Problems with 5.38 update
nihilista
I should have known better..... today i did an apt update and saw thet there was an update to 5.38. Installed it and like with nearly every last update the device (OrangePi +) didn't boot.
Did you even test updates in the stable repo before ? Don't know whats going wrong, so i will test it, but thats annoying.....
whats special on the OPi+ and OPi2e?
From the CPU they  a normal H3-Boards
All my Boards did boot after the 5.38 update
- NPi Neo2
- NPi Duo
- NPi Neo Core2
- OPi Zero
- OPi Zero Plus H5
- OPi One (legacy)  /  another - newly with mainline installed  - OPi One is also working fine with 5.38
Is it a legacy/stable <--> mainline/nightly problem?
My devices are using mostly mainline (nightly)
OPi plus (if he means that by OPi+) & plus 2e have eMMC... but without more information, it's hard to say what's wrong...
My OPI PC+ (server usecase so with mainline instead of legacy kernel runs smoothly on 5.38). I can't switch to legacy only to reproduce errors of others...
Spoiler
  ___                               ____  _   ____   ____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |  _ \ / ___|    _
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | |_) | |      _| |_
| |_| | | | (_| | | | | (_| |  __/ |  __/| | |  __/| |___  |_   _|
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|    \____|   |_|
                       |___/
Welcome to ARMBIAN 5.38.180128 nightly Debian GNU/Linux 9 (stretch) 4.14.15-sunx
Edited by chwe
didn't even know the OPi+
58 minutes ago, chwe said:
PC plus (if he means that by OPi+) & plus 2e have eMMC... but without more information, it's hard to say what's wrong...
I think as OPi+ he means the https://www.armbian.com/orange-pi-plus/
The only "pi" with eMMC at my side is the NPi Neo Core2, but also with mainline (image of the NPi Neo Plus2 is working here with eMMC-support, but Iam running this from uSD).
My OPi One is using legacy kernel (as Pi-Hole Server) but hasnt a eMMC.
It´s working here :)
EDIT: (God damn it, didn't see that it was the real Opi+ he is talking about, forgot about that one since the image for the opi+2 says opi+, sorry, nothing to see here )
Edited by DEHN.IO
Going to bed
In my case - both Orange Pi+ 2 and Orange Pi+ 2e are using emmc. Currently I am not able to provide any output from serial as I have no physical access to my devices (btw. I do not have serial/usb cable to investigate it :().
Information (common for both devices, also the same for 2 devices which have no issues: Orange Pi PC and Orange Pi Zero 512MB H2+):
- upgrade from 5.35 to 5.36 was OK
- upgrade from 5.36 to 5.37 was OK (I have seen this upgrade was very minor, only 1 package has been updated)
- upgrade from 5.37 to 5.38 failed for Opi+2 and Opi+2e (actually I am able to confirm for 100% that I am not able to connect to devices and I am 100% sure that this is not an issue related to e.g. different hwaddres, IP etc.) - either device hasn't booted at all or network interfaces are down (this one can be confirmed by anybody who can check by serial interface)
- upgrade from 5.37 to 5.38 was OK for OpiPC and OpiZero
- there ware no issues during upgrade process - it was completed without any warnings/errors.
- Opi+2 and Opi+2e are using eMMC as main boot device
- OpiPC and OpiZero are using SD cards as main boot device (obviously)
- All 4 platforms are running with legacy kernel
I will have physical access to both devices on Friday, 02.02.2018. I have "tool" SD card which will allow me to boot both devices and if there is any suggestion from this forum - I will be able to make necessary corrections (eg. "dd" new file to emmc boot sectors etc.).
Ok I can confirm that my
Orange PI Plus 2 upgrade from Headless Ubuntu 5.36to 5.38 (Stable) worked without problems.
Orange PI Plus 2E upgrade from Headless Ubuntu 5.37 (nightly) to 5.38 (nightly) worked without problems.
So looks like the legacy images are the problem :/
I made two additional upgrade tests with a legacy kernel, Orangepi PC+ and Orangepi 2e and it was not possible to detect any problemshttp://ix.io/EWl
- some old version which was on eMMC -> latest
- 5.35 from download -> latest
- some old beta -> latest
We can't test all possible boards/combinations.
