dsh Posted July 3, 2018 Share Posted July 3, 2018 (edited) If you have ever compiled buildroot from Amlogic, please help me. I am trying to learn develop app on amlogic based device. First I was getting compile error on 64bit Ubuntu 16.04. Something like this. Even though there was a file, 'bash' couldn't find or run. /bin/bash: /root/buildroot/x86/xxxx-gcc: No such file or directory Thinking it's something to do with 64 bit OS, I switched to 32 bit Ubuntu 16.04. However after about 2 hours I'm getting following error. /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-ld: No such file or directory fatal: Not a git repository (or any of the parent directories): .git fatal: Not a git repository (or any of the parent directories): .git Not a git repository To compare two paths outside a working tree: usage: git diff [--no-index] <path> <path> fatal: Not a git repository (or any of the parent directories): .git /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. make[2]: *** No rule to make target '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/firmware.bin', needed by '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/api/libapi.o'. Stop. make[2]: *** Waiting for unfinished jobs.... arm-none-eabi-gcc -DDO_DEPS_ONLY \ -g -Os -D__KERNEL__ -I/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/include2 -I/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/include -I/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/include -fno-builtin -ffreestanding -nostdinc -isystem -pipe -DCONFIG_ARM -D__ARM__ -Wall -Wstrict-prototypes \ -o /root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/lib/asm-offsets.s /root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/lib/asm-offsets.c -c -S /bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory Makefile:805: recipe for target '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/lib/asm-offsets.s' failed make[2]: *** [/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/lib/asm-offsets.s] Error 127 package/pkg-generic.mk:216: recipe for target '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/.stamp_built' failed make[1]: *** [/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/.stamp_built] Error 2 /root/buildroot_openlinux/output/meson8b_m201/Makefile:16: recipe for target '_all' failed make: *** [_all] Error 2 Again those files exists. File command shows following. arm-none-eabi-gcc: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.24, BuildID[sha1]=0c937a9bf52dcb3a4e5ced5efc41213730d23b54, stripped Am I doing anything wrong? Any input will be appreciated. Thanks in advance. Edited July 3, 2018 by dsh Fixed spelling Link to comment Share on other sites More sharing options...
