Igor Posted January 8, 2016 Share Posted January 8, 2016 Yes, sure. Go ahead ... BTW: can you try to compile U-boot for Armada ... it's failing for me on two different machines and it's suppose to work. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 8, 2016 Share Posted January 8, 2016 Wily, GCC 4.9 - fails with __stack_chk_* errors - usually this means wrong compiler options (stack protector) Trusty in a container, fails with same error It fails in tools/marvell directory, and it seems like there is non-standart Makefile and linker... Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 8, 2016 Share Posted January 8, 2016 I fixed this error, now it fails with hard-float/soft-float (VFP) mismatch Compilation with recommended buildroot failed at kernel stage. Edit: this must be a soft-float arch device, isn't it? Edit 3: No, it's hard-float, but u-boot requires soft-float toolchain, probably due to old u-boot version or some changes to its source. Edit 2: Compiles OK for me with soft-float 4.9 toolchain Ext. headers = 1, Header size = 79360 bytes Hdr-to-Img gap = 0 bytes New image size = 0xd4b80[871296] Source image size = 0xd4b7c[871292] ====>>>> u-boot.mmc was created sudo make CROSS_COMPILE=arm-linux-gnueabi- u-boot.mmc 74,18s user 8,78s system 96% cpu 1:25,63 total Link to comment Share on other sites More sharing options...
Igor Posted January 8, 2016 Author Share Posted January 8, 2016 I compiled kernel with with Armbian script, no problem. ... also tried buildroot yesterday and also failed. So U-boot is compiling now, with soft float? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted January 8, 2016 Share Posted January 8, 2016 I didn't try kernel compilation since u-boot failure terminated script before that. I don't think that any device is designed to use soft-float u-boot with hard-float kernel, it's either this or that. Manual compilation is working, but it won't work in Armbian build script since you need to change "arm-linux-gnueabihf-" to "arm-linux-gnueabi-" in make parameter, and possibly compilation target and u-boot file name for packaging. Plus this patch is required. Edit: I'm referring to this page for make targets. 1 Link to comment Share on other sites More sharing options...
Igor Posted January 8, 2016 Author Share Posted January 8, 2016 Cool, it's working now. Thanks. I'll put compiler under variable and fix u-boot packaging. Link to comment Share on other sites More sharing options...
