dhlii Posted June 30, 2018 Share Posted June 30, 2018 Can you power an Orange Pi Zero or Orange Pi One from the 26/40 pin header ? I am pretty sure the answer is yes as the OPI Zero expansion board has a power jack. But is there any information regarding how to do this ? Do you feed the +5v or the +3.3v Is it the same for all of the RPI compatible headers ? Link to comment Share on other sites More sharing options...
guidol Posted June 30, 2018 Share Posted June 30, 2018 5 minutes ago, dhlii said: Can you power an Orange Pi Zero or Orange Pi One from the 26/40 pin header ? I am pretty sure the answer is yes as the OPI Zero expansion board has a power jack. But is there any information regarding how to do this ? The Answer is yes Pin 2 or 4 for 5V and Pin 6 for GND To find out where Pin 1 (Square) is - see the backside of the PCB - Pin 1 is a soldered square. 1 Link to comment Share on other sites More sharing options...
dhlii Posted June 30, 2018 Author Share Posted June 30, 2018 Thank you. The graphic is nice but I know where the power pins are. I just wanted to make sure that if I feed +5 to the 5V header - instead of drawing +5 from the 5V header that the OPI will be happy and run from it. Obviously I need to provide enough power. Thank You again Link to comment Share on other sites More sharing options...
guidol Posted June 30, 2018 Share Posted June 30, 2018 30 minutes ago, dhlii said: I just wanted to make sure that if I feed +5 to the 5V header - instead of drawing +5 from the 5V header that the OPI will be happy and run from it. Yes that will work - did try that with my OPi One - where the Micro-USB port doesnt work anymore Link to comment Share on other sites More sharing options...
dhlii Posted July 5, 2018 Author Share Posted July 5, 2018 Thanks, I eventually found confirmation of this on the Xulong web site. I am trying to make an IoT expansion board that the OPI0 plugs into, and seek to power the OPI0 from the expansion board. Link to comment Share on other sites More sharing options...
guidol Posted July 6, 2018 Share Posted July 6, 2018 16 hours ago, dhlii said: Thanks, I eventually found confirmation of this on the Xulong web site. I am trying to make an IoT expansion board that the OPI0 plugs into, and seek to power the OPI0 from the expansion board. The original Opi Zero NAS expansion board does have a real power-connector (on the right) and some other goodies onboard Link to comment Share on other sites More sharing options...
