Bingo Posted April 15, 2018 Share Posted April 15, 2018 Hi Guyzz Just got a OPI1 (H3 512MB), and was trying out the stretch image from herehttps://www.armbian.com/orange-pi-one/https://dl.armbian.com/orangepione/Debian_stretch_next.7z It won't boot It starts up , w. both Orange & Green leds on lan , then i can see it requests a dhcp address , and it gets one (req/offer runs many times), then nothing happens after that. Just - Green light blinks on lan , Orange is unlit. I tried to write (linux dd) it on 2 different SD-cards , a 8GB Intenso , and also a 16GB Sandisk - same behaviour. I grabbed the latest Jessie from the archive , and wrote it to the Intenso 8GB , and it booted fine w. jessie. I don't mind running jessie for now. Just wanted to inform you Thanx for a nice Distro for my OPI's (Zero's & One's) Edit: sha256sum matches , so no DL corruption /Bingo Link to comment Share on other sites More sharing options...
chwe Posted April 15, 2018 Share Posted April 15, 2018 providing the boot log from serial console would help to see what's going wrong during boot. Link to comment Share on other sites More sharing options...
Bingo Posted April 15, 2018 Author Share Posted April 15, 2018 Is the console on uart1 ,2 or 3 ? /Bingo Link to comment Share on other sites More sharing options...
chwe Posted April 15, 2018 Share Posted April 15, 2018 https://linux-sunxi.org/Xunlong_Orange_Pi_One#Locating_the_UART Link to comment Share on other sites More sharing options...
Bingo Posted April 15, 2018 Author Share Posted April 15, 2018 Ohh ... Thnx Will try to dig up a 3v3 uartboard /Bingo Link to comment Share on other sites More sharing options...
Bingo Posted April 15, 2018 Author Share Posted April 15, 2018 Seems like i end up in Uboot See boot-bad I included a succesfull boot from jessie too /Bingo boot-bad.txt.tar.bz2 OPIone-jessie.txt.tar.bz2 Link to comment Share on other sites More sharing options...
Bingo Posted April 15, 2018 Author Share Posted April 15, 2018 Ohh here's a log from uboot reset Can't do a log from power-on , as the usb-device dissapear , and so does putty /Bingo reset-boot-bad.txt.tar.bz2 Link to comment Share on other sites More sharing options...
Bingo Posted April 15, 2018 Author Share Posted April 15, 2018 Well i'll be ...... The system boots fine on Debian Stretch now I downloaded the image once more , and wrote it to the Sandisk SD card It boots fine... This has to be a USER error (me ...) ... Prob. SD writing or bad SD to micro SD adapter. Thats embarsasing. Sorry for the "Noise" , and thank you for the immediate support , and getting me to pull out the FTDI TTL uart adapter /Bingo boot-ok.txt.tar.bz2 Link to comment Share on other sites More sharing options...
chwe Posted April 15, 2018 Share Posted April 15, 2018 hehe.. solved by your own. It can happen that the download was corrupted or your cards are... or burning went wrong... cards can be tested with f3 or h2testw download integrity can be checked by checking checksums https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-integrity and images should be burned with etcher.io (they had an issue on linux, not sure if this is solved yet) And sometimes we might have images which doesn't work, it's just that without a bootlog it's a 'black box' we have no chance to see whats wrong. 6 hours ago, Bingo said: Sorry for the "Noise" , and thank you for the immediate support , and getting me to pull out the FTDI TTL uart adapter IMO no need for a sorry, since solved easily (only posting one link ) and you reported back that there's no issue. Keep an eye on your SD cards there are known bad ones and known good ones, and you can test them to see if they perform well just have a look at: Link to comment Share on other sites More sharing options...
