Johhny Blue Posted March 14, 2018 Share Posted March 14, 2018 Hi, I realise the NeoCore is not yet supported, but I hope someone can help me with a problem that I am having using the GPIO as buttons. I would like to use the gpio marked GPIOPA13,P A14, PA15,P A16 and PA2 I think these are used by the UART and SPI - I don't require this functionality. I think I have to modify the fex, I have looked, but do not want to kill my system Isit possible to use those gpio? Can someone point me in the right direction? TIA. J. Link to comment Share on other sites More sharing options...
Igor Posted March 14, 2018 Share Posted March 14, 2018 4 minutes ago, Johhny Blue said: I realise the NeoCore is not yet supported It is virtually the same board as Neo (you can start with their images) and gpio handling is pretty generic. http://linux-sunxi.org/Fex_Guide http://linux-sunxi.org/GPIO https://forum.armbian.com/search/?&q=gpio Just read and try. Link to comment Share on other sites More sharing options...
Johhny Blue Posted March 14, 2018 Author Share Posted March 14, 2018 Hey Igor. Thanks for the reply. I checked out your links and it is way beyond me. I looked the current fex file and found these 2 occurrences of PA 15 [card_boot] logical_start = 40960 sprite_work_delay = 500 sprite_err_delay = 200 sprite_gpio0 = port:PA15<1><default><default><default> next_work = 3 and [spi1] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA13<2><1><default><default> spi_sclk = port:PA14<2><default><default><default> spi_mosi = port:PA15<2><default><default><default> spi_miso = port:PA16<2><default><default><default> and PA16 [audio0] audio_used = 1 lineout_vol = 31 cap_vol = 5 audio_hp_ldo = "none" adcagc_used = 0 adcdrc_used = 0 dacdrc_used = 0 adchpf_used = 0 dachpf_used = 0 audio_pa_ctrl = port:PA16<1><default><default><0> So I really don't know what to change it to (without killing my system), that will allow me to connect a button between that port and ground. Is it even possible with those ports or should I look elsewhere? Link to comment Share on other sites More sharing options...
