Button on PiOne board doesn't work in 4.14.14
eejeel
I'am running a PiOne with 4.14.14 Stretch.
I have installed acpid and give the command acpi_listen
When pussing the button in Stretch and I didn't see any logging.
With the old kernel in 5.38 Jessie on the same PiOne I saw
button/power PBTN 00000080 00000000
In the output of
 dtc /boot/dtb/sun8i-h3-orangepi-one.dtb
I saw
key_pins@0 {
    pins = "PL3";
    function = "gpio_in";
    linux,phandle = <0x39>;
    phandle = <0x39>;
Means gpio_in  defined as an input?
Is the button function not yet implemented in 4.14.14? Or is something going wrong?
In mainline kernel DT the onboard button sends the code BTN_0 so it doesn't work as a power button by default.
		sw4 {
			label = "sw4";
			linux,code = <BTN_0>;
			gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>;
It can be changed to one of the codes defined here like KEY_POWER, but it will work only for shutdown, there is no suspend/resume or powering on after shutdown support.
I use this button for shutdown the PiOne. Therefore in the 5.38 Jessie version I have put a file in /etc/acpi/events/button_power
File contents:
event=button/power
action=/sbin/shutdown -h now
As written in another forum topic, PiHole is my first and only Linux project. I don't know to implement this. Is it possible that this can be included in one of the next package releases?
