplus2e_Ubuntu_xenial_next_4.13.14_desktop.img, put it on an SD card, and load it in the orange pi. The legacy installs fine but not this version.
Before I even make it to the login prompt I get these codec errors:
sun4i-codec 1c22c00.codec: ASoC: /soc/codec/analog@01f015c0 not registered
sun4i-codec 1c22c00.codec: Failed to register our card
Then after filling out the login info, adding a new user, it goes to boot to the desktop, but nothing happens, just returns me to the command line.
After some mucking around, and using ntmui or whatever it was to get my ethernet working, I updated to see if that might fix anything. Unsurprisingly it didn't. Then I tried to start the desktop manually running startxfce4 and found another error which I'm guessing is why the desktop won't start, apparently a missing video driver?
gbm: failed to pen any driver (search paths /usr/lib/arm-linux-gnueabihf/dri:${ORIGIN}/dri:/uselib/dri)
gbm: Last dlopen error: /usr/lib/dri/sun4i-drm-dri.so: cannot open shard object file: No such file or directory failted to load driver: sun41-drm
EGL_MESA_drm_image required.
(EE_
Fatal server error:
(EE) AddScreen/ScreenInit failed for driver 0
I'll keep mucking around and see if I can fix it.
Then better stay away from images made only for developers/testing and use stable builds. Automated nightly builds are made from the latest development sources and are not tested. Sometimes do work, sometimes don't.
I'm getting the same error on my Orange Pi PC 2.  Everything else is very stable.  Using the latest nightly build.
| Orange Pi PC2 | 5.38.180128 | arm64 | aarch64 | 4.14.15-sunxi64
BOARD=orangepipc2
BOARD_NAME="Orange Pi PC2"
BOARDFAMILY=sun50iw2
VERSION=5.38.180128
LINUXFAMILY=sunxi64
BRANCH=next
ARCH=arm64
IMAGE_TYPE=nightly
BOARD_TYPE=conf
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Imag
[   11.537413] thermal thermal_zone0: failed to read out thermal zone (-110)
[   11.642541] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
[   11.655683] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[   11.663873] sun4i-codec 1c22c00.codec: Failed to register our card
[   11.699451] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[   11.837283] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
I'm getting this too, not just on the nightly build, also on the supported "light desktop usage scenario" Armbian Stretch and Armbian Xenial mainline images here. Only Armbian Xenial desktop legacy kernel 3.4.y has a working desktop for me when connected to HDMI.
Headless, as well as just a text-only terminal on the monitor, everything works like a charm.
/var/log/Xorg.0.log suggets it at least does detect the monitor, but for some raison bails out with AddScreen/ScreenInit failed for driver 0
[   467.283]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[   467.316] X Protocol Version 11, Revision 0
[   467.327] Build Operating System: Linux 4.4.0-119-generic armv7l Ubuntu
[   467.338] Current Operating System: Linux orangepiplus2e 4.14.50-sunxi #6 SMP Mon Jun 18 14:09:47 UTC 2018 armv7l
[   467.338] Kernel command line: root=UUID=907d1c62-bd37-4d65-9619-b9e8abe22a16 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=3526c152-01 ubootsource=mmc usb-storage.quirks=   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[   467.363] Build Date: 13 April 2018  08:09:42PM
[   467.375] xorg-server 2:1.19.6-1ubuntu4 (For technical support please see http://www.ubuntu.com/support)
[   467.388] Current version of pixman: 0.34.0
[   467.413] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   467.414] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   467.465] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 18 14:35:15 2018
[   467.479] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   467.492] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   467.493] (==) No Layout section.  Using the first Screen section.
[   467.493] (==) No screen section available. Using defaults.
[   467.493] (**) |-->Screen "Default Screen Section" (0)
[   467.493] (**) |   |-->Monitor "<default monitor>"
[   467.494] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[   467.494] (**) Option "BlankTime" "0"
[   467.494] (**) Option "StandbyTime" "0"
[   467.494] (**) Option "SuspendTime" "0"
[   467.494] (**) Option "OffTime" "0"
[   467.494] (==) Automatically adding devices
[   467.494] (==) Automatically enabling devices
[   467.494] (==) Automatically adding GPU devices
[   467.494] (==) Automatically binding GPU devices
[   467.494] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   467.495] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   467.495] 	Entry deleted from font path.
