Enabling 1wire support rock64
marki2239
Is there a guide somewhere how to enable 1wire support on a rock64 using stretch or xenial.   Im trying to read a dallas DS18b20 sensor.
I see some examples for other boards but cant figure out how to apply them to the Rock64.
Thanks
If you want reliable, go for a 1wire to i2c bridge like the ds2482 or something.
Bit banging timing sensitive protocols in a multi user OS is never a good idea. It wastes CPU time with spin waits and if the process gets pre-empted it will probably fail.
It then gives you the freedom of using a w1 kernel driver or doing it all in userspace.
Being i2c, it's a master clocked protocol, so there are no timing issues even if you don't have a hardware i2c port available.
OWFS supports the Maxim i2c chips too
