Jim Posted February 12, 2018 Share Posted February 12, 2018 The pcduino discussions appear to be centred here and the A10 appears to be a cutdown A20 so please forgive me if this is in the wrong area. I've been playing with an old pcduino2 and have got the latest mainline server version of Armbian installed on it. Very impressive. However, it appears to have only a single I2C bus and no SPI devices. It looks like there should be a sun4i-a10-spi-spidev.dts file somewhere or else some way to build the appropriate kernel modules but I have been unable to find this. I understand that this is a deprecated board but I should (hopefully) be able to perform any kernel builds required and am more than happy to feed the results back when it works. Many thanks in advance. Jim. Link to comment Share on other sites More sharing options...
Igor Posted February 13, 2018 Share Posted February 13, 2018 23 hours ago, Jim said: The pcduino discussions appear to be centred here and the A10 appears to be a cutdown A20 so please forgive me if this is in the wrong area. I've been playing with an old pcduino2 and have got the latest mainline server version of Armbian installed on it. Very impressive. However, it appears to have only a single I2C bus and no SPI devices. It looks like there should be a sun4i-a10-spi-spidev.dts file somewhere or else some way to build the appropriate kernel modules but I have been unable to find this. I understand that this is a deprecated board but I should (hopefully) be able to perform any kernel builds required and am more than happy to feed the results back when it works. Many thanks in advance. Jim. https://docs.armbian.com/User-Guide_Allwinner_overlays/ Link to comment Share on other sites More sharing options...
Jim Posted February 14, 2018 Author Share Posted February 14, 2018 Many thanks for that very useful reply. I was missing the spi-spidev overlay load. However, I now have another problem (sorry for this). The param_spidev_spi_bus parameter gives the bus that the MCP2515 is on. However, this appears to be the only SPI device that is created, So, for example, if I set it to 0 then I get /dev/spidev0.0 and no other devices. By using the overlays spi0, spi1 and spi2 I was hoping for /dev/spidev0.0, /dev/spidev-0.1, /dev/spidev1.0 and /dev/spidev2.0. Also, shouldn't there be a way to avoid activating the MCP2515. Once again, many thanks for your help! Jim. Link to comment Share on other sites More sharing options...
Jim Posted February 14, 2018 Author Share Posted February 14, 2018 I've just looked at sun4i-a10-spi-spidev.dts and it has status="disabled" for some reason. Could this be the cause? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted February 15, 2018 Share Posted February 15, 2018 Currently only one spidev node can be enabled with provided overlays (to simplify scripting due to u-boot limitations). If you need more than one node you'll have to make a custom overlay. Link to comment Share on other sites More sharing options...
