zhen8838 Posted July 9, 2018 Share Posted July 9, 2018 My Development board is Orange Pi zero plus2 H5. My bluetooth already in work,but I try to play a .wav for test.this circumstance occurs. This is my test wav file: 1045.wav I use : aplay 1045.wav Playing WAVE '1045.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo then I record the sounds as mypaly.mp3. I guess this problem is due to uart Baud rate 115200 is not high enough . How can i fix this? 1045.wav mypaly.mp3 Link to comment Share on other sites More sharing options...
zhen8838 Posted July 10, 2018 Author Share Posted July 10, 2018 I solved this problem,I refer to the answer to this question. This is indeed caused by the serial port baud rate being too low. I modified /etc/init.d/ap6212-bluetooth hciattach /dev/$PORT bcm43xx 115200 flow bdaddr $MAC_OPTIONS to hciattach /dev/$PORT bcm43xx 1500000 flow bdaddr $MAC_OPTIONS Link to comment Share on other sites More sharing options...
