tom_i Posted July 22, 2018 Share Posted July 22, 2018 14 hours ago, tkaiser said: Boots even from SATA disks behind a crappy SATA PM. Ok thx, fortunatelly my board works pretty well Anyway, my network manager doesn't work as I switched from 4.4. kernel to the next 4.17.5. It shows me just: sudo journalctl -u systemd-networkd-wait-online.service - [sudo] password for nashome: -- Logs begin at Sat 2018-07-21 09:50:37 UTC, end at Sat 2018-07-21 09:57:12 UTC Jul 21 09:50:40 espressobin systemd[1]: Starting Wait for Network to be Configur Jul 21 09:52:40 espressobin systemd-networkd-wait-online[566]: Event loop failed Jul 21 09:52:40 espressobin systemd[1]: systemd-networkd-wait-online.service: Ma Jul 21 09:52:40 espressobin systemd[1]: systemd-networkd-wait-online.service: Fa Jul 21 09:52:40 espressobin systemd[1]: Failed to start Wait for Network to be C Because I'm connected it through "screen" so it looks that it break lines of that log :-/ Link to comment Share on other sites More sharing options...
ebin-dev Posted July 22, 2018 Share Posted July 22, 2018 24 minutes ago, tom_i said: my network manager doesn't work as I switched from 4.4. kernel to the next 4.17.5. I am on Debian stretch- mainline/stable (4.17.5) (Armbian 5.44) - and it works just fine ... Welcome to ARMBIAN 5.44 user-built Debian GNU/Linux 9 (stretch) 4.17.5-mvebu64 # cat /proc/version Linux version 4.17.5-mvebu64 (root@armbian) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #34 SMP PREEMPT Mon Jul 9 16:32:32 UTC 2018 # journalctl -u systemd-networkd-wait-online.service -- No entries -- # systemd --v systemd 232 +PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN @Igor Is there a problem with systemd-networkd in Ubuntu ? Link to comment Share on other sites More sharing options...
Igor Posted July 22, 2018 Share Posted July 22, 2018 Just now, ebin-dev said: Is there a problem with systemd-networkd in Ubuntu ? Ubuntu Bionic? It has plenty of (upstream) bugs and that is the reason we don't support it. Link to comment Share on other sites More sharing options...
tom_i Posted July 22, 2018 Author Share Posted July 22, 2018 Hi @ebin-dev I'm on Debian too: Linux version 4.17.5-mvebu64 (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #87 SMP PREEMPT Sun Jul 8 19:16:19 UTC 2018 lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux testing (buster) Release: testing Codename: buster It shows me some messages about eth0: [ 2868.894331] mvneta d0030000.ethernet eth0: could not attach PHY: -19 [ 2868.898077] mvneta d0030000.ethernet eth0: cannot probe MDIO bus Is there any way, how to debug this? I've tried to define eth0 with DHCP in "/etc/network/interfaces", or run "sudo dhclient eth0". Both with no luck Link to comment Share on other sites More sharing options...
ebin-dev Posted July 22, 2018 Share Posted July 22, 2018 5 minutes ago, tom_i said: Is there any way, how to debug this? You should not change the content of /etc/network/interfaces if you use systemd-networkd. If it is of some help for you - see my configuration below: # cat /etc/network/interfaces # interfaces(5) file used by ifup(8) and ifdown(8) auto lo iface lo inet loopback # cd /etc/systemd/network # ls 10-br0.netdev 10-br0.network 10-eth0.network 10-lan0.network 10-lan1.network 10-wan.network # cat * [NetDev] Name=br0 Kind=bridge MACAddress=XX:XX:XX:XX:XX:XX [Match] Name=br0 [Network] DHCP=ipv4 [Match] Name=eth0 [Network] DHCP=ipv4 [Match] Name=lan0 [Network] Bridge=br0 [Match] Name=lan1 [Network] Bridge=br0 [Match] Name=wan [Network] Bridge=br0 Link to comment Share on other sites More sharing options...
Igor Posted July 22, 2018 Share Posted July 22, 2018 8 minutes ago, tom_i said: Description: Debian GNU/Linux testing (buster) We only support Armbian builds here. Link to comment Share on other sites More sharing options...
