zamar19 Posted April 30, 2018 Share Posted April 30, 2018 I've a problem with latest Armbian Debian Server stretch (ARMBIAN 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.18-sunxi, Uboot loader 2017.11) on OrangePI One, and OrangePI PC. It boots seemingly OK, but without any output to 1080P HDMI monitor. So I've no video. But Ubuntu Desktop with Legacy kernel boots fine using the same SDCard (and same power supply ). I can SSH to the Debian after boot, here's the boot and diag log. Couldn't wait for senseless SDCard testing to finish, as it works perfect with Armbian Ubuntu Desktop version. Legacy version on 1st boot shown boot progress and defaulted to 720P resolution, which I changed later to 1080P. But Debian Server doesn't show ANY output on the same monitor during boot and after. I understand, there may be a problem with querying EDID - but how I can fix it? It can be a wrong color scheme too, like 1 instead of 0. Both OS versions are downloaded from *official* Armbian page links, tested upon burn to SDCard, and SHA256 matched to control files. I tried 2 different SDCards, and 2 Debian versions - OrangePI One and PC - the same thing: no HDMI output. Link to comment Share on other sites More sharing options...
zamar19 Posted April 30, 2018 Author Share Posted April 30, 2018 Tried to boot on another 1080P monitor - and the same OS booted OK. So it looks like uBoot can't read EDID from the 1st monitor. The question is: what are other ways to set monitor resolution apart from reading it from EDID? Can it be directly permanently set in uBoot? Is fw_setenv command supported in Debian Stretch in write mode? Tried fw_printenv, and got "Environment does not start on (erase) block boundary", which results in Read Only access to env from SSH console. Is that the latest uBoot? It seems that error was fixed in Aug 2016, not sure though if its the same uBoot line. Can we enable Netconsole in this uBoot, and how? Link to comment Share on other sites More sharing options...
zamar19 Posted April 30, 2018 Author Share Posted April 30, 2018 I tried to follow advice from this post, but it didn't work: add line in /boot/armbianEnv.txt : extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin video=HDMI-A-1:1920x1080-24@60 I also tried to add similar line in boot.cmd and recompile, and it failed to boot: setenv extraargs "drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin video=HDMI-A-1:1920x1080-24@60" I assume the generic 1920x1080.bin from the distro can be used instead of my monitor edid.bin? The reason is I've a 4K monitor, so not sure if Linux driver will read or execute info from its EDID properly even if manually added to the EDID folder. Also the question: should a full path to the EDID folder be given in extraargs, or its known to the system? Do you guys ever answer questions, or its a monologues forums? I realize many have similar issues with monitor EDID - but no solution works for different monitors or OS release the same way, and the Wiki docs are grossly obsolete. I also suspect it may be a code syntax issue. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted April 30, 2018 Share Posted April 30, 2018 8 minutes ago, zamar19 said: Do you guys ever answer questions, or its a monologues forums? Sometimes. Mainline driver has not reached upstream yet, it may have bugs. Bugs that will not be fixed in this version or that may have been fixed already in the version that will appear upstream. And kernel related questions asked without providing debug logs in form of output of "armbianmonitor -u" are often ignored, when people don't read this page that is linked below the forum header why should we bother to read and try to answer in return? 14 minutes ago, zamar19 said: Also the question: should a full path to the EDID folder be given in extraargs, or its known to the system? This path should be relative to /lib/firmware, which means that if edid/1920x1080.bin is specified then /lib/firmware/edid/1920x1080.bin should already exist, assuming the DRM output notation "HDMI-A-1" is correct. Link to comment Share on other sites More sharing options...
chwe Posted May 1, 2018 Share Posted May 1, 2018 6 hours ago, zamar19 said: Do you guys ever answer questions, or its a monologues forums? do you read flags on the downloadpage? cause when you download mainline images you'll see this one: start to complain after 19h is a bit.. Hmm. let's say, I would be sometimes happy if I get an answer within 24h for services I pay for... Keep in mind, this is a spare-time projects, people who might have experience with your issue might have a live besides Armbian. If you have a quick look here: http://linux-sunxi.org/Mainlining_Effort#Status_Matrix You'll see that HDMI got mainlined with 4.17 kernel. Whereas armbian next sticks at 4.14 at the moment. The only reason you get this earlier was due to the fact that @zador.blood.stained was patient enough to patch the next kernel 8 months ago (and here too with a WIP flag, means more or less the same as for wip/testing images, things may not work 'as expected'). Furthermore you could follow this thread here: where HDMI was discussed once again... Not that i want to bother you, but there's a reason why we suggest mainline for server use cases only (where people normally access their devices via SSH) and why even then, the image is flagged as testing. Link to comment Share on other sites More sharing options...
