pkfran Posted May 10, 2018 Share Posted May 10, 2018 i want instal peerflix on Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107_desktop, i've install first nodejs from synapsis and after install nodejs -v -> 4.2.6 i run npm -y install peerflix and if return the error message : peerflix --help /usr/local/lib/node_modules/peerflix/node_modules/parse-torrent/index.js:257 ;(function () { Buffer.alloc(0) })() ^ TypeError: Buffer.alloc is not a function at /usr/local/lib/node_modules/peerflix/node_modules/parse-torrent/index.js:257:24 at Object.<anonymous> (/usr/local/lib/node_modules/peerflix/node_modules/parse-torrent/index.js:257:35) at Module._compile (module.js:410:26) at Object.Module._extensions..js (module.js:417:10) at Module.load (module.js:344:32) at Function.Module._load (module.js:301:12) at Module.require (module.js:354:17) at require (internal/module.js:12:17) at Object.<anonymous> (/usr/local/lib/node_modules/peerflix/app.js:14:20) at Module._compile (module.js:410:26) An idea? Thank's Link to comment Share on other sites More sharing options...
