[TEST/A20/Lamobo R1/20160307] kernel 4.4.4 Linaro gcc 5.1.1 (full crypto, power managt)
FYI
quick update kernel 4.4.24
gr@bpi:~$ cat /proc/version
Linux version 4.4.4-sunxi (root@server1404) (gcc version 5.1.1 20150608 (Linaro GCC 5.1-2015.08) ) #1 SMP Mon Mar 7 13:55:59 CET 2016
download deb here
I have moved to 4.4.4 Xcompiled with linaro 4.9.2 5.1.1
=> Armbian tool on Ubuntu 14.04.34  guest with gcc 5.3
full-crypto + A20 hardware (P)RNG + CPU @1GHz
NOTE: [standard sunxi-next] nice, the linux-trusty*.deb package is built with kernel only compile (thanks)
config
http://pastebin.com/V4p7B9bK
NOTE : [standard sunxi-next] nice to have NEON as module
I prefer CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
testing CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE=y
CONFIG_PM_DEVFREQ=y
added LED triggers
but forgot to add Ministrel for Wifi AC
Edited by wildcat_paris
kernel 4.4.4
I'm going to be using a lamobo today to make my internet not-shit via MPTCP.  If people would like< I'm glad to try and add MPTCP kernel support to armbian while I am at it.
.....Wildcat-- I'd love to know what the kernel you mentioned is all about, too.  Sounds, well like the sort of thing I'd do...... or try to anyway :D.
@Jacob
you mean
https://en.wikipedia.org/wiki/Multipath_TCP
looking at mptcp, it is not included in the linux kernel tree (as far as I can see), currently they maintain kernel 3.18 version on github and there is a patch for kernel 4.1 (does it work on 4.4? to be tested?)
Isn't that a (apache,etc.) server side feature, Apple is using it to optimize "Hello Siri" connections?
http://multipath-tcp.org/pmwiki.php?n=Main.Release90
http://multipath-tcp.org/pmwiki.php/Users/DoItYourself
http://multipath-tcp.org/patches/
and also, you need to compile routing tool packages adapted to mptcp, etc.
https://github.com/multipath-tcp
so? can it help the Lamobo-R1 hardware limitations?
in case you want to play with my kernel built with the Armbian tool, here is my deb files for kernel 4.4.4 for trusty / with CPU @1GHz + performance governor, standard Armbian already integrates the patch from OpenWRT for lamobo to improve TCP
download : http://guillaume.romagny.free.fr/lamobo/(use @ your own risk!)
gr@bpi:~$ sensors
sun4i_ts-isa-0000
Adapter: ISA adapter
SoC temperature:  +36.4°C
gr@bpi:~$ sudo cpufreq-info
[sudo] password for gr:
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 0 1
  CPUs which need to have their frequency coordinated by software: 0 1
  maximum transition latency: 244 us.
  hardware limits: 144 MHz - 1.01 GHz
  available frequency steps: 144 MHz, 312 MHz, 528 MHz, 720 MHz, 864 MHz, 912 MHz, 960 MHz, 1.01 GHz
  available cpufreq governors: powersave, conservative, userspace, ondemand, performance
  current policy: frequency should be within 144 MHz and 1.01 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency is 1.01 GHz (asserted by call to hardware).
  cpufreq stats: 144 MHz:0.00%, 312 MHz:0.00%, 528 MHz:0.00%, 720 MHz:0.00%, 864 MHz:0.00%, 912 MHz:0.00%, 960 MHz:0.00%, 1.01 GHz:100.00%  (1)
analyzing CPU 1:
  driver: cpufreq-dt
                  within this range.