zamar19 Posted May 1, 2018 Author Share Posted May 1, 2018 I'm not asking for out-of-the-box solution, but merely look for a workaround, and besides all smarty non-working drivers there're pretty straightforward "hard-coded" solutions, which can be suggested by more experienced users. Yet NONE is suggested so far. Btw, running LXQT desktop correctly identifies all available resolutions from 4K monitor EDID. So my guess is, uBoot driver tries to run 1st default 4K reso instead of set in extraargs 1080P, and fails to do it, especially without Mali support. Yet hard coding reso works on Ubuntu desktop with legacy kernel. I assume, uBoot graphics driver in Debian package is different from OS graphics driver? These commands fail, but seems forwarded to the kernel, as changing them alters boot results, so may be its syntax error? extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin,video=HDMI-A-1:1920x1080-24@60 extraargs="drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin video=HDMI-A-1:1920x1080-24@60" For now I hooked HDMI 2-port switch to the OPI PC. Once the device reads EDID from 1080P monitor, I flip the switch to the 4K monitor and it shows normal 1080P pic. Will see, may be editing default 1080P EDID file will bring more light, unless someone suggests something on-topic. I got both monitors EDIDs with get-edid and copied to the EDID folder, then references in armbianEnv.txt . They both have 256K size, while the Debian package EDIDs are 128K in size. May be shrinking the file size by deleting EDID extensions info would do the trick? What webUI admin tool is a good match for OPI on Debian? Webmin sounds a bit heavy, if still in the Debian repo. Link to comment Share on other sites More sharing options...
zamar19 Posted May 1, 2018 Author Share Posted May 1, 2018 Here's sudo armbianmonitor -u output. Link to it was present in the 1st post, but somehow auto deleted on its edit: Spoiler lrwxrwxrwx 1 root root 27 Jan 27 17:44 /etc/resolv.conf -> /run/resolvconf/resolv.conf # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8) # DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN nameserver XXX.XXX.1.1 ### Current sysinfo: Linux 4.14.18-sunxi (orangepipc) 04/30/2018 _armv7l_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 2.74 0.34 1.14 1.11 0.00 94.68 Device: tps kB_read/s kB_wrtn/s kB_read kB_wrtn ram0 0.00 0.00 0.00 0 0 ram1 0.00 0.00 0.00 0 0 ram2 0.00 0.00 0.00 0 0 ram3 0.00 0.00 0.00 0 0 mmcblk0 6.28 233.42 0.82 95869 336 mmcblk0p1 5.98 225.82 0.82 92745 336 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- r b swpd free buff cache si so bi bo in cs us sy id wa st 0 0 0 853932 9780 99932 0 0 59 0 47 65 3 1 95 1 0 total used free shared buff/cache available Mem: 1.0G 59M 833M 5.6M 107M 914M Swap: 127M 0B 127M 11:41:31 up 6 min, 1 user, load average: 0.42, 0.25, 0.14 [ 3.583563] audit: initializing netlink subsys (disabled) [ 3.583855] audit: type=2000 audit(3.570:1): state=initialized audit_enabled=0 res=1 [ 3.584061] Initialise system trusted keyrings [ 3.584232] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 3.588923] zbud: loaded [ 3.591032] NFS: Registering the id_resolver key type [ 3.591090] Key type id_resolver registered [ 3.591103] Key type id_legacy registered [ 3.591123] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.591139] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 3.592047] JFS: nTxBlock = 7992, nTxLock = 63939 [ 3.601732] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 3.608278] Key type asymmetric registered [ 3.608358] bounce: pool size: 64 pages [ 3.608442] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 3.608577] io scheduler noop registered [ 3.608594] io scheduler deadline registered [ 3.608866] io scheduler cfq registered (default) [ 3.608884] io scheduler mq-deadline registered [ 3.608897] io scheduler kyber registered [ 3.609029] io scheduler bfq registered [ 3.609990] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO [ 3.613677] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 3.615065] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 3.658202] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 3.661066] console [ttyS0] disabled [ 3.681232] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A [ 4.561388] console [ttyS0] enabled [ 4.568207] brd: module loaded [ 4.576309] loop: module loaded [ 4.581051] libphy: Fixed MDIO Bus: probed [ 4.585652] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 4.591458] dwmac-sun8i 1c30000.ethernet: No regulator found [ 4.597217] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) [ 4.606632] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 4.612302] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 4.619526] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 4.625195] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 4.632427] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 4.637393] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 