manuti Posted June 9, 2015 Share Posted June 9, 2015 I obtain an "Authentication token manipulation error" on Banana Pro Debian 3.0 jessie 4.0.4 when I try to change the rot password in the first run. Any help? Thanks Link to comment Share on other sites More sharing options...
Igor Posted June 9, 2015 Share Posted June 9, 2015 It's normal, only on Jessie. Wait that the system auto reboots once then you are able to login. Link to comment Share on other sites More sharing options...
manuti Posted June 10, 2015 Author Share Posted June 10, 2015 OK, I have an error: Failed to start LSB: Scritp to run when first starting. Any chance to solve this error? Thanks See an image of the error in this link Link to comment Share on other sites More sharing options...
Igor Posted June 10, 2015 Share Posted June 10, 2015 Jessie is problematic ... What you get if you type this after login: systemctl status firstrun.service I made a new build today (currently testing) ... and so far no errors. Link to comment Share on other sites More sharing options...
manuti Posted June 11, 2015 Author Share Posted June 11, 2015 Thanks, downloading new version and testing this evening CET. Bananapi_Debian_3.1_jessie_4.0.5.zip Link to comment Share on other sites More sharing options...
manuti Posted June 11, 2015 Author Share Posted June 11, 2015 Thanks a lot Igor. With Bananapi Debian 3.1 jessie 4.0.5. on a Banana PRO first run OK intrnal Wi-Fi - OK after copy in /boot/dtb/ the file sun7..bananapro.dtb over sun7...bananapi.dtb and reboot thanks 1 Link to comment Share on other sites More sharing options...