1 minute ago, earth08 said:
I have same problem after i updated today,
Till now no success to get it work
I M using oPi+2e
Sent from my AO5510 using Tapatalk
Unless someone, who has this problem, does not provide serial console logs, we will not get anywhere.
I can't reproduce it.
So, I have OrangePi plus 2e which boots mainline kernel from eMMC, and have MMC card as data volume.
I just did apt update, apt upgrade and could'nt  boot system anymore.
Fortunatelly I have backup image, but anyway... What goes wrong ?!?
19 minutes ago, flags8192 said:
Here is the console log: https://pastebin.com/i9FsCHqt
Looks like u-boot MMC numbering changes broke backwards compatibility with our old boot script (that had "mmc 0" hardcoded everywhere, pre-23-08-2017), now the question is which images are affected.
@Igor
I would recommend removing new u-boot packages from the repository for all sunxi devices that have eMMC. Or simply for all sunxi devices since I'm not sure if other old (something like pre-5.30) images will be affected.
40 minutes ago, IgorS said:
But this update was ok on OPi one.
OPi One hasnt a eMMC device
  ___                               ____  _    ___
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_)  / _ \ _ __   ___
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | '_ \ / _ \
| |_| | | | (_| | | | | (_| |  __/ |  __/| | | |_| | | | |  __/
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_|  \___/|_| |_|\___|
                       |___/
Welcome to ARMBIAN 5.38 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i
Linux pihole 3.4.113-sun8i #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 armv7l armv7l armv7l GNU/Linux
root@pihole:~# ls /dev/mmc*
/dev/mmcblk0  /dev/mmcblk0p1
Because I needed instant solution, I switched sytem to mmc and data volume to emmc
That's correct in your case because u have backup,
What if we don't have backup and want our system back online
Well, I think you can do following:
Get mmc card
Put fresh armbian on it
Boot from it
Make tar of /mmcblk2p1 (somewhere on network, I use sshfs for this)
Shutdown
Get mmc on pc an delete everything on it, then utar content of mmcblk2p1 on it.
It should work (worked for me)
Rgds
Get mmc card
Boot from it
Shutdown
Rgds
I just needed to adjust UUIDS in fstab
Get mmc card
Boot from it
Shutdown
Rgds
Dear,
I don't get when u say make tar of.
Can u please explain?
Thanks in adv.
When you boot in 'fresh' armbian from mmc, your old system is still on emmc, just need way to get it out.
Easiest way is to make tar archive from it, maybe on usb pendrive.
Insert pendrive, let say it is /dev/sda (check with lsblk)
Create mountpoints:
mkdir /mnt/src
mkdir /mnt/dest
Mount pendrive:
mount /dev/sda /mnt/dest
Mount emmc partition:
mount /dev/mmcblk2p1 /mnt/src
cd /mnt/dest
tar -cvzf my_archive_name.tar.gz -C /mnt/src .
(Note dot at the end, is important)
when finished
cd /
umount /mnt/src
umount /mnt/dest
poweroff
On your pendrive is now content of the emmc
Then get both to pc and erase all on mmc
untar archive from pendrive to mmc
Bring to Opi and it should work
Create mountpoints:
mkdir /mnt/src
mkdir /mnt/dest
Mount pendrive:
cd /mnt/dest
when finished
cd /
umount /mnt/src
umount /mnt/dest
poweroff
All commands as root, of course
2 minutes ago, earth08 said:
Dear,
Thanks for explaining,
I will do that now,
Would it be possible to transfer same from mmc to emmc when fix is available?
Nope, bloody new U-Boot wan't boot from emmc. Until solution, we are trapped on mmc
Changed back https://github.com/armbian/upload/commit/c68b8c84f9edfdfd55f1579894f05035e637022a
And also Odroid XU4 upgrade to NEXT https://github.com/armbian/upload/commit/36437b8a9704a5056fccb6ed154b69778716bed8
At least upstream those problems should be fixed by now.
Sorry, I missunderstood you. Yes, when fix comes,  will be possible through armbian-config install to emmc.