4.644279] libphy: stmmac: probed [ 4.648091] dwmac-sun8i 1c30000.ethernet: Found internal PHY node [ 4.654275] libphy: mdio_mux: probed [ 4.657867] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY [ 4.664233] dwmac-sun8i 1c30000.ethernet: Powering internal PHY [ 4.674836] libphy: mdio_mux: probed [ 4.678902] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.685456] ehci-platform: EHCI generic platform driver [ 4.690900] ehci-platform 1c1a000.usb: EHCI Host Controller [ 4.696496] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 [ 4.704892] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000 [ 4.740526] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 [ 4.746895] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.753728] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.760973] usb usb1: Product: EHCI Host Controller [ 4.765853] usb usb1: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 4.771871] usb usb1: SerialNumber: 1c1a000.usb [ 4.776943] hub 1-0:1.0: USB hub found [ 4.780776] hub 1-0:1.0: 1 port detected [ 4.785401] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 4.791619] ohci-platform: OHCI generic platform driver [ 4.797034] ohci-platform 1c1a400.usb: Generic Platform OHCI controller [ 4.803680] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 [ 4.811592] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 [ 4.884747] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 4.891557] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.898780] usb usb2: Product: Generic Platform OHCI controller [ 4.904712] usb usb2: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 4.910729] usb usb2: SerialNumber: 1c1a400.usb [ 4.915692] hub 2-0:1.0: USB hub found [ 4.919488] hub 2-0:1.0: 1 port detected [ 4.924152] usbcore: registered new interface driver usb-storage [ 4.930750] mousedev: PS/2 mouse device common for all mice [ 4.936785] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 [ 4.943596] sun6i-rtc 1f00000.rtc: RTC enabled [ 4.948227] i2c /dev entries driver [ 4.953808] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 4.962902] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 5.020535] sunxi-mmc 1c0f000.mmc: base:0xf1005000 irq:25 [ 5.026881] ledtrig-cpu: registered to indicate activity on CPUs [ 5.033007] hidraw: raw HID events driver (C) Jiri Kosina [ 5.038549] usbcore: registered new interface driver usbhid [ 5.044150] usbhid: USB HID core driver [ 5.048914] NET: Registered protocol family 10 [ 5.067797] Segment Routing with IPv6 [ 5.071602] NET: Registered protocol family 17 [ 5.076247] Key type dns_resolver registered [ 5.080932] Registering SWP/SWPB emulation handler [ 5.086277] registered taskstats version 1 [ 5.090381] Loading compiled-in X.509 certificates [ 5.095328] zswap: loaded using pool lzo/zbud [ 5.101370] Btrfs loaded, crc32c=crc32c-generic [ 5.110871] mmc0: host does not support reading read-only switch, assuming write-enable [ 5.112659] Key type encrypted registered [ 5.119518] ehci-platform 1c1b000.usb: EHCI Host Controller [ 5.119552] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 [ 5.136581] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000 [ 5.138878] mmc0: new high speed SDHC card at address 1234 [ 5.139446] mmcblk0: mmc0:1234 SA08G 7.29 GiB [ 5.140689] mmcblk0: p1 [ 5.190513] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 [ 5.196818] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.203626] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.210860] usb usb3: Product: EHCI Host Controller [ 5.215739] usb usb3: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 5.221754] usb usb3: SerialNumber: 1c1b000.usb [ 5.226742] hub 3-0:1.0: USB hub found [ 5.230551] hub 3-0:1.0: 1 port detected [ 5.235217] ehci-platform 1c1c000.usb: EHCI Host Controller [ 5.240839] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 [ 5.248887] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000 [ 5.280518] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 5.286786] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.293597] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.300835] usb usb4: Product: EHCI Host Controller [ 5.305715] usb usb4: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 5.311724] usb usb4: SerialNumber: 1c1c000.usb [ 5.316692] hub 4-0:1.0: USB hub found [ 5.320479] hub 4-0:1.0: 1 port detected [ 5.325065] ehci-platform 1c1d000.usb: EHCI Host Controller [ 5.330674] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 [ 5.338618] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000 [ 5.370520] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 [ 5.376774] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.383582] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.390818] usb usb5: Product: EHCI Host Controller [ 5.395697] usb usb5: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 5.401714] usb usb5: SerialNumber: 1c1d000.usb [ 