[SOLVED] RT5572 Wireless Adapter does not work on my Rock64
Christian_
Hello.
Please could someone help me to solve this issue?
I have a wifi dongle recognized as: Bus 002 Device 002: ID 148f:5572 Ralink Technology, Corp. RT5572 Wireless Adapter
I am trying to use it on my Rock64 and ARMBIAN 5.42 testing Debian GNU/Linux 9 (stretch) 4.4.124-rk3328
uname -a:
Linux rock64 4.4.124-rk3328 #24 SMP Wed Mar 28 17:15:52 CEST 2018 aarch64 GNU/Linux
It seems it is recognized correctly:
Spoiler
lsmod:
rt2800usb              28672  0
rt2800lib              81920  1 rt2800usb
rt2x00usb              20480  1 rt2800usb
rt2x00lib              49152  3 rt2x00usb,rt2800lib,rt2800usb
dmesg:
[   14.576374] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5592, rev 0222 detected
[   14.606007] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 000f detected
[   14.607477] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   14.610153] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   14.611640] usbcore: registered new interface driver rt2800usb
[   14.657918] rt2800usb 2-1:1.0 wlx441ca87f7a19: renamed from wlan0
[   17.964407] IPv6: ADDRCONF(NETDEV_UP): wlx441ca87f7a19: link is not ready
[   17.964729] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[   17.992211] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[   18.346244] IPv6: ADDRCONF(NETDEV_UP): wlx441ca87f7a19: link is not ready
Using Network Manager had no luck, the device was always listed as disconnected.
So I tried to configure it manually in /etc/network/interfaces, adding this entry:
auto wlx441ca87f7a19
        iface wlx441ca87f7a19 inet dhcp
        wpa-ssid mySSID
        wpa-psk [key removed]
Still no luck, this is the log of networking service:
Spoiler
mag 13 15:07:43 rock64 systemd[1]: Starting Raise network interfaces...
mag 13 15:07:44 rock64 wpa_supplicant[4717]: Successfully initialized wpa_supplicant
mag 13 15:07:45 rock64 dhclient[4732]: Internet Systems Consortium DHCP Client 4.3.5
mag 13 15:07:45 rock64 dhclient[4732]: Copyright 2004-2016 Internet Systems Consortium.
mag 13 15:07:45 rock64 ifup[4683]: Internet Systems Consortium DHCP Client 4.3.5
mag 13 15:07:45 rock64 ifup[4683]: Copyright 2004-2016 Internet Systems Consortium.
mag 13 15:07:45 rock64 ifup[4683]: All rights reserved.
mag 13 15:07:45 rock64 ifup[4683]: For info, please visit https://www.isc.org/software/dhcp/
mag 13 15:07:45 rock64 dhclient[4732]: All rights reserved.
mag 13 15:07:45 rock64 dhclient[4732]: For info, please visit https://www.isc.org/software/dhcp/
mag 13 15:07:45 rock64 dhclient[4732]: Listening on LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19
mag 13 15:07:45 rock64 dhclient[4732]: Sending on   LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19
mag 13 15:07:45 rock64 ifup[4683]: Listening on LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19
mag 13 15:07:45 rock64 ifup[4683]: Sending on   LPF/wlx441ca87f7a19/44:1c:a8:7f:7a:19
mag 13 15:07:45 rock64 ifup[4683]: Sending on   Socket/fallback
mag 13 15:07:45 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 6
mag 13 15:07:45 rock64 dhclient[4732]: Sending on   Socket/fallback
mag 13 15:07:45 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 6
mag 13 15:07:51 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 14
mag 13 15:07:51 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 14
mag 13 15:08:05 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 13
mag 13 15:08:05 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 13
mag 13 15:08:18 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 15
mag 13 15:08:18 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 15
mag 13 15:08:33 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 8
mag 13 15:08:33 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 8
mag 13 15:08:41 rock64 dhclient[4732]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 5
mag 13 15:08:41 rock64 ifup[4683]: DHCPDISCOVER on wlx441ca87f7a19 to 255.255.255.255 port 67 interval 5
mag 13 15:08:46 rock64 dhclient[4732]: No DHCPOFFERS received.
mag 13 15:08:46 rock64 dhclient[4732]: No working leases in persistent database - sleeping.
mag 13 15:08:46 rock64 ifup[4683]: No DHCPOFFERS received.
mag 13 15:08:46 rock64 ifup[4683]: No working leases in persistent database - sleeping.
mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Found user 'avahi-autoipd' (UID 105) and group 'avahi-autoipd' (GID 109
mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Successfully called chroot().
mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Successfully dropped root privileges.
mag 13 15:08:46 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Starting with address 169.254.6.79
mag 13 15:08:51 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Callout BIND, address 169.254.6.79 on interface wlx441ca87f7a19
mag 13 15:08:51 rock64 avahi-autoipd(wlx441ca87f7a19)[4799]: client: RTNETLINK answers: Numerical result out of range
mag 13 15:08:51 rock64 avahi-autoipd(wlx441ca87f7a19)[4799]: Script execution failed with return value 2
mag 13 15:08:55 rock64 avahi-autoipd(wlx441ca87f7a19)[4798]: Successfully claimed IP address 169.254.6.79
mag 13 15:08:56 rock64 systemd[1]: Started Raise network interfaces.
I also tried to add:
options rt2800usb nohwcrypt=y
in /etc/modprobe.d/rt2800usb.conf, as I read somewhere and removed and reloaded the modules, no change
Trying the scan manually I get no results:
wlx441ca87f7a19  IEEE 802.11abgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
sudo iwlist wlx441ca87f7a19 scan
wlx441ca87f7a19  No scan results
I also connected the module to my laptop (running Ubuntu 17.10) to be sure it works, and from there I can connect to my wifi just fine (using Network Manager).
I also can connect to wifi using another usb adapter (Realtek 8188EU USB) on Rock64 with Network Manager.
Any idea?
Thanks in advance.
31 minutes ago, Christian_ said:
Any idea?
Blacklist in-kernel driver and search around for more recent known to work drivers (sources), install headers and compile the module. Repeat until you find a working one. When you find a good working one, we can once replace them with those shipped with the kernel. Ideally: send a patch against kernel source.
