php Posted February 4, 2018 Share Posted February 4, 2018 I've been running 5.36 successfully on my espressobin. Saw the upgrade to 5.38, so ran apt-get update and upgrade. Now the boot process shows this log snippet: [ 6.251662] md: autorun ... [ 6.254188] md: ... autorun DONE. [ 6.258090] Waiting for root device /dev/mmcblk0p1... [ 6.267577] mmc1: new high speed SDHC card at address aaaa [ 6.273478] mmcblk1: mmc1:aaaa SL16G 14.8 GiB [ 6.279091] mmcblk1: p1 [ 201.869175] random: crng init done I've let it sit for a while after this (200 seconds in), but no more log lines. Any other espressobin users successfully running 5.38? Link to comment Share on other sites More sharing options...
umiddelb Posted February 4, 2018 Share Posted February 4, 2018 The device node for the SD card has changed from mmcblk0 to mmcblk1. You need to edit the file `/boot/armbianEnv.txt`. Either you change mmcblk0 to mmcblk1 there as well or you modify the `rootdev` variable to something like: rootdev=UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx where xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx has to be replaced by the UUID of /dev/mmcblk1p1. sudo blkid will tell you the right UUID. Link to comment Share on other sites More sharing options...
php Posted February 4, 2018 Author Share Posted February 4, 2018 Hi @umiddelb, thanks for your suggestion but I'm confused. In my log above, it's trying to boot from mmcblk1p1. My armbianEnv.txt file looks like this, already with the UUID of my microSD card (verified in Ubuntu) verbosity=1 emmc_fix=off eth1addr=00:50:43:25:fb:84 eth2addr=00:50:43:84:25:2f eth3addr=00:50:43:0d:19:18 rootdev=UUID=dc2768b6-c4f5-466e-83c1-6cf4aa49a898 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u For kicks I changed it to `rootdev=/dev/mmcblk1p1` but got the same result. Can you provide a reference to the change you mention? I looked at the commit history for boot-espressobin.cmd but it doesn't show recent changes. Link to comment Share on other sites More sharing options...
chrisf Posted February 5, 2018 Share Posted February 5, 2018 is your boot environment set up correctly? Maybe it has the boot arguments set to mmcblk0p1 instead of loading the the environment values from the config files? Link to comment Share on other sites More sharing options...
php Posted February 5, 2018 Author Share Posted February 5, 2018 Hi @chrisf, you're quite right, the uboot environment variables use /dev/mmcblk0p1. So for anyone else who has this problem, these instructions (for ubuntu, but still apply) show bootmmc and bootcmd, both of which need to be changed to /dev/mmcblk1p1 (but don't change anything else). Thanks for the tip! Link to comment Share on other sites More sharing options...
Igor Posted February 5, 2018 Share Posted February 5, 2018 Is this problem related to specific kernel, 4.4.y / 4.14.y? Link to comment Share on other sites More sharing options...
php Posted February 5, 2018 Author Share Posted February 5, 2018 25 minutes ago, Igor said: Is this problem related to specific kernel, 4.4.y / 4.14.y? I don't know what precipitated the change from mmcblk0 to mmcblk1, but after upgrading to armbian 5.38 I'm running kernel 4.14.14 Link to comment Share on other sites More sharing options...
Igor Posted February 5, 2018 Share Posted February 5, 2018 22 minutes ago, php said: I don't know what precipitated the change from mmcblk0 to mmcblk1, but after upgrading to armbian 5.38 I'm running kernel 4.14.14 eMMC support was recently added to this kernel and that could trigger this problem. Not sure ATM. When reporting a problem it saves time if people add their full logs, preferably with armbianmonitor -u .Sometimes a quick scan can already provide an answer. Link to comment Share on other sites More sharing options...
php Posted February 5, 2018 Author Share Posted February 5, 2018 10 hours ago, Igor said: eMMC support was recently added to this kernel and that could trigger this problem. Not sure ATM. When reporting a problem it saves time if people add their full logs, preferably with armbianmonitor -u .Sometimes a quick scan can already provide an answer. Thanks for that tip @Igor Is there any diagnostic value in gathering those logs even after I changed my boot args to get back up and running? I could revert the change to the boot args if helpful. 1 Link to comment Share on other sites More sharing options...
umiddelb Posted February 5, 2018 Share Posted February 5, 2018 You should be able to read and modify the stored custom u-boot environment since the -next kernel has built-in support for the M25P80 chip. To gain access, you need to pass some partitioning information to the kernel command line. You may check if the device files /dev/mtd[012] exists. Otherwise you need to add the following parameter to the command line: mtdparts=spi0.0:1536k(uboot),64k(uboot-environment),-(reserved) Then, after having rebooted, you need to install the `u-boot-tools´ package and modify `/etc/fw_env.config´ like this # device name device offset env. size flash sector size number of sectors /dev/mtd1 0x0 0x00010000 0x1000 0x10 Now you can make use of `fw_printenv´ and `fw_setenv´ to get userland access the u-boot environment. Link to comment Share on other sites More sharing options...
php Posted February 5, 2018 Author Share Posted February 5, 2018 42 minutes ago, umiddelb said: You should be able to read and modify the stored custom u-boot environment since the -next kernel has built-in support for the M25P80 chip. To gain access, you need to pass some partitioning information to the kernel command line. You may check if the device files /dev/mtd[012] exists. Otherwise you need to add the following parameter to the command line: mtdparts=spi0.0:1536k(uboot),64k(uboot-environment),-(reserved) Then, after having rebooted, you need to install the `u-boot-tools´ package and modify `/etc/fw_env.config´ like this # device name device offset env. size flash sector size number of sectors /dev/mtd1 0x0 0x00010000 0x1000 0x10 Now you can make use of `fw_printenv´ and `fw_setenv´ to get userland access the u-boot environment. Thanks @umiddelb, that sounds much more elegant than my approach of powering up without the microSD card inserted :-) Link to comment Share on other sites More sharing options...
Igor Posted February 6, 2018 Share Posted February 6, 2018 14 hours ago, php said: Is there any diagnostic value in gathering those logs even after I changed my boot It does and it helps me to recreate this issue. I tried yesterday with some old image + upgrade to latest and it worked for me. Have you flashed u-boot to the latest? If not, do it. https://www.armbian.com/espressobin/ Link to comment Share on other sites More sharing options...
