Don Pedro Posted March 19, 2018 Share Posted March 19, 2018 Hello, after the usual apt update/apt upgrade the OS requested a reboot. However it then fails to boot. Here's the output of the console: Quote U-Boot 2017.11-armbian (Jan 24 2018 - 22:33:23 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Card did not respond to voltage select! mmc_init: -95, time 22 *** Warning - MMC init failed, using default environment Setting up a 1024x768 vga console (overscan 0x0) In: serial Out: vga Err: vga Allwinner mUSB OTG (Peripheral) SCSI: Target spinup took 0 ms. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 Warning: usb_ether using MAC address from ROM , eth1: usb_ether starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1...Found U-Boot script /boot/boot.scr 3708 bytes read in 202 ms (17.6 KiB/s) ## Executing script at 43100000 Wrong image format for "source" commandSCRIPT FAILED: continuing... Card did not respond to voltage select! mmc_init: -95, time 25 scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: ST4000VN000-1H41 Rev: SC46 Type: Hard Disk Capacity: 3815447.8 MB = 3726.0 GB (7814037168 x 512) Found 1 device(s). Device 0: (0:0) Vendor: ATA Prod.: ST4000VN000-1H41 Rev: SC46 Type: Hard Disk Capacity: 3815447.8 MB = 3726.0 GB (7814037168 x 512) ... is now current device Scanning scsi 0:1... Device 0: device type unknown ... is now current device ** Bad device usb 0 ** ** Bad device usb 0 ** ethernet@01c50000 Waiting for PHY auto negotiation to complete...... done Speed: 1000, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.178.34 (11 ms) *** Warning: no boot file name; using 'C0A8B222.img' Using ethernet@01c50000 device TFTP from server 192.168.178.1; our IP address is 192.168.178.34 Filename 'C0A8B222.img'. Load address: 0x42000000 Loading: T T T T T T T T T T Retry count exceeded; starting again missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-02-44-06-c3-35-61 Speed: 1000, full duplex Using ethernet@01c50000 device TFTP from server 192.168.178.1; our IP address is 192.168.178.34 Filename 'pxelinux.cfg/01-02-44-06-c3-35-61'. Load address: 0x43200000 Loading: T T T I guess the critical stuff is what I marked in bold? So what happened here and what to do to recover? Not keen to reinstall the whole OS... Edit: I pulled th SD-Card and read it from a Linux PC. When I take a look at /boot/boot.scr it is clearly corrupted! If I'm correct there's binary data inside, however in the hexdata I can see some segments with ASCII text fragments inside that releates to my private data (e.g. names of mp3 files!!) and that shoud definitely not be in boot.scr. So whatever happened, something during apt update/upgrade killed the boot.scr - and hopefully nothing else. Can I somehow repair boot.scr without reinstalling the whole OS? My Cubietruck is on Stretch. Edit: Further analysis showed that several more files than just boot.scr from /boot have been corrupted, where originally was a script there's binary junk now. So probably I need to reinstall the OS, as I cannot know which files were destroyed. The question here of course is what did corrupt all those file in /boot? I'm aware that I might never find out. The SD Card used is not a no-name product, it's an emtec (http://www.emtec-international.com/de/home), so this should not be due to a crappy card. So what remains is a stale feeling about the system suddenly dying... :-// THX Don Link to comment Share on other sites More sharing options...
Igor Posted March 21, 2018 Share Posted March 21, 2018 On 19. 3. 2018 at 10:47 PM, Don Pedro said: When I take a look at /boot/boot.scr it is clearly corrupted! boot.scr is binary made from boot.cmd ... how it is made is written in the last line. On 19. 3. 2018 at 10:47 PM, Don Pedro said: The SD Card used is not a no-name product, This tells nothing. All SD cards die. Sooner or later. Since I am dealing with Armbian I already threw away 10-15 cards and at least half of them were claimed to be the best in their (consumer) class. An upgrade is very stressful for SD card. Link to comment Share on other sites More sharing options...
Don Pedro Posted March 21, 2018 Author Share Posted March 21, 2018 4 hours ago, Igor said: boot.scr is binary made from boot.cmd ... how it is made is written in the last line. I know. My boot.cmd also contains crap :-/ Recreating boot.scr was my first attempt. But as we engineers say: Junk in, junk out. Is that already a FIFO? ;-) I extracted boot.scr from the original armbian image. I also was able to create one on a Linux machine alternatively. However when I realized even more files got corrupted I decide to dump the installation on the SD-card, you never know what other files were corrupted and I'm not keen on a semi-broken system showing mysterious errors. Quote This tells nothing. All SD cards die. Sooner or later. Since I am dealing with Armbian I already threw away 10-15 cards and at least half of them were claimed to be the best in their (consumer) class. An upgrade is very stressful for SD card. Of course a quality card doesn't mean it ain't gonna die one day. Plus SD card has the disadvantage that it can't be trimmed like an SSD. However this card is not old, I just setup the whole system (not upgraded) a couple of weeks ago, the card was newly bought for that purpose. I will check it with a test program before reinstalling the OS. Edit: I tested the card with Heise's H2testw and it found broken areas on the card. So it seems my card is broken. I will pick a new one and reinstall the OS. THX Don Link to comment Share on other sites More sharing options...
