Banana Pi: unbootable after dist-upgrade
mk16
Hello,
First of all thanks for the very nice dist, it's clean and optimized.
Unfortunately the Banana Pi is unbootable after having done the following:
  • Migrate the root fs to my USB drive and make it bootable with the nand-sata-install  script
  • Change the hostname (modify /etc/hosts, modify /etc/hostname, run /etc/init.d/hostname.sh, reboot)
  • run apt-get update && apt-get dist-upgrade, reboot
Each time the Banana Pi could not boot anymore, and that happened with both Jessie and Wheezie images.
I can't get any screenshots of the boot screen because it's a headless server.
Any ideas?
mk16
I've used those two vanilla images, v4.5 indeed:
 Wheezy & Jessie
When I did a dist-upgrade, the kernel was updated from 4.2.3 to 4.3.3, here's the /boot dir after the upgrade:
root@bananapi:/boot# ls -al
total 7572
drwxr-xr-x  5 root root    4096 Jan 19 21:31 .
drwxr-xr-x 22 root root    4096 Jan 19 21:12 ..
drwxr-xr-x  2 root root    4096 Jan 19 21:28 bin
-rw-r--r--  1 root root    6944 Oct 11 19:10 boot.bmp
-rw-r--r--  1 root root    1896 Jan 19 21:17 boot.cmd
-rw-r--r--  1 root root    1968 Jan 19 21:33 boot.scr
-rw-r--r--  1 root root  122375 Dec 28 11:27 config-4.3.3-sunxi
drwxr-xr-x  2 root root   12288 Jan 19 21:26 dtb
drwxr-xr-x  2 root root    4096 Dec 28 11:27 dtb.old
-rw-r--r--  1 root root       0 Jan 19 21:29 .next
lrwxrwxrwx  1 root root      22 Oct 11 19:11 script.bin -> /boot/bin/bananapi.bin
-rw-r--r--  1 root root 1988477 Dec 28 11:27 System.map-4.3.3-sunxi
-rwxr-xr-x  1 root root 5591872 Dec 28 11:27 vmlinuz-4.3.3-sunxi
lrwxrwxrwx  1 root root      19 Jan 19 21:29 zImage -> vmlinuz-4.3.3-sunxi
Should I pin the kernel packages to the 4.2.3 version for the time being?
I'm planning in the near future to boot from SATA, I suppose I won't be affected by the issue then?
Thanks for the quick answers btw :)
Great! I don't recall precisely the command, is it debuild? For now I've exluded the following packages from upgrade:
hi  linux-dtb-next-sunxi            4.5                               armhf        Linux DTB, version 4.2.3-sunxi
hi  linux-firmware-image-next-sunxi 4.5                               armhf        Linux kernel firmware, version 4.2.3-sunxi
hi  linux-headers-next-sunxi        4.5                               armhf        Linux kernel headers for 4.2.3-sunxi on armhf
hi  linux-image-next-sunxi          4.5                               armhf        Linux kernel, version 4.2.3-sunxi
hi  linux-wheezy-root-next-bananapi 4.5                               armhf        Various root file system tweaks for ARM boards
Should I compile only the image package?
Edited by mk16