[   467.495] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   467.495] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   467.495] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   467.495] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   467.495] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   467.495] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	built-ins
[   467.495] (==) ModulePath set to "/usr/lib/xorg/modules"
[   467.495] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[   467.495] (II) Loader magic: 0x64c008
[   467.495] (II) Module ABI versions:
[   467.495] 	X.Org ANSI C Emulation: 0.4
[   467.495] 	X.Org Video Driver: 23.0
[   467.495] 	X.Org XInput driver : 24.1
[   467.495] 	X.Org Server Extension : 10.0
[   467.497] (--) using VT number 3
[   467.497] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   467.499] (II) xfree86: Adding drm device (/dev/dri/card0)
[   467.518] (II) no primary bus or device found
[   467.518] 	falling back to /sys/devices/platform/display-engine/drm/card0
[   467.518] (II) LoadModule: "glx"
[   467.518] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   467.523] (II) Module glx: vendor="X.Org Foundation"
[   467.523] 	compiled for 1.19.6, module version = 1.0.0
[   467.523] 	ABI class: X.Org Server Extension, version 10.0
[   467.523] (==) Matched modesetting as autoconfigured driver 0
[   467.523] (==) Matched fbdev as autoconfigured driver 1
[   467.523] (==) Assigned the driver to the xf86ConfigLayout
[   467.523] (II) LoadModule: "modesetting"
[   467.523] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   467.524] (II) Module modesetting: vendor="X.Org Foundation"
[   467.524] 	compiled for 1.19.6, module version = 1.19.6
[   467.524] 	Module class: X.Org Video Driver
[   467.524] 	ABI class: X.Org Video Driver, version 23.0
[   467.524] (II) LoadModule: "fbdev"
[   467.524] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   467.525] (II) Module fbdev: vendor="X.Org Foundation"
[   467.525] 	compiled for 1.19.3, module version = 0.4.4
[   467.525] 	Module class: X.Org Video Driver
[   467.525] 	ABI class: X.Org Video Driver, version 23.0
[   467.525] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   467.525] (II) FBDEV: driver for framebuffer: fbdev
[   467.684] (II) modeset(0): using drv /dev/dri/card0
[   467.684] (WW) Falling back to old probe method for fbdev
[   467.685] (II) Loading sub module "fbdevhw"
[   467.685] (II) LoadModule: "fbdevhw"
[   467.685] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   467.685] (II) Module fbdevhw: vendor="X.Org Foundation"
[   467.685] 	compiled for 1.19.6, module version = 0.0.2
[   467.686] 	ABI class: X.Org Video Driver, version 23.0
[   467.686] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   467.686] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[   467.686] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[   467.687] (==) modeset(0): RGB weight 888
[   467.687] (==) modeset(0): Default visual is TrueColor
[   467.687] (II) Loading sub module "glamoregl"
[   467.687] (II) LoadModule: "glamoregl"
[   467.687] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[   467.705] (II) Module glamoregl: vendor="X.Org Foundation"
[   467.705] 	compiled for 1.19.6, module version = 1.0.0
[   467.705] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   467.705] (II) glamor: OpenGL accelerated X.org driver based.
[   467.833] (II) glamor: EGL version 1.4 (DRI2):
[   467.834] EGL_MESA_drm_image required.
[   467.836] (EE) modeset(0): glamor initialization failed
[   467.836] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[   468.052] (II) modeset(0): Output HDMI-1 has no monitor section
[   468.266] (II) modeset(0): EDID for output HDMI-1
[   468.266] (II) modeset(0): Manufacturer: SAM  Model: b81  Serial#: 808663346
[   468.266] (II) modeset(0): Year: 2014  Week: 32
[   468.266] (II) modeset(0): EDID Version: 1.3
[   468.266] (II) modeset(0): Digital Display Input
[   468.266] (II) modeset(0): Max Image Size [cm]: horiz.: 61  vert.: 35
[   468.266] (II) modeset(0): Gamma: 2.20
[   468.266] (II) modeset(0): DPMS capabilities: Off
[   468.266] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   468.266] (II) modeset(0): First detailed timing is preferred mode
[   468.266] (II) modeset(0): redX: 0.634 redY: 0.341   greenX: 0.312 greenY: 0.636
[   468.266] (II) modeset(0): blueX: 0.158 blueY: 0.062   whiteX: 0.312 whiteY: 0.329
[   468.266] (II) modeset(0): Supported established timings:
[   468.266] (II) modeset(0): 720x400@70Hz
[   468.266] (II) modeset(0): 640x480@60Hz
[   468.266] (II) modeset(0): 640x480@67Hz
[   468.266] (II) modeset(0): 640x480@72Hz
[   468.266] (II) modeset(0): 640x480@75Hz
[   468.266] (II) modeset(0): 800x600@56Hz
[   468.266] (II) modeset(0): 800x600@60Hz
[   468.266] (II) modeset(0): 800x600@72Hz
[   468.266] (II) modeset(0): 800x600@75Hz
[   468.266] (II) modeset(0): 832x624@75Hz
[   468.267] (II) modeset(0): 1024x768@60Hz
[   468.267] (II) modeset(0): 1024x768@70Hz
[   468.267] (II) modeset(0): 1024x768@75Hz
[   468.267] (II) modeset(0): 1280x1024@75Hz
[   468.267] (II) modeset(0): 1152x864@75Hz
[   468.267] (II) modeset(0): Manufacturer's mask: 0
[   468.267] (II) modeset(0): Supported standard timings:
[   468.267] (II) modeset(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[   468.267] (II) modeset(0): #1: hsize: 1280  vsize 800  refresh: 60  vid: 129
[   468.267] (II) modeset(0): #2: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[   468.267] (II) modeset(0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[   468.267] (II) modeset(0): #4: hsize: 1440  vsize 900  refresh: 60  vid: 149
[   468.267] (II) modeset(0): #5: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[   468.267] (II) modeset(0): #6: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[   468.267] (II) modeset(0): Supported detailed timing:
[   468.267] (II) modeset(0): clock: 297.0 MHz   Image Size:  608 x 345 mm
[   468.267] (II) modeset(0): h_active: 3840  h_sync: 4016  h_sync_end 4104 h_blank_end 4400 h_border: 0
[   468.267] (II) modeset(0): v_active: 2160  v_sync: 2168  v_sync_end 2178 v_blanking: 2250 v_border: 0
[   468.267] (II) modeset(0): Ranges: V min: 24 V max: 75 Hz, H min: 30 H max: 90 kHz, PixClock max 305 MHz
[   468.267] (II) modeset(0): Monitor name: U28D590
[   468.267] (II) modeset(0): Serial No: H4MF800857
[   468.267] (II) modeset(0): clock: 148.5 MHz   Image Size:  608 x 345 mm
[   468.267] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[   468.267] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   468.268] (II) modeset(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[   468.268] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   468.268] (II) modeset(0): Supported detailed timing:
[   468.268] (II) modeset(0): clock: 74.2 MHz   Image Size:  608 x 345 mm
[   468.268] (II) modeset(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[   468.268] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[   468.268] (II) modeset(0): clock: 241.5 MHz   Image Size:  608 x 345 mm
[   468.268] (II) modeset(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[   468.268] (II) modeset(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[   468.268] (II) modeset(0): Number of EDID sections to follow: 1
[   468.268] (II) modeset(0): EDID (in hex):
[   468.268] (II) modeset(0): 	00ffffffffffff004c2d810b32393330
[   468.268] (II) modeset(0): 	20180103803d23782a5fb1a2574fa228
[   468.268] (II) modeset(0): 	0f5054bfef80714f810081c081809500
[   468.268] (II) modeset(0): 	a9c0b300010104740030f2705a80b058
[   468.268] (II) modeset(0): 	8a0060592100001e000000fd00184b1e
[   468.268] (II) modeset(0): 	5a1e000a202020202020000000fc0055
[   468.268] (II) modeset(0): 	3238443539300a2020202020000000ff
[   468.268] (II) modeset(0): 	0048344d463830303835370a20200132
[   468.268] (II) modeset(0): 	020323f14890041f1303122022230907
[   468.268] (II) modeset(0): 	07830100006d030c002000803c201060
[   468.268] (II) modeset(0): 	010203023a801871382d40582c450060
[   468.268] (II) modeset(0): 	592100001e023a80d072382d40102c45
[   468.268] (II) modeset(0): 	8060592100001e011d007251d01e206e
[   468.269] (II) modeset(0): 	28550060592100001e565e00a0a0a029
[   468.269] (II) modeset(0): 	503020350060592100001a0000000000
[   468.269] (II) modeset(0): 	00000000000000000000000000000037
[   468.269] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[   468.269] (II) modeset(0): Printing probed modes for output HDMI-1
[   468.269] (II) modeset(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[   468.269] (II) modeset(0): Modeline "3840x2160"x25.0  297.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[   468.269] (II) modeset(0): Modeline "3840x2160"x24.0  297.00  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[   468.269] (II) modeset(0): Modeline "3840x2160"x30.0  296.70  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[   468.269] (II) modeset(0): Modeline "3840x2160"x24.0  296.70  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[   468.269] (II) modeset(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[   468.269] (II) modeset(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[   468.270] (II) modeset(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[   468.270] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[   468.270] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   468.270] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   468.270] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   468.270] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   468.270] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   468.270] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   468.270] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   468.270] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   468.270] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   468.270] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   468.270] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   468.270] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   468.270] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   468.271] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   468.271] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   468.271] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   468.271] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   468.271] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   468.271] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   468.271] (II) modeset(0): Output HDMI-1 connected
[   468.271] (II) modeset(0): Using exact sizes for initial modes
[   468.271] (II) modeset(0): Output HDMI-1 using initial mode 3840x2160 +0+0
[   468.271] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[   468.271] (==) modeset(0): DPI set to (96, 96)
[   468.271] (II) Loading sub module "fb"
[   468.271] (II) LoadModule: "fb"
[   468.271] (II) Loading /usr/lib/xorg/modules/libfb.so
[   468.272] (II) Module fb: vendor="X.Org Foundation"
[   468.272] 	compiled for 1.19.6, module version = 1.0.0
[   468.272] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   468.272] (II) UnloadModule: "fbdev"
[   468.272] (II) Unloading fbdev
[   468.273] (II) UnloadSubModule: "fbdevhw"
[   468.273] (II) Unloading fbdevhw
[   468.273] (==) Depth 24 pixmap format is 32 bpp
[   468.273] (EE)
Fatal server error:
[   468.273] (EE) AddScreen/ScreenInit failed for driver 0
[   468.273] (EE)
[   468.274] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   468.274] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   468.274] (EE)
[   468.502] (EE) Server terminated with error (1). Closing log file.
Edited by Sjors Provoost