Smurfix Posted July 22, 2018 Share Posted July 22, 2018 There is no physical interface named "eth0" you could talk on. There are interfaces named "lan1", "lan0" and "wan". However, eth0 is what the CPU uses to multiplex these, so you need to set that to "up" too. I do it with this simple systemd-networkd rule: # cat /etc/systemd/network/49-switch.network [Match] Name=eth0 [Network] DHCP=no Then you can access the three real interfaces normally. Link to comment Share on other sites More sharing options...
ebin-dev Posted July 22, 2018 Share Posted July 22, 2018 35 minutes ago, Smurfix said: I do it with this simple systemd-networkd rule I have changed the configuration in 10-eth0.network to DHCP=no. It is working, but networkctl reports it failed. # networkctl IDX LINK TYPE OPERATIONAL SETUP 1 lo loopback carrier unmanaged 2 bond0 ether off unmanaged 3 dummy0 ether off unmanaged 4 eth0 ether carrier configuring 5 wan ether carrier failed 6 lan0 ether no-carrier failed 7 lan1 ether no-carrier failed 8 br0 ether routable configured 8 links listed. Link to comment Share on other sites More sharing options...
tom_i Posted July 22, 2018 Author Share Posted July 22, 2018 53 minutes ago, ebin-dev said: You should not change the content of /etc/network/interfaces if you use systemd-networkd. If it is of some help for you - see my configuration below: # cat /etc/network/interfaces # interfaces(5) file used by ifup(8) and ifdown(8) auto lo iface lo inet loopback # cd /etc/systemd/network # ls 10-br0.netdev 10-br0.network 10-eth0.network 10-lan0.network 10-lan1.network 10-wan.network # cat * [NetDev] Name=br0 Kind=bridge MACAddress=XX:XX:XX:XX:XX:XX [Match] Name=br0 [Network] DHCP=ipv4 [Match] Name=eth0 [Network] DHCP=ipv4 [Match] Name=lan0 [Network] Bridge=br0 [Match] Name=lan1 [Network] Bridge=br0 [Match] Name=wan [Network] Bridge=br0 Same for me man. My ip addr show: nashome@espressobin:/etc/systemd/network$ ip addr show 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 3: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 4: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 532 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 5: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 532 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 6: br0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff So no lan0, lan1 are up, so maybe that's the reason it doesn't work. Link to comment Share on other sites More sharing options...
ebin-dev Posted July 22, 2018 Share Posted July 22, 2018 8 minutes ago, tom_i said: So no lan0, lan1 are up, so maybe that's the reason it doesn't work. You are on Debian buster testing - that causes your problem. Is there a reason why you are not using Debian stretch mainline/stable ? The interfaces are up and running: # ip addr show 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever 2: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 3: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 4: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 532 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 5: wan@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 6: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 7: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 8: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff inet 192.168.xx.yy/24 brd 192.168.xx.255 scope global dynamic br0 valid_lft 861638sec preferred_lft 861638sec inet6 2a02:810d:1500:7c44:f2ad:4eff:xxxx:yyyy/64 scope global mngtmpaddr noprefixroute dynamic valid_lft 5214sec preferred_lft 2514sec inet6 fe80::f2ad:4eff:xxxx:yyyy/64 scope link valid_lft forever preferred_lft forever Link to comment Share on other sites More sharing options...
y52 Posted July 22, 2018 Share Posted July 22, 2018 54 minutes ago, ebin-dev said: I have changed the configuration in 10-eth0.network to DHCP=no. It should be [Network] DHCP=ipv4 Link to comment Share on other sites More sharing options...
tom_i Posted July 22, 2018 Author Share Posted July 22, 2018 43 minutes ago, ebin-dev said: You are on Debian buster testing - that causes your problem. Is there a reason why you are not using Debian stretch mainline/stable ? The interfaces are up and running: # ip addr show 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever 2: bond0: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 3: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 4: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 532 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 5: wan@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 6: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 7: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff 8: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff inet 192.168.xx.yy/24 brd 192.168.xx.255 scope global dynamic br0 valid_lft 861638sec preferred_lft 861638sec inet6 2a02:810d:1500:7c44:f2ad:4eff:xxxx:yyyy/64 scope global mngtmpaddr noprefixroute dynamic valid_lft 5214sec preferred_lft 2514sec inet6 fe80::f2ad:4eff:xxxx:yyyy/64 scope link valid_lft forever preferred_lft forever I've seen that 4.17.X kernel has more features for EspressoBin so I wanted to switch to the NEXT. Ddebian Stretch has 4.4. right? Link to comment Share on other sites More sharing options...
Igor Posted July 22, 2018 Share Posted July 22, 2018 Debian testing is not supported. We have enough problems without that. You are welcome to discuss this further in the general area. Link to comment Share on other sites More sharing options...
tom_i Posted July 22, 2018 Author Share Posted July 22, 2018 15 minutes ago, Igor said: Debian testing is not supported. We have enough problems without that. You are welcome to discuss this further in the general area. Aha.. ok. Thx Link to comment Share on other sites More sharing options...
