Roberto Assiro Posted January 26, 2018 Share Posted January 26, 2018 Hi all, on orange pi zero plus with allwinner H5 I have problem to install python library pyA20 to controll gpio. On H2 it was easy to do this. Same suggestions? Thanks in advance Link to comment Share on other sites More sharing options...
Larry Bank Posted January 26, 2018 Share Posted January 26, 2018 Are you willing to give ArmbianIO a try? It has C, Java and Python bindings and should work fine on your board. I'm not sure if your board name is in the list of supported boards, but you can pass it the name of the Orange Pi Zero (which should have the same gpio mapping). https://github.com/bitbank2/ArmbianIO Link to comment Share on other sites More sharing options...
