rk3328 (libre) slow crypto and latency errors in log
jmandawg
Hi all,
I got a libre rk3327 board, and i'm tyring to test my crypto and i'm not getting anywhere near the results you guys are getting here
Is there something special i need to do to enable the hardware crypto?
Linux renegade 4.4.138-rk3328 #3 SMP Sun Jul 1 20:15:37 UTC 2018 aarch64 GNU/Linux
OpenSSL 1.1.0f  25 May 2017
built on: reproducible build, date unspecified
options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr)
compiler: gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_STATIC_ENGINE -DOPENSSL_PIC -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DOPENSSLDIR="\"/usr/lib/ssl\"" -DENGINESDIR="\"/usr/lib/aarch64-linux-gnu/engines-1.1\""
The 'numbers' are in 1000s of bytes per second processed.
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes  16384 bytes
aes-192 cbc      36539.19k    39338.69k    40346.11k    40604.67k    40645.97k    40621.40k
aes-256 cbc      32540.46k    35086.57k    35856.98k    33921.02k    35092.24k    36104.87k
aes-128-cbc      88314.51k   278811.82k   584844.37k   837859.67k   957298.01k   964192.94k
Also i'm getting a bunch of these in the log (unrelated to the openssl test) possibly due to the USB 3.0 drive connected.
 9.542005] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[    9.682999] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[    9.809006] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[   10.009009] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[   10.676004] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[   10.709000] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[   11.775018] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[   11.809028] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
[   12.344005] dwmmc_rockchip ff500000.dwmmc: Unexpected interrupt latency
Thanks for the help.
cpufreq-set -g performance
for i in 128 192 256 ; do openssl speed -elapsed -evp aes-${i}-cbc; done
This (also 'OpenSSL 1.1.0f  25 May 2017' -- Debian Stretch) results in
aes-128-cbc      95001.11k   300025.71k   628819.80k   900902.91k  1028759.55k  1039226.20k
aes-192-cbc      90857.74k   269696.09k   520566.02k   699155.46k   775708.67k   780954.28k
aes-256-cbc      88656.81k   251228.82k   456117.16k   587700.91k   640838.31k   644011.35k
Now connecting an USB3 attached SSD and repeating:
aes-128-cbc      95060.44k   299314.65k   628529.15k   900353.02k  1028920.66k  1039018.67k
aes-192-cbc      90838.22k   269684.97k   520050.86k   699034.62k   776033.62k   780004.01k
aes-256-cbc      88611.06k   251042.15k   456075.01k   587704.32k   640884.74k   644541.10k
'armbianmonitor -u' output: http://ix.io/1hh1 (no 'Unexpected interrupt latency' occurences).
I power the Renegade in a sane way: 5V/4A PSU feeding 5V via GPIO header. @jmandawg how do you power the board? Using the crappy Micro USB connector?
22 minutes ago, jmandawg said:
i'm using a 5v 3A power supply connected to the crappy micro usb connector.  Let me see if i can find something better and try again.
Usually with Micro USB the problem is between PSU and board. More than 99% of all Micro USB cables are simply insufficient and were not made to transport more than 500mA.
Jean-Luc ran into similar problems when reviewing the board (though using the vendor's own PSU with fixed cable which should probably be ok even if Micro USB is only rated for 1800mA max which is a joke if you want to attach host powered USB3 disks). Further readings:
