zag Posted March 23, 2018 Share Posted March 23, 2018 Good day, Here it produces and reboots again. The card boots normally, but does not see the flash memory. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... [ 5.352628] Btrfs loaded Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.27.1 [/sbin/fsck.ext2 (1) -- /dev/mmcblk0p1] fsck.ext2 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1 contains a file system with errors, check forced. /dev/mmcblk0p1: Duplicate or bad block in use! /dev/mmcblk0p1: Multiply-claimed block(s) in inode 374953: 1545728 /dev/mmcblk0p1: Multiply-claimed block(s) in inode 375076: 1545728 /dev/mmcblk0p1: (There are 2 inodes containing multiply-claimed blocks.) /dev/mmcblk0p1: File /var/lib/AccountsService/users/gena.4FCWFZ (inode #374953, mod time Mon Mar 19 14:48:19 2018) has 1 multiply-claimed block(s), shared with 1 file(s): /dev/mmcblk0p1: /var/lib/dhcp/dhclient.eth0.leases (inode #375076, mod time Mon Mar 19 14:48:06 2018) /dev/mmcblk0p1: /dev/mmcblk0p1: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options) fsck exited with status code 4 done. Failure: File system check of the root filesystem failed The root filesystem on /dev/mmcblk0p1 requires a manual fsck Rebooting automatically due to panic= boot argument I correctly understood that the problem is in flash memory? Can this be somehow corrected? Link to comment Share on other sites More sharing options...
Igor Posted March 23, 2018 Share Posted March 23, 2018 Please describe your setup as best as possible so we know what your operating environment is like. Name of your board with all details, version number, take a picture if you are not sure what you have Name of the image you installed or logs, when you can boot the board: armbianmonitor -u (paste URL to your forum post) If your board does not boot, provide a log from serial console (UART) or at least make and attach a picture, where it stops. Describe the problem the best you can and provide all necessary info that we can reproduce the problem. If anything is attached to the board, supply all details Link to comment Share on other sites More sharing options...
Termik Posted March 28, 2018 Share Posted March 28, 2018 This looks like a dirty filesystem on sd card. You should manual run fsck with Your card on another linux-based computer and correct any errors on it. Link to comment Share on other sites More sharing options...
zag Posted April 12, 2018 Author Share Posted April 12, 2018 Hello, Sorry that did not answer for a long time, there was no possibility. Thank you for showing interest in my problem. 1. Orange PI PC plus version 1.1 2. Armbian_5.25_Orangepipcplus_Ubuntu_xenial_default_3.4.113_desctop 3. Log from the console when loading in the attached file. 4. After the installation of the "Armbian", everything worked correctly. After about 2-3 months the browser stopped working (I do not remember with what error it was not started). After a short time the card stopped loading, that is, the download sometimes occurred, but for the most part it stopped. I was trying to boot from the SD card with the version of the operating system 5.30 (Armbian_5.25_Orangepipc_Ubuntu_xenial_default_3.4.113_desctop), everything was loaded and worked fine. I wanted to reset "Armbian" to internal memory, but the utility "nand-site-install" does not see EMMC memory. Is it possible to somehow format the internal memory and reinstall everything? OPCPlusProblem.txt Link to comment Share on other sites More sharing options...
