After years of running Armbian on my Cubox i4 without problems, I am suddenly in a situation that I don't understand. For some reason, I decided to reboot it, and now it doesn't work anymore. Using a micro-USB cable and my Macbook, I connected to the serial line to grab some logging:
U-Boot SPL 2017.11-armbian (Jan 24 2018 - 22:39:16)
Trying to boot from MMC1
U-Boot 2017.11-armbian (Jan 24 2018 - 22:39:16 +0100)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 41C
Reset cause: POR
Board: MX6 Cubox-i
DRAM: 2 GiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Net: FEC
starting USB...
USB0: Port not available.
USB1: USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
907 bytes read in 98 ms (8.8 KiB/s)
## Executing script at 12000000
## Error: "autodetectfdt" not defined
** File not found /boot/dtb/ **
** Unrecognized filesystem type **
** File not found /dtb/ **
5783761 bytes read in 483 ms (11.4 MiB/s)
5546904 bytes read in 427 ms (12.4 MiB/s)
## Loading init Ramdisk from Legacy Image at 14800000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 5783697 Bytes = 5.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
I suspect that ## Error: "autodetectfdt" not defined is the culprit. Is there a way I can solve this? I would prefer not to flash the micro-SD, since it contains quite some data I'd like to preserve...
Question
mthmulders
Hi all,
6 answers to this question