5.406657] hub 5-0:1.0: USB hub found [ 5.410441] hub 5-0:1.0: 1 port detected [ 5.414984] ohci-platform 1c1b400.usb: Generic Platform OHCI controller [ 5.421634] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 [ 5.429535] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400 [ 5.504673] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 5.511480] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.518704] usb usb6: Product: Generic Platform OHCI controller [ 5.524635] usb usb6: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 5.530652] usb usb6: SerialNumber: 1c1b400.usb [ 5.535583] hub 6-0:1.0: USB hub found [ 5.539368] hub 6-0:1.0: 1 port detected [ 5.543927] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 5.550580] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 [ 5.558460] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400 [ 5.634671] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 5.641484] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.648707] usb usb7: Product: Generic Platform OHCI controller [ 5.654641] usb usb7: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 5.660659] usb usb7: SerialNumber: 1c1c400.usb [ 5.665608] hub 7-0:1.0: USB hub found [ 5.669397] hub 7-0:1.0: 1 port detected [ 5.673933] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 5.680587] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 [ 5.688483] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400 [ 5.730518] usb 4-1: new high-speed USB device number 2 using ehci-platform [ 5.764671] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 5.771485] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.778709] usb usb8: Product: Generic Platform OHCI controller [ 5.784643] usb usb8: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 5.790661] usb usb8: SerialNumber: 1c1d400.usb [ 5.795646] hub 8-0:1.0: USB hub found [ 5.799429] hub 8-0:1.0: 1 port detected [ 5.804037] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 5.815088] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 5.820855] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9 [ 5.828950] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.835759] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.842995] usb usb9: Product: MUSB HDRC host driver [ 5.847961] usb usb9: Manufacturer: Linux 4.14.18-sunxi musb-hcd [ 5.853978] usb usb9: SerialNumber: musb-hdrc.1.auto [ 5.859333] hub 9-0:1.0: USB hub found [ 5.863131] hub 9-0:1.0: 1 port detected [ 5.868499] of_cfs_init [ 5.871076] of_cfs_init: OK [ 5.874008] vdd-cpux-dummy: disabling [ 5.877675] vcc3v0: disabling [ 5.880678] vcc5v0: disabling [ 5.883648] usb0-vbus: disabling [ 5.890043] Freeing unused kernel memory: 1024K [ 5.951341] usb 4-1: New USB device found, idVendor=05e1, idProduct=0408 [ 5.958071] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.965266] usb 4-1: Product: USB 2.0 Video Capture Controller [ 5.971131] usb 4-1: Manufacturer: Syntek Semiconductor [ 6.230563] usb 8-1: new low-speed USB device number 2 using ohci-platform [ 6.357462] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 [ 6.502588] usb 8-1: New USB device found, idVendor=1997, idProduct=0409 [ 6.509307] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 6.516498] usb 8-1: Product: Micro Keyboard [ 6.520798] usb 8-1: Manufacturer: Riitek [ 6.532204] input: Riitek Micro Keyboard as /devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.0/0003:1997:0409.0001/input/input0 [ 6.610766] hid-generic 0003:1997:0409.0001: input,hidraw0: USB HID v1.11 Keyboard [Riitek Micro Keyboard] on usb-1c1d400.usb-1/input0 [ 6.630182] input: Riitek Micro Keyboard as /devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.1/0003:1997:0409.0002/input/input1 [ 6.719893] hid-generic 0003:1997:0409.0002: input,hidraw1: USB HID v1.11 Mouse [Riitek Micro Keyboard] on usb-1c1d400.usb-1/input1 [ 16.065716] random: crng init done [ 16.119193] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 16.865452] systemd[1]: System time before build time, advancing clock. [ 16.906135] ip_tables: (C) 2000-2006 Netfilter Core Team [ 16.944300] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 16.963002] systemd[1]: Detected architecture arm. [ 17.005141] systemd[1]: Set hostname to <orangepipc>. [ 17.679111] systemd[1]: Created slice System Slice. [ 17.716456] systemd[1]: Created slice system-serial-getty.slice. [ 17.761203] systemd[1]: Mounting Debug File System... [ 17.790948] systemd[1]: Listening on fsck to fsckd communication Socket. [ 17.831517] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 17.849043] systemd[1]: Reached target Remote File Systems. [ 17.881045] systemd[1]: Listening on udev Control Socket. [ 18.558836] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 19.029558] Adding 131068k swap on /var/swap. Priority:-2 extents:2 across:139260k SSFS [ 19.686445] thermal thermal_zone0: failed to read out thermal zone (-110) [ 