Build framework: Allow to skip patching when running compile.sh
Rfreire
Hello there Maintainers! o/
I have found something while builiding my image and would like to ask for your opinion on that :-)
I have built a Docker build environment where things are going real smooth (After some tinkering ;-)
In order to save everyone's bandwidth (and be able to do builds while offline), I was tinkering with IGNORE_UPDATES=yes FORCE_CHECKOUT=no compile option.
Well.
That causes the build to fail, because after the first compile and its patch, a second round with these flags will cause the patch to be applied again and potentially breaking stuffs.
I'm circumventing it by moving the patch dir, by:
# Move the patch directory somewhere else
# mv ./patch/kernel/rockchip-default/ ./patch/kernel/rockchip-default.orig
# And then retry the compile op
# ./compile.sh KERNEL_KEEP_CONFIG=yes CLEAN_LEVEL=debs BOARD=tinkerboard BRANCH=default IGNORE_UPDATES=yes FORCE_CHECKOUT=no
Thoughts?
Have a great weekend (I'm have a great one! ;-D)
