Hello,
I'm trying to build a image using the amazing auto builder supplied by armbian. In the past I've build kernels and modules for linux running at CycloneV-Devices. I don't need graphic support. If I use the image for a M2 Plus there is a initialization issue at mmc:
MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Card did not respond to voltage select!
mmc_init: -95, time 22
So I'm stuck. Is there a
