Linef-Pn Posted February 8, 2016 Share Posted February 8, 2016 Hi, i recently installed jessie (vanilla) on a cubietruck. I have problems with a usb stick to be correctly detected. It is a rf stick to communicate with Homematic devices (HM-CFG-USB). When I plug it in, I get following messages in syslog: Feb 8 21:34:38 localhost kernel: [ 5043.855985] usb 3-1: new full-speed USB device number 8 using ohci-platform Feb 8 21:34:38 localhost kernel: [ 5044.079007] usb 3-1: New USB device found, idVendor=1b1f, idProduct=c00f Feb 8 21:34:38 localhost kernel: [ 5044.079041] usb 3-1: New USB device strings: Mfr=4, Product=14, SerialNumber=36 Feb 8 21:34:38 localhost kernel: [ 5044.079060] usb 3-1: Product: HM-CFG-USB Feb 8 21:34:38 localhost kernel: [ 5044.079077] usb 3-1: Manufacturer: eQ-3 Feb 8 21:34:38 localhost kernel: [ 5044.079093] usb 3-1: SerialNumber: LEQ0659333 Feb 8 21:34:38 localhost kernel: [ 5044.092021] hid-generic 0003:1B1F:C00F.000A: device has no listeners, quitting Feb 8 21:34:38 localhost mtp-probe: checking bus 3, device 8: "/sys/devices/platform/soc@01c00000/1c14400.usb/usb3/3-1" Feb 8 21:34:38 localhost mtp-probe: bus: 3, device: 8 was not an MTP device On raspberry / wheezy I have no problems detecting the stick: Feb 8 19:56:49 raspberrypi kernel: [4414242.954861] usb 1-1.2: new full-speed USB device number 8 using dwc_otg Feb 8 19:56:49 raspberrypi kernel: [4414243.059928] usb 1-1.2: New USB device found, idVendor=1b1f, idProduct=c00f Feb 8 19:56:49 raspberrypi kernel: [4414243.059972] usb 1-1.2: New USB device strings: Mfr=4, Product=14, SerialNumber=36 Feb 8 19:56:49 raspberrypi kernel: [4414243.059991] usb 1-1.2: Product: HM-CFG-USB Feb 8 19:56:49 raspberrypi kernel: [4414243.060008] usb 1-1.2: Manufacturer: eQ-3 Feb 8 19:56:49 raspberrypi kernel: [4414243.060025] usb 1-1.2: SerialNumber: LEQ0659333 Feb 8 19:56:49 raspberrypi kernel: [4414243.077115] hid-generic 0003:1B1F:C00F.0002: hiddev0,hidraw0: USB HID v1.10 Device [eQ-3 HM-CFG-USB] on usb-20980000.usb-1 .2/input0 Could someone help me, please? Thanks! Martin Link to comment Share on other sites More sharing options...
zador.blood.stained Posted February 8, 2016 Share Posted February 8, 2016 I added hiddev and hidraw options to mainline kernel config, so this should be fixed with new kernel release. If you want to test it now, you can try installing prebuilt kernel from this topic (you need to install at least linux-image and linux-dtb packages). Link to comment Share on other sites More sharing options...
Linef-Pn Posted February 9, 2016 Author Share Posted February 9, 2016 Hi, The new kernel now lets me access the USB stick and I can fetch RF-data from it. Thx very much for the quick help! Martin Link to comment Share on other sites More sharing options...
matteobp Posted October 2, 2018 Share Posted October 2, 2018 On 2/8/2016 at 10:39 PM, zador.blood.stained said: I added hiddev and hidraw options to mainline kernel config, so this should be fixed with new kernel release. If you want to test it now, you can try installing prebuilt kernel from this topic (you need to install at least linux-image and linux-dtb packages). I have a similar problem with apcupsd on a Odroid XU4 board, see this topic CONFIG_USB_HIDDEV was disabled on the kernel configuration file, while CONFIG_HIDRAW is already enabled. I build the kernel with CONFIG_USB_HIDDEV enabled, but it is still not working. Any ideas? Thanks in advance. P.S. In this case https://forum.odroid.com/viewtopic.php?f=93&t=28978 enabling CONFIG_USB_HIDDEV was enough https://github.com/hardkernel/linux/commit/be592282a08a2493692448e365e46b52ac715b3f Link to comment Share on other sites More sharing options...
