Rock64 omv samba speed
micktol
I have installed open media vault on my rock64 and I have a sata3 disc drive connected to the usb3 port. I have tried both armbian and ayufan firmwares and the speed of the samba shares is 30 MB/sec. I know that the system can do more as with FTP I get 100MB/sec. I have tried many samba tweaks but nothing changes, is this the max I can expect?
53 minutes ago, micktol said:
I installed omv with armbian-config is this the correct way?
it is.. In the past some of the tweaks where not applied when you install OMV that way, so starting from OMV image directly was the better way (don't know if this is still true). You can build OMV images on your own with armbians buildscript or download them directly from here: https://sourceforge.net/projects/openmediavault/