19.759534] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 19.759540] [drm] No driver support for vblank timestamp query. [ 19.768683] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer]) [ 19.768985] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 19.769003] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_tcon]) [ 19.900771] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) [ 19.902426] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver [ 19.902758] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi]) [ 19.997022] usb 4-1: New device Syntek Semiconductor USB 2.0 Video Capture Controller @ 480 Mbps (05e1:0408, interface 0, class 0) [ 19.997031] usb 4-1: video interface 0 found [ 20.332971] Console: switching to colour frame buffer device 240x67 [ 20.367921] sun4i-drm display-engine: fb0: frame buffer device [ 20.372071] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 20.390853] lirc_dev: IR Remote Control driver registered, major 243 [ 20.396238] IR LIRC bridge handler initialized [ 20.397786] Registered IR keymap rc-empty [ 20.397956] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 [ 20.398102] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input2 [ 20.398663] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 20.398786] sunxi-ir 1f02000.ir: initialized sunXi IR driver [ 20.401024] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered [ 20.401032] sun4i-codec 1c22c00.codec: Failed to register our card [ 20.430562] Registered IR keymap rc-cec [ 20.430747] rc rc1: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1 [ 20.430932] input: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1/input3 [ 20.436623] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok [ 20.469310] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok [ 20.693968] saa7115 2-0025: gm7113c found @ 0x4a (stk1160) [ 20.730600] thermal thermal_zone0: failed to read out thermal zone (-110) [ 21.058820] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL) [ 21.067686] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 21.067702] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 21.067972] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 21.116075] systemd-journald[491]: Received request to flush runtime journal from PID 1 [ 21.371076] stk1160: Device uses internal 8-bit ADC, skipping AC97 setup. [ 21.430946] stk1160 4-1:1.0: V4L2 device registered as video0 [ 21.431149] usbcore: registered new interface driver stk1160 [ 21.471476] usbcore: registered new interface driver snd-usb-audio [ 21.760605] thermal thermal_zone0: failed to read out thermal zone (-110) [ 24.161198] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 24.161238] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready ### interrupts: CPU0 CPU1 CPU2 CPU3 17: 0 0 0 0 GICv2 50 Level /soc/timer@01c20c00 18: 0 0 0 0 GICv2 29 Level arch_timer 19: 6585 6850 7363 3917 GICv2 30 Level arch_timer 22: 514 0 0 0 GICv2 120 Level 1ee0000.hdmi, dw-hdmi-cec 23: 0 0 0 0 GICv2 82 Level 1c02000.dma-controller 24: 398 0 0 0 GICv2 118 Level 1c0c000.lcd-controller 25: 23690 0 0 0 GICv2 92 Level sunxi-mmc 26: 0 0 0 0 GICv2 103 Level musb-hdrc.1.auto 27: 0 0 0 0 GICv2 104 Level ehci_hcd:usb1 28: 0 0 0 0 GICv2 105 Level ohci_hcd:usb2 29: 0 0 0 0 GICv2 106 Level ehci_hcd:usb3 30: 0 0 0 0 GICv2 107 Level ohci_hcd:usb6 31: 622 0 17 0 GICv2 108 Level ehci_hcd:usb4 32: 0 0 0 0 GICv2 109 Level ohci_hcd:usb7 33: 2 0 0 0 GICv2 110 Level ehci_hcd:usb5 34: 45 0 0 0 GICv2 111 Level ohci_hcd:usb8 38: 363 0 0 0 GICv2 114 Level eth0 42: 377 0 0 0 GICv2 32 Level ttyS0 43: 0 0 0 0 GICv2 72 Level 1f00000.rtc 45: 0 0 0 0 GICv2 69 Level sunxi-ir 46: 6252 0 0 0 GICv2 76 Level mv64xxx_i2c 99: 1 0 0 0 sunxi_pio_edge 44 Edge usb0-id-det IPI0: 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 Timer broadcast interrupts IPI2: 4080 4743 3699 3494 Rescheduling interrupts IPI3: 2 5 4 8 Function call interrupts IPI4: 0 0 0 0 CPU stop interrupts IPI5: 2180 1069 1164 243 IRQ work interrupts IPI6: 0 0 0 0 completion interrupts Err: 0 Link to comment Share on other sites More sharing options...
zamar19 Posted August 13, 2018 Author Share Posted August 13, 2018 Hi guys, I downloaded and burned to SDCard the last nightly image Armbian_5.58.180812_Orangepipc_Ubuntu_bionic_next_4.17.14 for OrangePI PC. Added desktop with apps, and it boots to desktop upon login. How to boot straight to desktop, without login and typing startx? I have 4K HDMI display, so must run development images, since stable don't support 4K as I was explained here earlier. The display has 2 main resolutions: 4K and 1080P. But in Armbian Display settings, choosing 4K gives full screen image, and choosing 1080P results in only a portion of display area used by the system. How I can activate in Armbian the 2nd main display resolution 1080P, so the desktop would occupy the entire screen with lower CPU & GPU load than 4K? Link to comment Share on other sites More sharing options...
