FANTASTIC
jeyjey
I am a miner. I am building a OrangePi Zero plus cluster and Armbian is the more perfect OS distro I ever tested. I tryed all OrangePi images and other way of install. This is the best! Have you an idea if the Armbian images will implement the graphic Driver?
Graphics driver is here for some time, first a simple one, now DRM, but it is still under development. If you mean video acceleration, then its what @gnasch pointed out.
BTW. HDMI out is usually disabled on board that doesn't have it.
I am sorry for the description of what I am really search for. Armbian let me mine with these little cooky machines but only with CPU. To add the graphic cores to the mining jobs we must install OpenCl for Mali450, that is the GPU. The video streaming card is not important to mine cryptos. Did anyone make the discovered? As you know nobody is trying to mine with unprofitable SOCS. But if we will add the graph cores to the CPUs probably we can get something else. Many thanks!
